Текущее время: Вт сен 22, 2026 07:07
 Заголовок сообщения: СтримТВ 2740U
СообщениеДобавлено: Вс мар 15, 2009 21:01
Добрый день. Немогу настроить ТВ. С другим модемом все работает. Инструкции никакой нет :(
Мои настройки:
> dumpcfg
<psitree>
<WirelessCfg>
<vars state="enabled" ssIdIndex="0" country="RU" apMode="ap" bridgeRestrict="disabled" wdsMAC_0="" wdsMAC_1="" wdsMAC_2="" wdsMAC_3="" band="b" channel="6" rate="auto" multicastRate="auto" basicRate="default" fragThreshold="2346" RTSThreshold="2347" DTIM="1" beacon="100" XPress="off" gMode="auto" gProtection="auto" preamble="long" AfterBurner="off" TxPowerPercent="100" WME="auto" WMENoAck="off" WMEApsd="on" RegulatoryMode="off" PreNetRadarDectTime="60" InNetRadarDectTime="60" TpcMitigation="0" AutoChannelTimer="0" NBandwidthCap="0" NCtrlSideband="none" NBand="2" NMCSIdx="-1" NProtection="auto" NMode="auto" NReqd="off" 11Mode="1" />
<wlMssidVars tableSize="4">
<wlMssidEntry enblSsId="1" ssId="D-Link=ADSL=Router" hide="0" apIsolation="off" fltMacMode="disabled" disableWme="off" MaxAssoc = "128" authMode="psk2" radiusServerIP="0.0.0.0" radiusServerPort="1812" radiusServerKey="" wep="disabled" auth="0" keyBit="64-bit" key64_1="" key64_2="" key64_3="" key64_4="" key64Index="1" key128_1="" key128_2="" key128_3="" key128_4="" key128Index="1" wpaRekey="0" wpakey="1111" Preauthentication="off" ReauthTimeout="36000" wpa="tkip" tr69cBeaconType="Basic" tr69cBasicEncryptionModes="None" tr69cBasicAuthenticationMode="None" tr69cWPAEncryptionModes="TKIPEncryption" tr69cWPAAuthenticationMode="PSKAuthentication" tr69cIEEE11iEncryptionModes="AESEncryption" tr69cIEEE11iAuthenticationMode="EAPAuthentication"/>
<wlMssidEntry enblSsId="0" ssId="Guest" hide="0" apIsolation="off" fltMacMode="disabled" disableWme="off" MaxAssoc = "128" authMode="open" radiusServerIP="0.0.0.0" radiusServerPort="1812" radiusServerKey="" wep="disabled" auth="0" keyBit="128-bit" key64_1="" key64_2="" key64_3="" key64_4="" key64Index="1" key128_1="" key128_2="" key128_3="" key128_4="" key128Index="1" wpaRekey="0" wpakey="" Preauthentication="off" ReauthTimeout="36000" wpa="tkip" tr69cBeaconType="Basic" tr69cBasicEncryptionModes="None" tr69cBasicAuthenticationMode="None" tr69cWPAEncryptionModes="TKIPEncryption" tr69cWPAAuthenticationMode="PSKAuthentication" tr69cIEEE11iEncryptionModes="AESEncryption" tr69cIEEE11iAuthenticationMode="EAPAuthentication"/>
<wlMssidEntry enblSsId="0" ssId="Guest1" hide="0" apIsolation="off" fltMacMode="disabled" disableWme="off" MaxAssoc = "128" authMode="open" radiusServerIP="0.0.0.0" radiusServerPort="1812" radiusServerKey="" wep="disabled" auth="0" keyBit="128-bit" key64_1="" key64_2="" key64_3="" key64_4="" key64Index="1" key128_1="" key128_2="" key128_3="" key128_4="" key128Index="1" wpaRekey="0" wpakey="" Preauthentication="off" ReauthTimeout="36000" wpa="tkip" tr69cBeaconType="Basic" tr69cBasicEncryptionModes="None" tr69cBasicAuthenticationMode="None" tr69cWPAEncryptionModes="TKIPEncryption" tr69cWPAAuthenticationMode="PSKAuthentication" tr69cIEEE11iEncryptionModes="AESEncryption" tr69cIEEE11iAuthenticationMode="EAPAuthentication"/>
<wlMssidEntry enblSsId="0" ssId="Guest2" hide="0" apIsolation="off" fltMacMode="disabled" disableWme="off" MaxAssoc = "128" authMode="open" radiusServerIP="0.0.0.0" radiusServerPort="1812" radiusServerKey="" wep="disabled" auth="0" keyBit="128-bit" key64_1="" key64_2="" key64_3="" key64_4="" key64Index="1" key128_1="" key128_2="" key128_3="" key128_4="" key128Index="1" wpaRekey="0" wpakey="" Preauthentication="off" ReauthTimeout="36000" wpa="tkip" tr69cBeaconType="Basic" tr69cBasicEncryptionModes="None" tr69cBasicAuthenticationMode="None" tr69cWPAEncryptionModes="TKIPEncryption" tr69cWPAAuthenticationMode="PSKAuthentication" tr69cIEEE11iEncryptionModes="AESEncryption" tr69cIEEE11iAuthenticationMode="EAPAuthentication"/>
</wlMssidVars>
</WirelessCfg>
<SystemInfo>
<protocol autoScan="disable" upnp="enable" igmpSnp ="enable" igmpMode ="disable" macFilterPolicy="forward" encodePassword="enable" siproxd="enable" enetwan="disable" pppThrough="enable"/>
<sysLog state="disable" displayLevel="ERR" logLevel="DEBUG" option="local" serverIP="0.0.0.0" serverPort="514"/>
<snmp state="enable" readCommunity="public" writeCommunity="private" sysName="DSL2740B" sysLocation="unknown" sysContact="unknown" trapIP="0.0.0.0" debug="0" configId="00000000"/>
<sysUserName value="adm1n"/>
<sysPassword value="ehjybjE5ODQ="/>
<sptPassword value="c3VfgbtydA=="/>
<usrPassword value="dXglcy=="/>
<dns dynamic="enable" primary="192.168.1.1" secondary="192.168.1.1" domain=""/>
</SystemInfo>
<AtmCfg>
<initCfg structureId="2" threadPriority="25" freeCellQSize="10" freePktQSize="200" freePktQBufSize="1600" freePktQBufOffset="32" rxCellQSize="10" rxPktQSize="200" txFifoPriority="64" aal5MaxSduLen="64" aal2MaxSduLen="0"/>
</AtmCfg>
<AtmCfgTd>
<td1 cat="UBR" PCR="0" SCR="0" MBS="0"/>
</AtmCfgTd>
<SecCfg>
<srvCtrlList ftp="lan" http="lan" icmp="lan" snmp="lan" ssh="lan" telnet="lan" tftp="lan"/>
</SecCfg>
<Lan>
<entry9999 address="1.1.1.1" mask="255.255.255.0" dhcpServer="disable" leasedTime="0" startAddr="0.0.0.0" endAddr="0.0.0.0" instanceId="1509949444"/>
<entry1 address="10.0.0.3" mask="255.255.255.0" dhcpServer="disable" leasedTime="24" startAddr="192.168.1.2" endAddr="192.168.1.254" instanceId="1509949441"/>
</Lan>
<RouteCfg>
<ripGlobal state="disable" ripIfcTableSize="1"/>
<ripIfc tableSize="1">
<ripIfcEntry id="1" name="br0" state="disable" version="2" operation="active"/>
</ripIfc>
</RouteCfg>
<AtmCfgVcc>
<vccId9999 vpi="0" vci="65534" tdId="0" aalType="AAL2" adminStatus="down" encap="unknown" qos="disable" instanceId="1509949443"/>
<vccId1 vpi="1" vci="50" tdId="1" aalType="AAL5" adminStatus="up" encap="llc" qos="disable" instanceId="1509949441"/>
<vccId2 vpi="1" vci="91" tdId="1" aalType="AAL5" adminStatus="up" encap="llc" qos="disable" instanceId="1509949442"/>
<vccId3 vpi="1" vci="92" tdId="1" aalType="AAL5" adminStatus="up" encap="llc" qos="disable" instanceId="1509949443"/>
</AtmCfgVcc>
<pppsrv_1_50>
<ppp_conId1 userName="" password="" serviceName="" idleTimeout="0" pppMtu="1492" ipExt="disable" keepAlive="enable" auth="auto" useStaticIpAddr="0" localIpAddr="255.255.255.255" Debug="disable"/>
</pppsrv_1_50>
<wan_1_50>
<entry1 vccId="1" conId="1" name="pppoe_1_50_1" protocol="PPPOE" encap="LLC" firewall="enable" nat="enable" igmp="disable" vlanId="-1" service="enable" instanceId="1509949442" iptv="disable"/>
</wan_1_50>
<PMapCfg>
<pmap tableSize="2">
<pmapEntry id="1" groupName="Default" ifList="wl0|wl0.1|wl0.2|wl0.3|eth0.3|eth0.4|eth0.5" vendorid0="" vendorid1="" vendorid2="" vendorid3="" vendorid4=""/>
<pmapEntry id="2" groupName="StreamTV" ifList="eth0.2|nas_1_91|nas_1_92" vendorid0="" vendorid1="" vendorid2="" vendorid3="" vendorid4=""/>
</pmap>
<pmapIfcCfg pmapIfName="eth0" pmapIfcStatus="enable"/>
</PMapCfg>
<wan_1_91>
<entry1 vccId="2" conId="1" name="br_1_91" protocol="BRIDGE" encap="LLC" firewall="disable" nat="disable" igmp="disable" vlanId="-1" service="enable" instanceId="1509949443" iptv="disable"/>
</wan_1_91>
<wan_1_92>
<entry1 vccId="3" conId="1" name="br_1_92" protocol="BRIDGE" encap="LLC" firewall="disable" nat="disable" igmp="disable" vlanId="-1" service="enable" instanceId="1509949444" iptv="disable"/>
</wan_1_92>
<ADSL/>
<PptpCfg/>
<DDNSCfg/>
<SNTPCfg/>
<ToDCfg/>
<MACCfg/>
<EngDbgCfg/>
<DatetimeCfg/>
<URLFilterCfg/>
</psitree>
 Заголовок сообщения: Re: СтримТВ 2740U
СообщениеДобавлено: Вт апр 07, 2009 09:27
У меня работает всё. с виду у тебя всё правильно. Вечером домой приду - отпишусь о своём конфиге
СообщениеДобавлено: Вт апр 07, 2009 10:35
Мои настройки:
Настроено всё верно. А в чем проблема, что конкретно не работает?
