Текущее время: Ср сен 23, 2026 13:29
 Заголовок сообщения: dlink dsl 2500u/bru/d + pptp
СообщениеДобавлено: Чт авг 14, 2008 15:13
добрый день, есть dlink dsl 2500u/bru/d
Board ID: 96332CG
Software Version: RU_DSL-2500U_1.30_05282008
Bootloader (CFE) Version: (before 1.0.37-5.12)
пытаюсь на нём поднять vpn клиент. вроде как соединяется, но траффик не идёт и секунд через 30 отключается.
Лог:
Jan 1 00:04:01     daemon     notice     pppd[602]: MPPC/MPPE 40-bit stateless compression enabled
Jan 1 00:04:02    daemon    notice    pppd[602]: local IP address 192.168.7.9
Jan 1 00:04:02    daemon    notice    pppd[602]: remote IP address 192.168.7.8
Jan 1 00:06:16    user    debug    syslog: mkdir -p /var/ppp/peers
Jan 1 00:06:20    user    debug    syslog: echo "#!/bin/sh" > /var/ppp/ip-up.local
Jan 1 00:06:22    user    debug    syslog: echo "#!/bin/sh" > /var/ppp/ip-down.local
Jan 1 00:06:22    user    debug    syslog: echo "route add default dev \$1" >> /var/ppp/ip-up.local
Jan 1 00:06:22    user    debug    syslog: echo "route del default dev \$1" >> /var/ppp/ip-down.local
Jan 1 00:06:23    user    debug    syslog: echo "iptables -t nat -A POSTROUTING -o \$1 -j MASQUERADE" >> /var/ppp/ip-up.local
Jan 1 00:06:23    user    debug    syslog: echo "iptables -A FORWARD -o \$1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu" >> /var/ppp/ip-up.local
Jan 1 00:06:23    user    debug    syslog: echo "iptables -A FORWARD -i \$1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu" >> /var/ppp/ip-up.local
Jan 1 00:06:23    user    debug    syslog: chmod +rx /var/ppp/ip-up.local
Jan 1 00:06:23    user    debug    syslog: echo "iptables -t nat -D POSTROUTING -o \$1 -j MASQUERADE" >> /var/ppp/ip-down.local
Jan 1 00:06:23    user    debug    syslog: echo "iptables -D FORWARD -o \$1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu" >> /var/ppp/ip-down.local
Jan 1 00:06:23    user    debug    syslog: echo "iptables -D FORWARD -i \$1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu" >> /var/ppp/ip-down.local
Jan 1 00:06:23    user    debug    syslog: chmod +rx /var/ppp/ip-down.local
Jan 1 00:06:23    user    debug    syslog: kill -9 602
Jan 1 00:06:24    user    debug    syslog: pppd call vpnuser
Jan 1 00:06:26    daemon    notice    pppd[815]: pppd 2.4.3 started by admin, uid 0
Jan 1 00:06:26    daemon    info    pppd[815]: Using interface ppp0
Jan 1 00:06:26    daemon    notice    pppd[815]: Connect: ppp0 <--> /dev/ttyp0
Jan 1 00:06:27    daemon    warn    pppd[815]: Warning - secret file /etc/ppp/pap-secrets has world and/or group access
Jan 1 00:06:29    user    debug    syslog: echo 0 > /var/isdft_cfg
Jan 1 00:06:36    daemon    warn    pppd[815]: Warning - secret file /etc/ppp/chap-secrets has world and/or group access
Jan 1 00:06:40    daemon    warn    pppd[815]: Warning - secret file /etc/ppp/chap-secrets has world and/or group access
Jan 1 00:06:41    daemon    warn    pppd[815]: Warning - secret file /etc/ppp/chap-secrets has world and/or group access
Jan 1 00:06:41    daemon    notice    pppd[815]: MPPC compression enabled
Jan 1 00:06:41    daemon    notice    pppd[815]: local IP address 192.168.7.12
Jan 1 00:06:41    daemon    notice    pppd[815]: remote IP address 192.168.7.8
Jan 1 00:07:08    user    warn    syslog: dns query failed
Jan 1 00:07:10    user    warn    syslog: dns query failed
Jan 1 00:07:12    user    warn    syslog: dns query failed
Jan 1 00:07:15    user    warn    syslog: dns query failed
Jan 1 00:07:17    user    warn    syslog: dns query failed
Jan 1 00:07:19    user    warn    syslog: dns query failed
Jan 1 00:07:53    user    warn    syslog: dns query failed
Jan 1 00:07:55    user    warn    syslog: dns query failed
Jan 1 00:07:57    user    warn    syslog: dns query failed
Jan 1 00:07:59    user    warn    syslog: dns query failed
Jan 1 00:08:01    user    warn    syslog: dns query failed
Jan 1 00:08:04    user    warn    syslog: dns query failed
Jan 1 00:08:36    user    warn    syslog: dns query failed
Jan 1 00:08:38    daemon    notice    pppd[815]: Modem hangup
Jan 1 00:08:38    user    warn    syslog: dns query failed
Jan 1 00:08:40    daemon    info    pppd[815]: Connect time 2.0 minutes.
Jan 1 00:08:40    daemon    info    pppd[815]: Sent 8572933 bytes, received 0 bytes.
Jan 1 00:08:41    user    warn    syslog: dns query failed
Jan 1 00:08:41    daemon    notice    pppd[815]: Connection terminated....
Jan 1 00:08:43    user    warn    syslog: dns query failed
Jan 1 00:08:45    user    warn    syslog: dns query failed
Jan 1 00:08:47    user    warn    syslog: dns query failed
Jan 1 00:08:48    daemon    info    pppd[815]: Using interface ppp0
Jan 1 00:08:50    daemon    notice    pppd[815]: Connect: ppp0 <--> /dev/ttyp0
Jan 1 00:08:52    daemon    warn    pppd[815]: Warning - secret file /etc/ppp/pap-secrets has world and/or group access
Jan 1 00:08:57    daemon    warn    pppd[815]: Warning - secret file /etc/ppp/chap-secrets has world and/or group access
Jan 1 00:09:05    daemon    warn    pppd[815]: Warning - secret file /etc/ppp/chap-secrets has world and/or group access
Jan 1 00:09:15    daemon    warn    pppd[815]: Warning - secret file /etc/ppp/chap-secrets has world and/or group access
Jan 1 00:09:20    daemon    warn    pppd[815]: Warning - secret file /etc/ppp/chap-secrets has world and/or group access
Jan 1 00:09:26    daemon    notice    pppd[815]: MPPC compression enabled
Jan 1 00:09:26    daemon    notice    pppd[815]: local IP address 192.168.7.12
Jan 1 00:09:26    daemon    notice    pppd[815]: remote IP address 192.168.7.8
Jan 1 00:09:56    user    warn    syslog: dns query failed
Jan 1 00:09:58    user    warn    syslog: dns query failed
Jan 1 00:10:01    user    warn    syslog: dns query failed
Jan 1 00:10:03    user    warn    syslog: dns query failed
Jan 1 00:10:05    user    warn    syslog: dns query failed
Jan 1 00:10:08    user    warn    syslog: dns query failed
Jan 1 00:10:41    user    warn    syslog: dns query failed
Jan 1 00:10:44    user    warn    syslog: dns query failed
Jan 1 00:10:46    user    warn    syslog: dns query failed
Jan 1 00:10:48    user    warn    syslog: dns query failed
Jan 1 00:10:50    user    warn    syslog: dns query failed
Jan 1 00:10:52    user    warn    syslog: dns query failed
Jan 1 00:10:59    daemon    notice    pppd[815]: Modem hangup
Jan 1 00:11:00    daemon    info    pppd[815]: Connect time 1.6 minutes.
Jan 1 00:11:00    daemon    info    pppd[815]: Sent 3340951 bytes, received 0 bytes.
Jan 1 00:11:04    daemon    notice    pppd[815]: Connection terminated....
Jan 1 00:11:10    daemon    info    pppd[815]: Using interface ppp0
Jan 1 00:11:13    daemon    notice    pppd[815]: Connect: ppp0 <--> /dev/ttyp0
Jan 1 00:11:16    daemon    warn    pppd[815]: Warning - secret file /etc/ppp/pap-secrets has world and/or group access
Jan 1 00:11:20    daemon    warn    pppd[815]: Warning - secret file /etc/ppp/chap-secrets has world and/or group access
Jan 1 00:11:22    daemon    warn    pppd[815]: Warning - secret file /etc/ppp/chap-secrets has world and/or group access
Jan 1 00:11:22    daemon    notice    pppd[815]: MPPC compression enabled
Jan 1 00:11:22    daemon    notice    pppd[815]: local IP address 192.168.7.12
Jan 1 00:11:22    daemon    notice    pppd[815]: remote IP address 192.168.7.8
Jan 1 00:11:59    user    warn    syslog: dns query failed
Jan 1 00:12:01    user    warn    syslog: dns query failed
Jan 1 00:12:03    user    warn    syslog: dns query failed
Jan 1 00:12:06    user    warn    syslog: dns query failed
Jan 1 00:12:08    user    warn    syslog: dns query failed
Jan 1 00:12:10    user    warn    syslog: dns query failed
Jan 1 00:12:44    user    warn    syslog: dns query failed
Jan 1 00:12:46    user    warn    syslog: dns query failed
Jan 1 00:12:48    user    warn    syslog: dns query failed
Jan 1 00:12:50    user    warn    syslog: dns query failed
Jan 1 00:12:52    user    warn    syslog: dns query failed
Jan 1 00:12:54    user    warn    syslog: dns query failed
Jan 1 00:13:20    daemon    notice    pppd[815]: Modem hangup
Jan 1 00:13:21    daemon    info    pppd[815]: Connect time 2.0 minutes.
Jan 1 00:13:21    daemon    info    pppd[815]: Sent 12482579 bytes, received 0 bytes.
Jan 1 00:13:23    daemon    notice    pppd[815]: Connection terminated....
Jan 1 00:13:23    user    debug    syslog: mkdir -p /var/ppp/peers
Jan 1 00:13:26    daemon    info    pppd[815]: Using interface ppp0
Jan 1 00:13:34    daemon    notice    pppd[815]: Connect: ppp0 <--> /dev/ttyp0
Jan 1 00:13:36    user    debug    syslog: echo "#!/bin/sh" > /var/ppp/ip-up.local
Jan 1 00:13:40    daemon    warn    pppd[815]: Warning - secret file /etc/ppp/pap-secrets has world and/or group access
Jan 1 00:13:46    daemon    warn    pppd[815]: Warning - secret file /etc/ppp/chap-secrets has world and/or group access
Jan 1 00:13:47    user    debug    syslog: echo "#!/bin/sh" > /var/ppp/ip-down.local
Jan 1 00:13:47    daemon    notice    pppd[815]: MPPC compression enabled
Jan 1 00:13:47    daemon    notice    pppd[815]: local IP address 192.168.7.12
Jan 1 00:13:47    daemon    notice    pppd[815]: remote IP address 192.168.7.8
Jan 1 00:13:54    user    warn    kernel: AdslCoreEcUpdTmr: timeMs=1800340 ecUpdMask=0x40000
Jan 1 00:13:56    user    debug    syslog: echo "route add default dev \$1" >> /var/ppp/ip-up.local
Jan 1 00:14:03    user    debug    syslog: echo "route del default dev \$1" >> /var/ppp/ip-down.local
Jan 1 00:14:08    user    debug    syslog: echo "iptables -t nat -A POSTROUTING -o \$1 -j MASQUERADE" >> /var/ppp/ip-up.local
Jan 1 00:14:12    user    debug    syslog: echo "iptables -A FORWARD -o \$1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu" >> /var/ppp/ip-up.local
Jan 1 00:14:16    user    debug    syslog: echo "iptables -A FORWARD -i \$1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu" >> /var/ppp/ip-up.local
Jan 1 00:14:18    user    debug    syslog: chmod +rx /var/ppp/ip-up.local
Jan 1 00:14:18    user    debug    syslog: echo "iptables -t nat -D POSTROUTING -o \$1 -j MASQUERADE" >> /var/ppp/ip-down.local
Jan 1 00:14:18    user    debug    syslog: echo "iptables -D FORWARD -o \$1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu" >> /var/ppp/ip-down.local
Jan 1 00:14:18    user    debug    syslog: echo "iptables -D FORWARD -i \$1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu" >> /var/ppp/ip-down.local
Jan 1 00:14:18    user    debug    syslog: chmod +rx /var/ppp/ip-down.local
Jan 1 00:14:19    user    debug    syslog: kill -9 815
Jan 1 00:14:19    user    debug    syslog: pppd call vpnuser
Jan 1 00:14:22    daemon    notice    pppd[1111]: pppd 2.4.3 started by admin, uid 0
Jan 1 00:14:22    daemon    info    pppd[1111]: Using interface ppp0
Jan 1 00:14:22    daemon    notice    pppd[1111]: Connect: ppp0 <--> /dev/ttyp0
Jan 1 00:14:24    daemon    warn    pppd[1111]: Warning - secret file /etc/ppp/pap-secrets has world and/or group access
Jan 1 00:14:25    user    debug    syslog: echo 0 > /var/isdft_cfg
Jan 1 00:14:32    daemon    warn    pppd[1111]: Warning - secret file /etc/ppp/chap-secrets has world and/or group access
Jan 1 00:14:39    daemon    warn    pppd[1111]: Warning - secret file /etc/ppp/chap-secrets has world and/or group access
Jan 1 00:14:43    daemon    warn    pppd[1111]: Warning - secret file /etc/ppp/chap-secrets has world and/or group access
Jan 1 00:14:51    daemon    notice    pppd[1111]: MPPC compression enabled
Jan 1 00:14:52    daemon    notice    pppd[1111]: local IP address 192.168.7.13
Jan 1 00:14:52    daemon    notice    pppd[1111]: remote IP address 192.168.7.8
Jan 1 00:15:40    user    warn    syslog: dns query failed
Jan 1 00:15:43    user    warn    syslog: dns query failed
Jan 1 00:15:45    user    warn    syslog: dns query failed
Jan 1 00:15:47    user    warn    syslog: dns query failed
Jan 1 00:15:47    user    crit    kernel: ADSL link down
Jan 1 00:15:49    user    warn    syslog: dns query failed
Jan 1 00:15:51    user    warn    syslog: dns query failed
Jan 1 00:16:25    user    warn    syslog: dns query failed
Jan 1 00:16:27    user    warn    syslog: dns query failed
Jan 1 00:16:30    user    warn    syslog: dns query failed
Jan 1 00:16:32    user    warn    syslog: dns query failed
Jan 1 00:16:34    user    warn    syslog: dns query failed
Jan 1 00:16:36    user    warn    syslog: dns query failed
Jan 1 00:17:08    user    warn    syslog: dns query failed
Jan 1 00:17:11    user    warn    syslog: dns query failed
Jan 1 00:17:13    user    warn    syslog: dns query failed
Jan 1 00:17:15    user    warn    syslog: dns query failed
Jan 1 00:17:17    user    warn    syslog: dns query failed
Jan 1 00:17:19    user    warn    syslog: dns query failed
Jan 1 00:17:30    daemon    notice    pppd[1111]: Terminating connection due to link down.
Jan 1 00:17:32    user    debug    syslog: kill -9 1111
Jan 1 00:17:34    daemon    info    pppd[1111]: Connect time 2.7 minutes.
Jan 1 00:17:34    daemon    info    pppd[1111]: Sent 19280946 bytes, received 0 bytes.
Jan 1 00:17:34    user    crit    kernel: ADSL G.994 training
Jan 1 00:17:37    user    debug    syslog: echo "#!/bin/sh" > /var/ppp/ip-up.local
Jan 1 00:17:38    user    debug    syslog: echo "#!/bin/sh" > /var/ppp/ip-down.local
Jan 1 00:17:38    user    debug    syslog: mkdir -p /var/ppp/peers
Jan 1 00:17:40    user    debug    syslog: echo 0 > /var/isdft_cfg
Jan 1 00:17:43    user    crit    kernel: ADSL G.992 started
Jan 1 00:17:46    user    crit    kernel: ADSL G.992 channel analysis
Jan 1 00:17:52    user    warn    syslog: dns query failed
Jan 1 00:17:53    user    crit    kernel: ADSL G.992 message exchange
Jan 1 00:17:54    user    crit    kernel: ADSL link up, interleaved, us=509, ds=2045
Jan 1 00:17:54    user    warn    syslog: dns query failed
Jan 1 00:17:55    user    debug    syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107
Jan 1 00:17:56    user    debug    syslog: echo > /proc/net/ip_conntrack
Jan 1 00:17:56    user    debug    syslog: echo "1000" > /proc/sys/net/ipv4/ip_conntrack_max
Jan 1 00:17:56    user    debug    syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107 2>/dev/null
Jan 1 00:17:56    user    debug    syslog: iptables -t nat -D POSTROUTING -o nas_0_0_33 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Jan 1 00:17:56    user    debug    syslog: iptables -t nat -A POSTROUTING -o nas_0_0_33 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Jan 1 00:17:56    user    debug    syslog: kill -9 557
Jan 1 00:17:56    user    debug    syslog: echo > /var/hosts
Jan 1 00:17:57    user    debug    syslog: iptables -I INPUT 1 -p icmp --icmp-type echo-request -i nas_0_0_33 -j ACCEPT
Jan 1 00:17:59    user    debug    syslog: kill -SIGTERM 607
Jan 1 00:17:59    user    debug    syslog: /bin/igmp nas_0_0_33 &
Jan 1 00:17:59    user    notice    igmp[1361]: igmp started!
Jan 1 00:17:59    user    notice    igmp[1361]: setsockopt - MRT_ADD_VIF
Jan 1 00:18:03    user    debug    igmp[1398]: iptables -D FORWARD -i nas_0_0_33 -d 239.255.255.250 -j DROP 2>/dev/null
Jan 1 00:18:04    user    debug    igmp[1400]: iptables -t filter -I FORWARD 1 -i nas_0_0_33 -d 239.255.255.250 -j ACCEPT 2>/dev/null
Jan 1 00:20:05    user    debug    syslog: ethctl vport query 2>/var/vcfgerr
Jan 1 00:20:05    user    debug    syslog: rm /var/vcfgerr
Jan 1 00:20:08    user    crit    kernel: OAM loopback response not received on PORT/VPI/VCI 0/0/33.
Jan 1 00:20:08    user    debug    syslog: ping 192.168.4.1
Jan 1 00:20:09    user    debug    syslog: ping 212.57.109.6
Что то из лога не пойму, что ему не нравится. Спасибо.
 Заголовок сообщения: Re: dlink dsl 2500u/bru/d + pptp
СообщениеДобавлено: Пт авг 15, 2008 13:38
Board ID: 96332CG
Лог:
Что используется в качестве PPTP-сервера? Или провайдер предоставляет доступ в интернет через VPN?
Попробуйте обновить прошивку модема до версии 1.40_08132008
http://www.dlink.ru/fw/firmware_upgrade.html
СообщениеДобавлено: Пт авг 15, 2008 22:40
Прошивку менял, тоже самое. PPTP сервер - ISA 2006 Ent.
СообщениеДобавлено: Ср авг 20, 2008 22:15
Можно я тож спрошу?
Есть провайдер который мне дал модем с настройками, модем в бридже. На компьютере соединение через PPTP.
Вопрос: можно ли используя DSL-2540U раздать инет на несколько компьтеров или придется в добавок к своему модему покупать чтонить на подобии DIR-100?
СообщениеДобавлено: Чт авг 21, 2008 11:14
Какой тип аутентификации настроен на сервере? Используется ли MPPE-шифрование?
СообщениеДобавлено: Чт авг 21, 2008 11:16
kukaxa писал(а):
Можно я тож спрошу?
Используя DSL-2540U нельзя, используя DSL-2540U/BRU/D можно.
СообщениеДобавлено: Чт авг 21, 2008 12:33
В магазине на 2500U - Model No: DSL-2500U/BRU/D
дома лежит 2540U - Model No: DSL-2540U и почему то на другой наклейке отдельно написано /BRU/D. Так и должно быть?
Если ето он, то дайде пожалуйста ссылку на настройку этого PPTP, что-то у меня не получается :(
