Текущее время: Сб сен 26, 2026 20:49
Начать новую тему Ответить на тему  [ Сообщений: 20 ]  На страницу Пред.  1, 2
СообщениеДобавлено: Пн апр 14, 2008 22:47
Вот последний лог:
Apr 14 23:28:03 user alert kernel: Intrusion -> IN=ppp_1_50_1 OUT= MAC= SRC=78.85.45.238 DST=91.76.87.246 LEN=48 TOS=0x00 PREC=0x20 TTL=117 ID=53588 DF PROTO=TCP SPT=10126 DPT=34315 WINDOW=16384 RES=0x00 SYN URGP=0
Apr 14 23:28:07 user alert kernel: Intrusion -> IN=ppp_1_50_1 OUT= MAC= SRC=78.85.45.238 DST=91.76.87.246 LEN=48 TOS=0x00 PREC=0x20 TTL=117 ID=53792 DF PROTO=TCP SPT=10126 DPT=34315 WINDOW=16384 RES=0x00 SYN URGP=0
Apr 14 23:29:05 user alert kernel: Intrusion -> IN=ppp_1_50_1 OUT= MAC= SRC=78.85.45.238 DST=91.76.87.246 LEN=48 TOS=0x00 PREC=0x20 TTL=117 ID=57449 DF PROTO=TCP SPT=16860 DPT=34315 WINDOW=16384 RES=0x00 SYN URGP=0
Apr 14 23:29:08 user alert kernel: Intrusion -> IN=ppp_1_50_1 OUT= MAC= SRC=78.85.45.238 DST=91.76.87.246 LEN=48 TOS=0x00 PREC=0x20 TTL=117 ID=57627 DF PROTO=TCP SPT=16860 DPT=34315 WINDOW=16384 RES=0x00 SYN URGP=0
Apr 14 23:31:19 user alert kernel: Intrusion -> IN=ppp_1_50_1 OUT= MAC= SRC=78.85.45.238 DST=91.76.87.246 LEN=48 TOS=0x00 PREC=0x20 TTL=117 ID=356 DF PROTO=TCP SPT=10646 DPT=34315 WINDOW=16384 RES=0x00 SYN URGP=0
Apr 14 23:31:23 user alert kernel: Intrusion -> IN=ppp_1_50_1 OUT= MAC= SRC=78.85.45.238 DST=91.76.87.246 LEN=48 TOS=0x00 PREC=0x20 TTL=117 ID=531 DF PROTO=TCP SPT=10646 DPT=34315 WINDOW=16384 RES=0x00 SYN URGP=0
Apr 14 23:37:46 user alert kernel: Intrusion -> IN=ppp_1_50_1 OUT= MAC= SRC=78.85.45.238 DST=91.76.87.246 LEN=48 TOS=0x00 PREC=0x20 TTL=117 ID=23818 DF PROTO=TCP SPT=11182 DPT=34315 WINDOW=16384 RES=0x00 SYN URGP=0
Apr 14 23:37:49 user alert kernel: Intrusion -> IN=ppp_1_50_1 OUT= MAC= SRC=78.85.45.238 DST=91.76.87.246 LEN=48 TOS=0x00 PREC=0x20 TTL=117 ID=23961 DF PROTO=TCP SPT=11182 DPT=34315 WINDOW=16384 RES=0x00 SYN URGP=0
Apr 14 23:38:55 user alert kernel: Intrusion -> IN=ppp_1_50_1 OUT= MAC= SRC=78.85.45.238 DST=91.76.87.246 LEN=48 TOS=0x00 PREC=0x20 TTL=117 ID=28446 DF PROTO=TCP SPT=14466 DPT=34315 WINDOW=16384 RES=0x00 SYN URGP=0
Apr 14 23:41:47 user alert kernel: Intrusion -> IN=ppp_1_50_1 OUT= MAC= SRC=78.85.45.238 DST=91.76.87.246 LEN=48 TOS=0x00 PREC=0x20 TTL=117 ID=40380 DF PROTO=TCP SPT=11635 DPT=34315 WINDOW=16384 RES=0x00 SYN URGP=0
Может, это о чем-то говорит?
СообщениеДобавлено: Вт апр 15, 2008 13:23
andrevv писал(а):
Вот последний лог:
В данном случае наблюдаются запросы на соединение (SYN) с IP адреса источника 78.85.45.238 с портом назначения 34315
Дело в том, что порт 34315 не использует ни одно приложение и поэтому не ясна цель атаки (если это атака).
Вопрос: используете ли Вы p2p приложения (e-Mule и прочее)?
WEB интерфейс работает нестабильно когда в логах появляются подобного рода записи? Что происходит, когда к устройству не подключена телефонная линия? WEB интерфейс работает нормально?
С уважением, Давыдов Денис.
СообщениеДобавлено: Вт апр 15, 2008 14:36
Не используются подобного рода приложения. Ни на одном из трех компов, на которых это происходит.
Web-интерфейс зависает еще до ввода мной логина/пароля для dsl-соединения. Поэтому вряд ли это атаки извне. Зависало и до втыкания телефонной линии. Я привожу куски лога уже после его (лога) включения, а это стоит мне кучу времени и нервов, Web-интерфейс начинает зависать сразу после перегрузки роутера.
Одно время я думал, может, Outpost, установленный на компах что-то глючит, но я его останавливал и все равно получал такое же зависание.
При этом пинг до самого роутера стабилен, до www.ru - стабилен. Но сайты грузятся почти без картинок, причем картинки не показываются даже в принудильном порядке. Часто грузится долго, а бывает, что и не грузится.
СообщениеДобавлено: Вт апр 15, 2008 14:38
Привозите устройство в сервис - проверим в Вашем присутствии.
СообщениеДобавлено: Вт апр 15, 2008 22:00
Честно говоря, был почти уверен в браке именно девайса. Но для полной успокоенности притащил с работы ноут, на котором не стоит Outpost. И никаких проблем не возникло! Веб-морда бегает картинки вроде грузятся. Т.е. почти однозначно дело в Outpost'e (у меня на всех трех компах 3.5.641). Но даже отключая его,я не добивался нормальной работы, видимо, только снос его поможет работе с роутером. Или нет? Я читал топики, посвященные работе с Outpost'ом, делал все, что там предлагалось - не помогло, а без него не хочется выходить в инет. Вопрос, наверное, несколько отошел уже от темы, но, может, у кого-то есть опыт по работе с 2640 с Outpost'ом на борту? Или специалисты что подскажут?
