Текущее время: Вт сен 29, 2026 00:29
СообщениеДобавлено: Вт окт 02, 2007 12:23
Сам модем работает уже 4 месяца круглосуточно без нареканий. Но
вчера вечером перегрузил модем, и пропала авторизация пользователя к серверу провайдера. Индикатор Internet горит красным.
прошивка: RU_DSL-2500U_3-06-04-0Z00.A2pB021c.d19b
Лог:
ADSL Statistics
Mode: ADSL2
Line Coding: Trellis On
Status: No Defect
Link Power State: L0
Downstream Upstream
SNR Margin (dB): 32.1 26.2
Attenuation (dB): 11.0 5.5
Output Power (dBm): 19.3 12.4
Attainable Rate (Kbps): 13032 1264
Rate (Kbps): 6142 636
MSGc (number of bytes in overhead channel message): 59 16
B (number of bytes in Mux Data Frame): 190 19
M (number of Mux Data Frames in FEC Data Frame): 1 8
T (Mux Data Frames over sync bytes): 1 3
R (number of check bytes in FEC Data Frame): 16 16
S (ratio of FEC over PMD Data Frame length): 0.9898 7.9101
L (number of bits in PMD Data Frame): 1673 178
D (interleaver depth): 64 8
Delay (msec): 15 15
Super Frames: 26064 26062
Super Frame Errors: 0 3
RS Words: 1694162 221527
RS Correctable Errors: 0 4309
RS Uncorrectable Errors: 0 N/A
HEC Errors: 0 2220
OCD Errors: 0 0
LCD Errors: 0 0
Total Cells: 6077828 1368595873
Data Cells: 1024 103104237
Bit Errors: 0 95818
Total ES: 0 5
Total SES: 0 4
Total UAS: 13 76130
Jan 1 00:08:01 daemon crit pppd[271]: PPP server detected.
Jan 1 00:08:01 daemon crit pppd[271]: PPP session established.
Jan 1 00:08:03 daemon crit pppd[271]: PPP LCP UP.
Jan 1 00:08:06 daemon err pppd[271]: User name and password authentication failed.
Jan 1 00:08:09 daemon crit pppd[271]: PPP server detected.
Jan 1 00:08:09 daemon crit pppd[271]: PPP session established.
Jan 1 00:08:11 daemon crit pppd[271]: PPP LCP UP.
Jan 1 00:08:16 daemon err pppd[271]: User name and password authentication failed.
Jan 1 00:08:19 daemon crit pppd[271]: PPP server detected.
Jan 1 00:08:19 daemon crit pppd[271]: PPP session established.
Jan 1 00:08:21 daemon crit pppd[271]: PPP LCP UP.
Логин и пароль изначально верны, т.к. до этого все работало
СообщениеДобавлено: Вт окт 02, 2007 13:16
дозвонился до техподдержки провайдера, оказалось, что пров не пускает последующие авторизации, если предыдущая сессия не завершена. Они при мне разорвали сеанс, и после перезагрузки модема все заработало.
Тему можно закрыть
Да, забыл, тип подключения безлим ALSL.
