Текущее время: Вт сен 29, 2026 22:11
СообщениеДобавлено: Пт фев 23, 2007 12:34
проблема такова:
Jan 2 13:07:55> Terminated: Modem Hang-Up
Jan 2 13:07:55> Modem hangup
Jan 2 13:07:55> Connection terminated.
Jan 2 13:07:55> pppd 2.4.3 started by root, uid 0
Jan 2 13:07:55> Connect: ppp0 {--} nas0
Jan 2 13:07:57> PAP authentication succeeded
Jan 2 13:07:57> peer from calling number 00:13:5F:5E:90:1B authorized
Jan 2 13:07:57> WAN IP address 88.205.xxx.xxx
Jan 2 13:07:57> PPPoE Connect with IP Address 88.205.xxx.xxx
Jan 2 13:07:57> PPPoE Connection Successfully Established
Jan 2 13:07:57> PPPoE Connect with Gateway IP Address: 195.54.4.9
Jan 2 13:07:57> WAN gateway 195.54.4.9
Jan 2 13:07:57> primary DNS address 195.54.2.1
Jan 2 13:07:57> secondary DNS address 212.57.145.253
Jan 2 13:12:55> Terminated: Modem Hang-Up
Jan 2 13:12:55> Modem hangup
Jan 2 13:12:55> Connection terminated.
Jan 2 13:12:55> pppd 2.4.3 started by root, uid 0
Jan 2 13:12:55> Connect: ppp0 {--} nas0
Jan 2 13:12:57> PAP authentication succeeded
Jan 2 13:12:57> peer from calling number 00:13:5F:5E:90:1B authorized
Jan 2 13:12:57> WAN IP address 88.205.xxx.xxx
Jan 2 13:12:57> PPPoE Connect with IP Address 88.205.xxx.xxx
Jan 2 13:12:57> PPPoE Connection Successfully Established
Jan 2 13:12:57> PPPoE Connect with Gateway IP Address: 195.54.4.9
Jan 2 13:12:57> WAN gateway 195.54.4.9
Jan 2 13:12:57> primary DNS address 195.54.2.1
Jan 2 13:12:57> secondary DNS address 212.57.145.253
Jan 2 13:17:55> Terminated: Modem Hang-Up
Jan 2 13:17:55> Modem hangup
Jan 2 13:17:55> Connection terminated.
Jan 2 13:17:55> pppd 2.4.3 started by root, uid 0
Jan 2 13:17:55> Connect: ppp0 {--} nas0
Jan 2 13:17:57> PAP authentication succeeded
Jan 2 13:17:57> peer from calling number 00:13:5F:5E:90:1B authorized
Jan 2 13:17:57> WAN IP address 88.205.xxx.xxx
Jan 2 13:17:57> PPPoE Connect with IP Address 88.205.xxx.xxx
Jan 2 13:17:57> PPPoE Connection Successfully Established
Jan 2 13:17:57> PPPoE Connect with Gateway IP Address: 195.54.4.9
Jan 2 13:17:57> WAN gateway 195.54.4.9
Jan 2 13:17:57> primary DNS address 195.54.2.1
Jan 2 13:17:57> secondary DNS address 212.57.145.253
... и так далее ...
... т.е. ровно каждые 5 минут соединение падает и вновь поднимается, причин этого провайдер не знает (и найти пока не может), говорит что это наблюдается у многих клиентов и только на модемах D-Link.
Прошивка: V3.02B01T01.RU.20061228 (были и другие, с ними картина та же)
Есть какие нибудь соображения на эту тему ? ... (понятно что проблема провайдера, но он разводит руками, мол ищем ... а воз и ныне там :cry: ) ...
P.S. и ещё, о чём говорит приведённый лог, если "по русски" :) ?
СообщениеДобавлено: Пн фев 26, 2007 15:13
Харрактеристики линии и какая модуляция настроена?
Бигаров Руслан.
СообщениеДобавлено: Пн фев 26, 2007 20:20
ADSL Firmware Version: 5.00.04.00 - 5.00.03.00 - 6.00.04.00 Annex A - 01.07.2b - 0.52
ADSL Software Version: V3.02B01T01.RU.20061228
Line State Connected
Modulation ADSL_2plus
Annex Mode Annex A
Max Tx Power -38 dBm/Hz
Item Downstream Upstream Unit
SNR Margin 6 7 dB
Line Attenuation 18 9 dB
Data Rate 21836 1085 kbps
модуляция была ADSL(Multi-Mode), на 8-ми мегабитах и при снижении до 4-х падения PPPoE так же наблюдались, как и сейчас при ADSL2+(Multi-Mode expert Annex M) ...
СообщениеДобавлено: Вт фев 27, 2007 11:01
1. Сбросьте до заводских настроек.
2. Залейте прошивку.
3. Залейте конфиг файл.
4. Снова сбросьте до заводских настроек.
5. Переконфигурируйте.
Бигаров Руслан.
СообщениеДобавлено: Вт фев 27, 2007 11:09
делал, неоднократно, при смене прошивок, - никакого эффекта, к тому же, как я уже писал ...
... так что это не поможет ... :(
СообщениеДобавлено: Вт фев 27, 2007 11:15
А по контракту у Вас какая скорость!? Т.е. Вы просили снизить скорость на порту DSLAM-а, а Вы просили жёстко задать модуляцию g.dmt или t1.413?
Бигаров Руслан.
СообщениеДобавлено: Вт фев 27, 2007 11:22
- по контракту у меня тарифицируется объём информации, посему скорость пров не режет
- скорость снижали на порту DSLAM-a
- жёстко задать модуляцию g.dmt или t1.413 не просил, а что это даст ?
СообщениеДобавлено: Ср фев 28, 2007 22:50
У меня схожая проблема, только отключения начинаются в 20-22 часа с интервалами 15-20 минут. Если перезагрузить модем, то связь опять становится стабильной, при этом параметры соединения (судя по разделу модема Status/ADSL) остаются такими же, или меняются пренебрежительно мало. Но, ждать, когда начнутся разрывы связи и после этого перезагружать модем - не выход.
Модем - 504T (не перепрашивался)
ADSL Firmware Version: 4.03.03.00 - 3.02.00.03 - 3.02.06.00 Annex A - 01.07.02 - 0.49
ADSL Software Version: V2.01B01T01.RU.20060522
Modulation Multi-mode
Annex Mode ANNEX_A
SNR Margin 15 15 dB
Line Attenuation 11 3 dB
Data Rate 15313 717 kbps
LOG:
Jan 1 12:00:10> Valid Configuration Tree
Jan 1 12:00:10> NTP Polling Timer for DHCP Started succesfully.
Jan 1 12:00:10> DSL Polling Timer Started succesfully.
Jan 1 12:00:10> doing modulation_set.
Jan 1 12:00:11> Firewall NAT service started
Jan 1 12:00:14> starting on port 80
Jan 1 12:00:14> Bridge Created: br0
Jan 1 12:00:15> No Module Description from Interface Below
Jan 1 12:00:15> Bridge Created: br1
Jan 1 12:00:15> Bridge Interface Added: eth0
Jan 1 12:00:16> Bridge Interface Added: nas1
Jan 1 12:00:16> Add Bridge Iface Error: 1
Jan 1 12:00:16> Duplicate Bridge Iface: nas1
Jan 1 12:00:20> DSL Carrier is down
Jan 1 12:00:40> DSL Carrier is up
Jan 1 12:00:41> pppd 2.4.3 started by root, uid 0
Jan 1 12:00:41> Connect: ppp0 {--} nas0
Jan 1 12:00:43> peer from calling number xx:xx:xx:xx:xx:xx authorized
Jan 1 12:00:43> WAN IP address 10.152.xxx.xxx
Jan 1 12:00:43> WAN gateway 10.150.xxx.xxx
Jan 1 12:00:43> PPPoE Connect with IP Address 10.152.xxx.xxx
Jan 1 12:00:43> PPPoE Connection Successfully Established
Jan 1 12:00:43> PPPoE Connect with Gateway IP Address: 10.150.xxx.xxx
Feb 26 21:50:29> DSL Carrier is down
Feb 26 21:50:39> DSL Carrier is training
Feb 26 21:50:59> DSL Carrier is up
Feb 26 21:51:00> PPPD Terminated Through Signal
Feb 26 21:51:00> Connection terminated.
Feb 26 21:51:00> pppd 2.4.3 started by root, uid 0
Feb 26 21:51:00> Connect: ppp0 {--} nas0
Feb 26 21:51:03> peer from calling number xx:xx:xx:xx:xx:xx authorized
Feb 26 21:51:03> WAN IP address 10.152.xxx.xxx
Feb 26 21:51:03> PPPoE Connect with IP Address 10.152.xxx.xxx
Feb 26 21:51:03> PPPoE Connection Successfully Established
Feb 26 21:51:03> PPPoE Connect with Gateway IP Address: 10.150.xxx.xxx
Feb 26 21:51:03> WAN gateway 10.150.xxx.xxx
Feb 26 22:08:09> DSL Carrier is down
Feb 26 22:08:39> DSL Carrier is up
Feb 26 22:08:40> PPPD Terminated Through Signal
Feb 26 22:08:41> Connection terminated.
Feb 26 22:08:41> pppd 2.4.3 started by root, uid 0
Feb 26 22:08:41> Connect: ppp0 {--} nas0
Feb 26 22:08:43> peer from calling number xx:xx:xx:xx:xx:xx authorized
Feb 26 22:08:43> WAN IP address 10.152.xxx.xxx
Feb 26 22:08:43> PPPoE Connect with IP Address 10.152.xxx.xxx
Feb 26 22:08:43> PPPoE Connection Successfully Established
Feb 26 22:08:43> PPPoE Connect with Gateway IP Address: 10.150.xxx.xxx
Feb 26 22:08:43> WAN gateway 10.150.xxx.xxx
Feb 26 22:25:39> DSL Carrier is down
Feb 26 22:26:19> DSL Carrier is up
Feb 26 22:26:20> PPPD Terminated Through Signal
Feb 26 22:26:21> Connection terminated.
Feb 26 22:26:21> pppd 2.4.3 started by root, uid 0
Feb 26 22:26:21> Connect: ppp0 {--} nas0
Feb 26 22:26:23> peer from calling number xx:xx:xx:xx:xx:xx authorized
Feb 26 22:26:23> WAN IP address 10.152.xxx.xxx
Feb 26 22:26:23> PPPoE Connect with IP Address 10.152.xxx.xxx
Feb 26 22:26:23> PPPoE Connection Successfully Established
Feb 26 22:26:23> PPPoE Connect with Gateway IP Address: 10.150.xxx.xxx
Feb 26 22:26:23> WAN gateway 10.150.xxx.xxx
Калужская облать. Провайдер - Домолинк.
СообщениеДобавлено: Пт мар 02, 2007 12:18
Попросите провайдера уменьшить скорость на вашем порту DSLAM-а.
Бигаров Руслан.
СообщениеДобавлено: Пт мар 02, 2007 12:45
Установил в модеме модуляцию G.dmt - разрывы прекратились, downstream ~ 10 Mbit (приемлемо).
Но, с технической точки зрения, каковы возможные причины разрывов только в вечернее время и каким образом однократная перезагрузка модема могла, при этом, восстановить стабильность связи?
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 50
