Текущее время: Ср сен 30, 2026 19:47
 Заголовок сообщения: DSL-504T => DSL Carrier is down/DSL Carrier is up
СообщениеДобавлено: Ср май 17, 2006 14:20
FW:V2.00B01T01.EU.20050630
vcera sdelal update na DSL-504T
s V2.00B01T01.EU.20041229
na V2.00B01T01.EU.20050630
i seicias takie problems:
Jan 1 12:00:10> NTP Polling Timer for DHCP Started succesfully.
Jan 1 12:00:10> DSL Polling Timer Started succesfully.
Jan 1 12:00:11> Firewall NAT service started
Jan 1 12:00:12> starting on port 80
Jan 1 12:00:13> Bridge Created: br0
Jan 1 12:00:14> Bridge Created: br1
Jan 1 12:00:15> Bridge Interface Added: eth0
Jan 1 12:00:20> DSL Carrier is down
Jan 1 12:01:00> DSL Carrier is up
Jan 1 12:05:40> DSL Carrier is down
Jan 1 12:06:20> DSL Carrier is up
Jan 1 12:19:40> DSL Carrier is down
Jan 1 12:20:50> DSL Carrier is up
Jan 1 12:23:30> DSL Carrier is down
Jan 1 12:24:10> DSL Carrier is up
Jan 1 12:27:10> DSL Carrier is down
Jan 1 12:27:50> DSL Carrier is up
Jan 1 12:31:40> DSL Carrier is down
Jan 1 12:32:50> DSL Carrier is up
Jan 1 12:35:20> DSL Carrier is down
Jan 1 12:36:00> DSL Carrier is up
Jan 1 12:41:10> DSL Carrier is down
Jan 1 12:42:00> DSL Carrier is up
Jan 1 12:47:20> DSL Carrier is down
Jan 1 12:48:10> DSL Carrier is up
Jan 1 12:50:00> DSL Carrier is down
Jan 1 12:50:40> DSL Carrier is up
s provaiderom pogovoril smeniti sADSL1 na ADSL2 so staroi prosivcoi bili disconnecti raz v deni nado bilo delati renew IP stobi sviazi vostanovilasi a seicias postoiannie disconnecti.
Podscajite poijalusta v cem problema?
СообщениеДобавлено: Чт май 18, 2006 10:43
Узнайте, какой тип модуляции используется у провайдера и измените его в настройках маршрутизатора Advanced>ADSL.
СообщениеДобавлено: Чт май 18, 2006 20:28
Modulation Type: Multy-mode.
Stranno :? vcera ia proshil do V2.00B01T01.EU.20050930 i seicas DSL-504T disconnectitsia redco:
-lampa ADSL gorit,
-ne pinguit ni odin IP address external
-i log ne registriruet deistvia disconnecta:
Jan 1 12:00:10> doing modulation_set.
Jan 1 12:00:16> Bridge Interface Added: eth0
Jan 1 12:00:20> DSL Carrier is down *- pri starte uje bilo
Jan 1 12:00:40> DSL Carrier is up *- pri starte uje bilo
prihoditsia najimati "Save and Reboot".
Provider toje menia ne vidit v seti poka ia REBOOT ne delaiu. Mojet ctoto ne v poriadke s DSL-504T?
Pomoghite pojaluista. mojet escio na kakieto nuansi nado obratiti vnimanie.
Zaranee blagodaren
СообщениеДобавлено: Пт май 19, 2006 09:10
В каком режиме настроен DSL-504T? Static IP, Dynamic IP, Bridge, PPPoE?
СообщениеДобавлено: Пт май 19, 2006 09:11
-lampa ADSL gorit,
Zaranee blagodaren
С ADSL все в порядке сейчас. Вы как настраиваете DSL-504T? И какие настройки использует провайдер?
СообщениеДобавлено: Пт май 19, 2006 14:54
И не плохо было бы посмотреть величину затухания сигнала в линии.
СообщениеДобавлено: Пт май 19, 2006 19:24
Зачем смотреть затухание если АДСЛ держиться и не отваливается?
Изображение DSL 504T [VX.XXXXXXXX.RU.XXXXXXXX]
СообщениеДобавлено: Пт май 19, 2006 19:25
n0taz писал(а):
Зачем смотреть затухание если АДСЛ держится и не отваливается?
СообщениеДобавлено: Пт май 19, 2006 23:35
pereproveril s provaiderom nastroiki:
ATM VC Setting
- PVC: Pvc0
- VPI: 0
- VCI: 35
- Virtual Circuit: Enabled
- WAN Setting: Dynamic IP Address
- Dynamic IP Connection Type: 1483 Bridged IP LLC
- MTU: 1400 bytes
- NAT: Enabled
- Firewall: Disabled
- ATM Service Category: UBR
- No DHCP *-vse v TCP/IP properties
- DNS Selection: Use Auto Discover DNS Server Only
- DDNS Server: Disable
- IGMP Proxy: Disable
s signalom u menia vrode vse v poriadke:
ADSL Status
- ADSL Firmware Version: 4.03.03.00 - 3.02.00.03 - 3.02.06.00 Annex A - 01.07.02 - 0.49
- ADSL Software Version: V2.00B01T01.EU.20050930
- Line State: Connected
- Modulation: Multi-mode
- Annex Mode: ANNEX_A
- Max Tx Power: -38 dBm/Hz
- SNR Margin 16/6 dB (down/up)*-inogda SNR downstream variiruet mejdu 11 i 24
- Line Attenuation 10/4 dB (down/up)
- Data Rate: 12014/1207 kbps (down/up)
Segodnia zavis tolico odin raz. Modem i computer videat drug druga no sviazi s netom vsetaki propadaet.
СообщениеДобавлено: Сб май 20, 2006 11:32
Вот у меня такой вопрос:
Cкорость U/D 256/512
Параметры линии, выдаются 504-ым
Connection Status Connected
Upstream Rate (Kbps) 256
Downstream Rate (Kbps) 512
US Margin 31
DS Margin 31
Modulation MMODE
LOS Errors 0
DS Line Attenuation 23
US Line Attenuation 16
Path Mode Fast Path
Имеет ли смысл попробовать тариф с большей скоростью при такой линии? Могут ли быть проблемы с устойчивостью?
СообщениеДобавлено: Сб май 20, 2006 16:02
vadimcreates
Если параметры варьируются от 11 до 24 - то это плохо. На лицо нестабильность в линии. Если происходит резкий скачек параметров - то велика вероятность того, что случиться обрыв АДСЛ.
СообщениеДобавлено: Пн май 22, 2006 10:54
V posleduiuscem savisanii DSL-504T ia srazu pozvonil provideru ctobi on menia opiati proveril. V rezultate modem sincronizovan s DSLAM a ping ne idet. Tolico posle reboota vse vostonovlenno.
Esli sprosite menia nagrevaitsia li marsrutizator to otvet net i bloc pitania eli teplii.
Zavisit li eto ot prosivki? Pomoghite kto znaet :(
n0taz, vi pravi na scet obriva ADSL. Ia nabliudal v "Stasus->ADSL" SNR Downstream skakival s 16 do 5 i obratno i Line Attenuation podnimalsia s 10 do 33 i obratno. No :!: v etom sluciae v loge ia takje vidil potverjdenie obriva "DSL Carrier is down" i vostanovlenie. A samoe interentnoe to, cto posle perezagruzke modema linia stanovilasi neveroiatno ustoiciva SNR DS 19 i Line Attenuation DS 10 decibel. I derjitsia stabilinoi pocti 24 ciasa. Kak togda mojno obiasniti eto :?:
kak ia viju poiavilasi vtoraia problema.
СообщениеДобавлено: Ср май 31, 2006 22:46
Provider uveriaet menia cto eti problemi s liniei ili s naprijeniem. Veriti li mne emu??? Kak eto mojno proveriti :?:
СообщениеДобавлено: Чт июн 01, 2006 04:25
объяснить можно просто - шумы на линии, модем ищет способ держать коннект, находит его и держит. надо устранять эти шумы. скорее всего проблема в кабеле (т.е. вызывать телефониста и пинать его ногами)
СообщениеДобавлено: Чт июн 01, 2006 11:50
Spasibo, budem probivati :lol:
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 61
