Текущее время: Ср сен 30, 2026 23:01
 Заголовок сообщения: D-Link 500T problems
СообщениеДобавлено: Вт май 30, 2006 23:48
Раньше все было нормально, но вот последние два дня постоянно начались обрывы связи.. Причем происходит это постоянно, через каждые 3-5 минут, бывает что после обрыва долго нет коннекта. Прошивка была стандартная, обновил, но все теже проблемы. Бывало не падало около 3 часов (было пару раз за 2 дня) и потом снова начиналось. Вот логи
Sep  8 12:00:06> Valid Configuration Tree
Sep  8 12:00:11> Firewall NAT service started
Sep  8 12:00:12> Bridge Created: br0
Sep  8 12:00:12> Bridge Interface Added: eth0
Sep  8 12:00:13> pppd 2.4.1 started by root, uid 0
Sep  8 12:00:15> DSL Carrier is up
Sep  8 12:00:23> Connecting PPPoE socket: 00:0d:66:02:00:1b f96d nas0 0x1000d3b8
Sep  8 12:00:23> Connect: ppp0 {--} nas0
Sep  8 12:00:25> WAN IP address 82.207.32.15
Sep  8 12:00:26> WAN gateway 195.5.5.19
Sep  8 12:00:26> primary   DNS address 195.5.51.178
Sep  8 12:00:26> secondary DNS address 82.207.67.2
Sep  8 12:00:26> PPPoE Connect with IP Address 82.207.32.15
Sep  8 12:00:26> PPPoE Connection Successfully Established
Sep  8 12:00:26> PPPoE Connect with Gateway IP Address: 195.5.5.19
Sep  8 12:01:05> DSL Carrier is training
Sep  8 12:01:15> DSL Carrier is up
Sep  8 12:01:21> Connection terminated.
Sep  8 12:01:21> Doing disconnect
Sep  8 12:01:21> pppd 2.4.1 started by root, uid 0
Sep  8 12:01:21> Connecting PPPoE socket: 00:0d:66:02:00:1b 0d6e nas0 0x1000d3b8
Sep  8 12:01:21> Connect: ppp0 {--} nas0
Sep  8 12:01:45> DSL Carrier is training
Sep  8 12:01:55> DSL Carrier is up
Sep  8 12:02:28> Connection terminated.
Sep  8 12:02:30> Doing disconnect
Sep  8 12:02:30> pppd 2.4.1 started by root, uid 0
Sep  8 12:02:35> DSL Carrier is down
Sep  8 12:02:45> DSL Carrier is up
Sep  8 12:03:07> DSL Carrier is training
Sep  8 12:03:08> pppd 2.4.1 started by root, uid 0
Sep  8 12:03:15> DSL Carrier is up
Sep  8 12:03:18> Connecting PPPoE socket: 00:0d:66:02:00:1b 356e nas0 0x1000d3b8
Sep  8 12:03:18> Connect: ppp0 {--} nas0
Sep  8 12:03:34> PAP authentication failed
Sep  8 12:03:34> Modem hangup
Sep  8 12:03:34> Connection terminated.
Sep  8 12:03:34> Doing disconnect
Sep  8 12:03:34> Terminated: Modem Hang-Up
Sep  8 12:03:39> pppd 2.4.1 started by root, uid 0
Sep  8 12:03:39> Connecting PPPoE socket: 00:0d:66:02:00:1b 3e6e nas0 0x1000d3b8
Sep  8 12:03:39> Connect: ppp0 {--} nas0
Sep  8 12:03:41> WAN IP address 82.207.34.145
Sep  8 12:03:41> PPPoE Connect with IP Address 82.207.34.145
Sep  8 12:03:41> WAN gateway 195.5.5.19
Sep  8 12:03:41> PPPoE Connection Successfully Established
Sep  8 12:03:41> PPPoE Connect with Gateway IP Address: 195.5.5.19
Sep  8 12:03:41> primary   DNS address 195.5.51.178
Sep  8 12:03:41> secondary DNS address 82.207.67.2
Sep  8 12:04:45> DSL Carrier is training
Sep  8 12:04:55> DSL Carrier is up
Sep  8 12:05:05> DSL Carrier is training
Sep  8 12:05:06> Connection terminated.
Sep  8 12:05:06> Doing disconnect
Sep  8 12:05:06> pppd 2.4.1 started by root, uid 0
Sep  8 12:05:15> DSL Carrier is up
Sep  8 12:05:42> pppd 2.4.1 started by root, uid 0
Sep  8 12:05:42> Connecting PPPoE socket: 00:0d:66:02:00:1b 726e nas0 0x1000d3b8
Sep  8 12:05:42> Connect: ppp0 {--} nas0
Sep  8 12:05:44> WAN IP address 82.207.34.145
Sep  8 12:05:44> PPPoE Connect with IP Address 82.207.34.145
Sep  8 12:05:44> WAN gateway 195.5.5.19
Sep  8 12:05:44> PPPoE Connection Successfully Established
Sep  8 12:05:44> PPPoE Connect with Gateway IP Address: 195.5.5.19
Sep  8 12:05:44> primary   DNS address 195.5.51.178
Sep  8 12:05:44> secondary DNS address 82.207.67.2
May 31 04:32:52> DSL Carrier is training
May 31 04:33:02> DSL Carrier is up
May 31 04:33:08> Connection terminated.
May 31 04:33:08> Doing disconnect
May 31 04:33:08> pppd 2.4.1 started by root, uid 0
May 31 04:33:08> Connecting PPPoE socket: 00:0d:66:02:00:1b d86e nas0 0x1000d3b8
May 31 04:33:08> Connect: ppp0 {--} nas0
May 31 04:33:11> WAN IP address 82.207.34.145
May 31 04:33:11> PPPoE Connect with IP Address 82.207.34.145
May 31 04:33:11> WAN gateway 195.5.5.19
May 31 04:33:11> PPPoE Connection Successfully Established
May 31 04:33:11> PPPoE Connect with Gateway IP Address: 195.5.5.19
May 31 04:33:11> primary   DNS address 195.5.51.178
May 31 04:33:11> secondary DNS address 82.207.67.2
May 31 04:39:32> DSL Carrier is training
May 31 04:39:42> DSL Carrier is up
May 31 04:39:44> Connection terminated.
May 31 04:39:44> Doing disconnect
Также вот DSL статус модема
DSL Status
  Connection Status Connected
  Upstream Rate (Kbps) 640
  Downstream Rate (Kbps) 2464
  US Margin 6
  DS Margin 8
  Modulation GDMT
  LOS Errors 0
  DS Line Attenuation 30
  US Line Attenuation 35
  Path Mode Interleaved
Звонил в тех. поддержку провайдера, говорят что линия идеальная и все должно быть нормально..
Но инет падает постоянно, что вы можете об этом сказать?
СообщениеДобавлено: Ср май 31, 2006 09:20
Тип модуляции совпадает с тем, что выставлено у провайдера?
СообщениеДобавлено: Ср май 31, 2006 09:53
Всегда стояла модуляция G.Dmt и стоит сейчас... Раньше всегда было все окей, пробовал другие типы не помогает.
СообщениеДобавлено: Ср май 31, 2006 09:58
Версия прошивки?
СообщениеДобавлено: Ср май 31, 2006 10:06
На данный момент
Software Version V1.00B02T02.RU.20050223
Вот сейчас некоторое время (уже минут 15 инет не выкидывает).. Вчера вечером еще кидало, встал утром - в логах куча сообщений Carrier is down и т.д. Перегрузил модем, пока работает, незнаю надолго ли
СообщениеДобавлено: Ср май 31, 2006 11:26
Обновите прошивку на эту: ftp://dlink.ru/pub/ADSL/DSL-500T/Firmwa ... adeB05.exe
а после чего на эту: ftp://dlink.ru/pub/ADSL/DSL-500T/Firmwa ... 060522.zip
Инструкция по перепрошивке: ftp://dlink.ru/pub/ADSL/DSL-500T/Firmwa ... l_ver3.pdf
СообщениеДобавлено: Ср май 31, 2006 16:45
DSL Status
US Margin 6
DS Margin 8
Modulation GDMT
LOS Errors 0
Имхо с такими марджинами и затуханиями прошивка не поможет, проверяйте линию или просите провайдера понизить скорость.
Изображение DSL 504T [VX.XXXXXXXX.RU.XXXXXXXX]
СообщениеДобавлено: Ср май 31, 2006 21:06
Не помогло... все тоже((((
СообщениеДобавлено: Ср май 31, 2006 21:41
n0taz писал(а):
DSL Status
Говорят что состояние линии в порядке
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 56
