Текущее время: Вт окт 27, 2026 02:18
 Заголовок сообщения: DG - 104SH -> NSG (Nateks) 4FXO
СообщениеДобавлено: Пт янв 09, 2004 15:36
Проблема такая,
DG - 104SH -> NSG (Nateks) 4FXO -> офисная АТС
в этом случае на стороне NSG (Nateks) 4FXO
есть вызов, а в трубке тишина.
Судя повсему непроключается логический канал
ниже версии прошивок, и дебаги
_____________________________________
со стороны DG - 104SH
ggdbg>show version
PROM Version Label: 1.0B13-G
TSG Version: V1.0 H.323 VoIP Gateway
CM Version Label: 1.0B42-G
TBD-TBD, H323 Build, 100 Ticks/Sec Clock
4 Voice TCIDS, 0 Data TCIDS
ggdbg>spy HSMU 0
ggdbg>002342954 HSMU: Enter call_profile->capabilities
002342954 HSMU: Coding Profile Bit 6 ignored, no 'voice' usage.
002342954 HSMU: Exit call_profile->capabilities.
002342954 HSMU 5: Process outgoing H.323 Fast Start call.
002342954 Dialing DEST = TA:217.107.47.21:1720,TEL:123
002342961 SOURCE = NAME:xxxxx|123456,TEL:201
002342961 USER_TO_USER = CID_NAME:201, CID_NUM:201 SETUP
002342961 hsmup_open_rtp_sockets: nw_open(RTP4), port=30010, call_num=5
002342961 hsmup_open_rtp_sockets: nw_open(RTCP9), call_num=5, port=30011
002342961 HSMU 5: set timer for 50000 in state hsmup_state_h225_wait_alerting
002343022 HSMU 5: abort timer in state hsmup_state_h225_wait_alerting
002343022 HSMU 5: Product ID = "4FXO"
002343022 HSMU 5: Version ID = "117"
002343022 HSMU 5: Starting Capabilities Exchange, capabilities_send=0
002343023 HSMU 5: Sending local capabilities.
002343023 HSMU 5: set timer for 30000 in state hsmup_state_h245_wait_complete
002343023 HSMU 5: cmControlStateFastStart
002343023 HSMU 5: SM Unexpected event "CALL_FAST_START_SETUP" in "hsmup_state_h245_wait_complete" state
002343023 HSMU 5: Chan 0o cmEvChannelSetRTCPAddress_msg IP = 217.107.47.21, Port = 22679
002343023 HSMU 5: Chan 0o cmEvChannelSetAddress_msg IP = 217.107.47.21, Port = 22678
002343023 HSMU 5: Chan 0o - cmChannelStateConnected "g729AnnexA"
local RTCP = 0, remote RTCP =22679, RTP = 217.107.47.21:22678
002343023 HSMU 5: SM Unexpected event "LC_CONNECTED" in "hsmup_state_h245_wait_complete" state
002343023 HSMU 5: Chan 0i cmEvChannelSetRTCPAddress_msg IP = 217.107.47.21, Port = 22679
002343023 HSMU 5: Chan 0i - cmChannelStateConnected "g729AnnexA"
local RTCP = 0, remote RTCP =22679, RTP = 0.0.0.0:0
002343661 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
002344323 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
002344647 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
002345211 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
002345619 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
002345993 HSMU 5: SM Unexpected event "LC_DISCONNECTED" in "hsmup_state_h245_wait_complete" state
002345993 HSMU 5: abort timer in state hsmup_state_h245_wait_complete
002345993 HSMU 5: H.323 release (IF)
002346045 HSMU 5: voice rtp open=1, rtcp open=1, nw_close(voice socked RTP4, RTCP9)
002346045 HSMU 5: nw_close(inchan local RTCP65535, RTP65535)
002346045 HSMU 5: nw_close(outchan local RTCP65535)
со стороны NSG (Nateks) 4FXO
usr/config$ rom -print
Download Method : TFTP
Hardware Ver. : 1.0
Boot Rom : boot.104
Application Rom : 4fxo.117
DSP App : 48302ce3.140
DSP Kernel : 48302ck.140
DSP Test Code : 483cbit.bin
Ringback Tone : ringbacktone.100
Hold Tone : holdtone.101
Greetings : greatrd.wav
Askpin : pincode.100
usr/config$
usr/config$ ~~~~~~ registrationRequest
cmEvNewCall(hsCall=7058860) runs
Set Tunnelling TRUE.
*-*-*-*-*-* Enter SSE section
*-*-*-*-*-* SSE section completed!
~~~~~~ admissionRequest
0-cmControlStateFastStart
Enter EvChannelNew..6acfc4
call0 hsChanIn-cmEvChannelNew Send
cmEvChannelParameters hsChannel: 6acfc4 channeName = g729AnnexA
incoming channel codec: g729AnnexA
cmEvChannelSetRTCPAddress hsChan = 6acfc4
RTCP call: 0, channel: 0
call0 ch0-ChannelState: Connected
Enter EvChannelNew..6ad15c
call0 hsChanIn2-cmEvChannelNew Send
cmEvChannelParameters hsChannel: 6ad15c channeName = g729AnnexA
cmEvChannelSetRTCPAddress hsChan = 6ad15c
RTCP call: 0, channel: 2
cmEvChannelSetAddress hsChan = 6ad15c
call0 ch1-217.107.47.21: 22676-cmEvChannelSetAddress
cmEvCallStateChanged(state=cmCallStateOffering, statemode=cmCallStateModeOfferingCreate)
0-Offering-cmEvCallStateChanged
cmEvCallStateChanged(state=cmCallStateConnected, statemode=cmCallStateModeConnectedCallSetup)
0-Connected-cmEvCallStateChanged
Callee----->
fs_flag[0]=1
------statemode: ConnectedCallSetup------
0-Enter openDeviceChannel
H323ap select codec g729AnnexA
H323ap select codec g729AnnexA, TxM=2 echo=1
After connect, h245 connect
dial out .... <1>
dial out .... <2>
dial out .... <3>
call0 ch0-ChannelState: Disconnected
call0 ch0-ChannelState: Idle
cmEvCallStateChanged(state=cmCallStateDisconnected, statemode=cmCallStateModeDisconnectedLocal)
0-Disconnected-cmEvCallStateChanged reason = -1
~~~~~~ disengageRequest
cmEvCallStateChanged(state=cmCallStateIdle, statemode=cmCallStateModeDisconnectedBusy)
СообщениеДобавлено: Пт янв 09, 2004 15:53
А если без fast-start?
С уважением, Дмитрий Письменов
СообщениеДобавлено: Чт янв 29, 2004 07:54
проблема решилась после прошивки новой версии
ggdbg>show version
PROM Version Label: 1.0B20-G
CM Version Label: 1.0B53-G
System has FLASH
TIU Continuous Polling (1)
