Текущее время: Вт окт 27, 2026 00:17
 Заголовок сообщения: Звонки с 102SH на Cisco
СообщениеДобавлено: Чт дек 18, 2003 18:39
Че-го то я не понимаю...
Есть DG-102SH + AquaGK
Звоню на свою cisco2640 ios 12.2(19) - все замечательно проходит.
Вот лог этого звонка по sys 31 0
ggdbg>000522348 HSMU: Enter call_profile->capabilities
000522348 HSMU: Coding Profile Bit 6 ignored, no 'voice' usage.
000522348 HSMU: Exit call_profile->capabilities.
000522348 HSMU 5: Process outgoing H.323 call.
000522348 Dialing DEST = TEL:70000111111 (using GateKeeper)
000522348 SOURCE = NAME:DLINK
000522348 USER_TO_USER = SETUP
000522348 HSMU 5: set timer for 50000 in state hsmup_state_h225_wait_alerting
000522449 HSMU 5: Starting Capabilities Exchange, capabilities_send=0
000522449 HSMU 5: Sending local capabilities.
000522449 HSMU: h323_get_static_cap_name capability name "nonStandard"
000522449 HSMU: h323_get_static_cap_name NOT FOUND!
000522449 HSMU: Invalid capability name "hookflash"
000522449 HSMU: Invalid capability name "dtmf"
000522449 HSMU: Invalid capability name "basicString"
000522449 HSMU: h323_get_static_cap_name capability name "g729AnnexA"
000522449 HSMU: h323_get_static_cap_name capability name "g729"
000522450 HSMU: h323_get_static_cap_name capability name "g729wAnnexB"
000522450 HSMU: h323_get_static_cap_name capability name "g729AnnexAwAnnexB"
000522450 HSMU: h323_get_static_cap_name capability name "g7231"
000522450 HSMU: h323_get_static_cap_name capability name "g711Alaw64k"
000522450
000522450 Capability Set
000522450 H245 Address in Alerting, ip=0xd51856c1, port=3819
000522450 HSMU 5: Starting Capabilities Exchange, capabilities_send=1
000522450 HSMU 5: No product Id info
000522450 HSMU 5: No version Id info
000522450 HSMU 5: abort timer in state hsmup_state_h225_wait_alerting
000522450 HSMU 5: set timer for 30000 in state hsmup_state_h245_wait_complete
000522450 Local capability codec "g729AnnexA".
000522450 Remote capability codec "nonStandard".
000522450 Remote capability codec "UnknownCapability".
000522450 Remote capability codec "g729AnnexA".
000522450 Match found for codec "g729AnnexA".
000522450 HSMU 5: Capabilities match found for "g729AnnexA"
000522450 HSMU 5: CapabilitiesExt_msg
000522470 HSMU 5: cmEvCallMasterSlaveStatus_msg: Local station is Master
000522470 HSMU 5: cmControlStateConnected, p_call->fast_start_on=0
000522470 HSMU 5: abort timer in state hsmup_state_h245_wait_complete
000522470 HSMU 5: Chan 0o - hsmup_open_channel() codec = "g729AnnexA", p_assoc_c
han=0x0
000522470 hsmup_open_channel: nw_open(RTCP2), call_num=5 , port=30011, chan_num(
i/o)=0o
000522471 HSMU 5: set timer for 10000 in state hsmup_state_master_wait_connect_a
ll_lc
000522471 HSMU 5: Chan 0i cmEvChannelSetRTCPAddress_msg IP = 192.168.0.193, Port
= 1055
000522471 HSMU 5: Chan 0i - master offering channel "g729"
000522471 HSMU 5: selected codec name=g729AnnexA, selected profile=5, master
000522471 hsmup_master_incoming_lc: nw_open(RTP1), call_num=5 , port=30010, chan
_num(i/o)=0i
000522471 HSMU 5: Chan 0i: Opened RTP socket = 1, port = 30010
000522471 HSMU 5: Chan 0i - cmChannelStateConnected "g729AnnexA"
local RTCP = 30011, remote RTCP =1055, RTP = 192.168.0.203:30010
000522471 HSMU 5: Chan 0o cmEvChannelSetRTCPAddress_msg IP = 192.168.0.193, Port
= 1057
000522471 HSMU 5: Chan 0o cmEvChannelSetAddress_msg IP = 192.168.0.193, Port = 1
056
000522471 HSMU 5: Chan 0o - cmChannelStateConnected ""
local RTCP = 30011, remote RTCP =1057, RTP = 192.168.0.193:1056
000522471 HSMU 5: abort timer in state hsmup_state_master_wait_connect_all_lc
000522471 HSMU 5: VOICE CONNECTED, coding=g729AnnexA, mode=Master
000522471 HSMU 5: set timer for 180000 in state hsmup_state_voice_connected
000522670 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000522944 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000523398 HSMU 5: abort timer in state hsmup_state_voice_connected
000523398 HSMU 5: Master OpenLogicalChannel "g729AnnexA"
000523398 HSMU 5: Chan 1o - hsmup_open_channel() codec = "g729AnnexA", p_assoc_c
han=0x0
000523398 hsmup_open_channel: nw_open(RTCP3), call_num=5 , port=30011, chan_num(
i/o)=1o
000523398 HSMU 5: set timer for 10000 in state hsmup_state_fax_channel
000523398 HSMU 5: Chan 1o cmEvChannelSetRTCPAddress_msg IP = 192.168.0.193, Port
= 1061
000523398 HSMU 5: Chan 1o cmEvChannelSetAddress_msg IP = 192.168.0.193, Port = 1
060
000523398 HSMU 5: Chan 1o - cmChannelStateConnected ""
local RTCP = 30011, remote RTCP =1061, RTP = 192.168.0.193:1060
000523429 HSMU 5: abort timer in state hsmup_state_fax_channel
000523429 HSMU 5: cmCallDropParam(p_call=0x41c812, h323_release_reason=11)
000523674 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000524077 HSMU RX RTCP
Звоню через GK партнера (не знаю, что там стоит) - звонок телефона раздается, а при снятии струбки тишина в обе стороны, а потом короткие гудки :(
В принципе партнер согласен подкрутить настройки своей кошки или GK. Токо надо ему сказать, что крутить надо.
ggdbg>000518360 HSMU: Enter call_profile->capabilities
000518360 HSMU: Coding Profile Bit 6 ignored, no 'voice' usage.
000518360 HSMU: Exit call_profile->capabilities.
000518360 HSMU 4: Process outgoing H.323 call.
000518360 Dialing DEST = TEL:70000111111 (using GateKeeper)
000518360 SOURCE = NAME:DLINK
000518360 USER_TO_USER = SETUP
000518360 HSMU 4: set timer for 50000 in state hsmup_state_h225_wait_alerting
000518475 H245 Address in Alerting, ip=0xd51856c1, port=3814
000518475 HSMU 4: Starting Capabilities Exchange, capabilities_send=0
000518475 HSMU 4: Sending local capabilities.
000518475 HSMU 4: No product Id info
000518475 HSMU 4: No version Id info
000518475 HSMU 4: abort timer in state hsmup_state_h225_wait_alerting
000518475 HSMU 4: Starting Capabilities Exchange, capabilities_send=1
000518475 HSMU 4: set timer for 30000 in state hsmup_state_h245_wait_complete
000518499 HSMU 4: cmEvCallMasterSlaveStatus_msg: Local station is Slave
000519358 HSMU 4: abort timer in state hsmup_state_h245_wait_complete
000519358 HSMU 4: cmCallDropParam(p_call=0x41b800, h323_release_reason=11)
000519410 HSMU 4: voice rtp open=0, rtcp open=0, nw_close(voice socked RTP0, RTC
P0)
000519410 HSMU 4: nw_close(inchan local RTCP65535, RTP65535)
000519410 HSMU 4: nw_close(outchan local RTCP65535)
