Текущее время: Вт окт 27, 2026 06:05
СообщениеДобавлено: Пн дек 06, 2004 18:34
Собственно сабж. Помогите плиз.
Настройка DVG-1104TH:
System information
    Gateway Service: 2
    Inter-Digit time out        : 5
    End of Dial                 :  [ # ] button
    Port status:
        port1: Enabled
        port2: Enabled
        port3: Enabled
        port4: Enabled
    DTMF selection              : H.245 SignalT
    Line seizure mode: None
    2nddial:  On
    Dial Rule
         outgoing call:(Call from PSTN)
         filter: []   drop: []   insert: [].
         incoming call:(Call from IP)
    PIN prompt: 0
         set1: 1111
         set2: 2222
         set3: 3333
         set4: 4444
    Ring Detect Method: 1
    Ring before Answer: 3
    FAX redundancy depth: 0
    Caller ID Detect: disable
Настройку DG-104SH:
Configuration for coding profile id 1:
Tx Coding = G.711 MU
Rx Coding = G.711 MU
Coding profile for voice
Tx VIF size = 1280 (bits)
Rx VIF size = 1280 (bits)
VAD = Enabled
VAD threshold = Adaptive VAD
Playout nominal delay = 60 (msec)
Playout maximum delay = 120 (msec)
Playout minimum delay = 0 (msec)
Adaptive Playout = Adjust immediately
Rate = 14400
DTMF Relay = Disabled
Tone detect = Enabled
Call Progress Tone detect = Disabled
V.18 Tone detect = Disabled
SS7 COT Tone detect = Disabled
SF Sig Tone detect = Disabled
EC = Enabled
EC NL = Enabled
EC NL Sens = 327
EC Tail = 8 (msec)
EC Refresh = Update
EC Coeffs = Normal
EC Auto Update = Disabled
EC Auto Search = Disabled
EC Search Freeze = Disabled
Modem TX level = 0 (dB)
Modem CD threshold = 0
Modem no activity timeout = 0 (sec)
Caller ID Support = Enabled
Resampling = Disabled
EC Config = NLP_FIXED
NLP Confort Noise = 65486
SID Retx Rate = 0
Encapsulation = RTP
Tx ssrc = 0
Tx start timestamp = 0
Rx ssrc = 0
Rx start timestamp = 0
Tx digit payload = 0
Rx digit payload = 0
Digit repetitions = 3
Secondary Decoder = Disabled
СообщениеДобавлено: Ср дек 08, 2004 11:45
Модератор
Модератор
System information
    Gateway Service: 2
    Port status:
        port1: Enabled
        port2: Enabled
        port3: Enabled
        port4: Enabled
    2nddial:  On
    Dial Rule
    PIN prompt: 0
         set1: 1111
         set2: 2222
         set3: 3333
         set4: 4444
Настройку DG-104SH:
VAD = Enabled
Rate = 14400
EC = Enabled
EC NL = Enabled
EC NL Sens = 327
EC Tail = 8 (msec)
EC Refresh = Update
EC Coeffs = Normal
SID Retx Rate = 0
Encapsulation = RTP
Tx ssrc = 0
Rx ssrc = 0
Выполните на 1104
sysconf -keypad 0
commit
reboot
Виктор Колосов
СообщениеДобавлено: Чт дек 09, 2004 15:11
теперь проблема в другом ...
при входящем звонке на 1104 он перекидывает на 104, а на 104 звонит телефон ... при поднятие трубки - сигнал занято ...
пробовал разные телефоны ... по всякому ... как это исправить ?
И при звонке с 104 во вне, с любого порта, он всегда звонит от первого порта 1104 ...
Если сделать с двух телефонов одновременно, то второй телефон слышит, что происходит на линии с первым ...
СообщениеДобавлено: Чт дек 09, 2004 15:14
Модератор
Модератор
Версии прошивок на устройствах?
Виктор Колосов
СообщениеДобавлено: Чт дек 09, 2004 15:24
как посмотреть ?
СообщениеДобавлено: Чт дек 09, 2004 16:02
Модератор
Модератор
Kartuz писал(а):
как посмотреть ?
1104 rom -print
102 show version
Виктор Колосов
СообщениеДобавлено: Чт дек 09, 2004 16:26
1104
Download Method : TFTP
Hardware Ver. : A1
Boot Rom : boot.104
Application Rom : 1.bin
DSP App : 48302ce3.140
DSP Kernel : 48302ck.140
DSP Test Code : 483cbit.bin
Ringback Tone : ringbacktone.100
Hold Tone : holdtone.101
Greetings : greeting.101
Askpin : pincode.100
104
Boot PROM Version 1.0B20-G
Firmware Version 1.0B58-G
СообщениеДобавлено: Чт дек 09, 2004 16:27
доступа по телнету к 104 нету ...
СообщениеДобавлено: Чт дек 09, 2004 16:30
Модератор
Модератор
Обновите 1104 согласно http://www.dlink.ru/phorum/viewtopic.php?t=3589
и настройте все заново
Виктор Колосов
СообщениеДобавлено: Чт дек 09, 2004 16:46
у меня эта версия прошивки и стоит ...
СообщениеДобавлено: Чт дек 09, 2004 16:47
которая здесь лежит
ftp://ftp.dlink.ru/pub/VoIP/DVG-1104TH/Firmware/
СообщениеДобавлено: Чт дек 09, 2004 16:49
Модератор
Модератор
Kartuz писал(а):
которая здесь лежит
Вышлите мне все настройки на почту
Виктор Колосов
СообщениеДобавлено: Чт дек 09, 2004 17:10
написал, на мыло указанное в профайле ...
