Текущее время: Вт окт 27, 2026 04:29
СообщениеДобавлено: Чт ноя 27, 2003 12:21
Есть устройство:
PROM Version Label: 1.0B19-G
TSG Version: V1.0 H.323 VoIP Gateway
CM Version Label: 1.0B52-G
TBD-TBD, H323 Build, 100 Ticks/Sec Clock
4 Voice TCIDS, 0 Data TCIDS
System has FLASH
TIU Continuous Polling (1)
DSP Configuration:
DSPs = 1
Channels per DSP = 4
HPI Mapping = 2 (FIFO)
Clock Mult = 4
Fsx Fsr = 32
Pwr Dn Tmr Period = 5000
Wake Up Int Mask = 0
HW Companding = 1
Serial Port Config = 0
Sync Int Config = 1
Clock Out Config = 1
Hint Control = 0x0
BDX Delay Control = 0
HW Gain Control = 0
PktIsr TS Offset = 0
Sample Freq (IPP) = 0
Serial Port Type = 1
Analog Codec Type = 1
Hpi Fifo Size = 894
Вяжется с ней CISCO 2621XM с c2600-adventerprisek9-mz.123-4.XD Сначала обрывалась связь каждые 10 секунд.
ПОСЛЕ
h245 caps mode restricted
h245 tunnel disable
Звонок на 104SH проходит, но при снятии трубки аппарата обрывается :(
Естественно после no h245 caps mode restricted всё возвращается как было....
Вот что spy кажет
ggdbg>006282903 HSMU 3: hsmup_cmEvCallFastStartSetup_api: Search for FS capabili
ty.
006282903 HSMU: partnerChannelsNum = 1.
006282903 HSMU: == Channel 0
006282903 HSMU: type cmCapAudio
006282903 HSMU: transmit alt channels number = 1.
006282903 HSMU: transmit ch 0: g7231.
006282903 HSMU: receive alt channels number = 1.
006282903 HSMU: receive ch 0: g7231.
006282903 HSMU: Fast Start symmetric channels:
006282903 HSMU: 0: g7231
006282903 HSMU: h323_get_static_cap_name capability name "g7231"
006282903 HSMU 3: CallingPartyId = "TA:192.168.2.2:11019"
006282903 HSMU 3: UserUserInfo = "TA:192.168.2.2:11019"
006282903 HSMU 3: remote CID number:"O", name:"O"
006282903 HSMU 3: received H323 Fast Start call, processing ...
006282915 HSMU: Enter call_profile->capabilities
006282915 HSMU: Coding Profile Bit 6 ignored, no 'voice' usage.
006282915 HSMU: Exit call_profile->capabilities.
006282915 HSMU 3: Fast start compatibility check.
006282916 HSMU 3: Match found for g7231 (local = 2, offered = 0)
006282916 HSMU 3: selected fast start channel "g7231".
006282916 HSMU 3: cmControlStateFastStart
006282916 HSMU 3: Chan 0i cmEvChannelSetRTCPAddress_msg IP = 192.168.2.2, Port =
18083
006282916 HSMU 3: Chan 0i - cmChannelStateConnected "g7231"
local RTCP = 0, remote RTCP =18083, RTP = 0.0.0.0:0
006282916 hsmup_fast_start_incoming_lc: nw_open(RTP2), call_num=3, port=0, Chan_
num(i/o)=30006i
006282916 HSMU 3: Chan 0i: Opened RTP socket = 2, cmChannel = 30006
006282916 hsmup_fast_start_incoming_lc: nw_open(RTCP3), call_num=3, port=30007,
chan_num(i/o)=0i
006282916 HSMU 3: Chan 0i: Opened RTCP socket = 3, port 30007
006282916 HSMU 3: Chan 0o cmEvChannelSetRTCPAddress_msg IP = 192.168.2.2, Port =
18083
006282916 HSMU 3: Chan 0o cmEvChannelSetAddress_msg IP = 192.168.2.2, Port = 180
82
006282916 HSMU 3: Chan 0o - cmChannelStateConnected "g7231"
local RTCP = 0, remote RTCP =18083, RTP = 192.168.2.2:18082
006282916 HSMU 3: VOICE CONNECTED, coding=g7231, FAST START mode, terminating
006282916 HSMU 3: set timer for 30000 in state hsmup_state_voice_connected
006283376 HSMU 3: abort timer in state hsmup_state_voice_connected
006283434 HSMU 3: set timer for 30000 in state hsmup_state_voice_connected
006283434 HSMU 3: abort timer in state hsmup_state_voice_connected
006283434 HSMU 3: cmControlStateTransportConnected, Control channel opened for F
ast Start call.
006283434 HSMU 3: Starting Capabilities Exchange, capabilities_send=0
006283434 HSMU 3: Sending local capabilities.
006283434 HSMU: h323_get_static_cap_name capability name "nonStandard"
006283434 HSMU: h323_get_static_cap_name NOT FOUND!
006283434 HSMU: Invalid capability name "hookflash"
006283434 HSMU: Invalid capability name "dtmf"
006283434 HSMU: Invalid capability name "basicString"
006283434 HSMU: h323_get_static_cap_name capability name "g7231"
006283434
006283434 Capability Set
006283434 HSMU 3: hsmup_rad_call_capabilities() Ignore regular capability match
during Fast Start.
006283434 HSMU 3: CapabilitiesExt_msg
006283446 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
006283446 HSMU 3: abort timer in state hsmup_state_voice_connected
006283446 HSMU 3: set timer for 10000 in state hsmup_state_fax_channel
006283447 HSMU 3: abort timer in state hsmup_state_fax_channel
006283447 HSMU 3: H.323 release (IF)
006283498 HSMU 3: voice rtp open=0, rtcp open=0, nw_close(voice socked RTP0, RTC
P0)
006283498 HSMU 3: nw_close(inchan local RTCP3, RTP2)
006283498 HSMU 3: nw_close(inchan local RTCP65535, RTP65535)
006283498 HSMU 3: nw_close(outchan local RTCP65535)
Что це такое???
Может кто видел?
С уважением, Александр.
СообщениеДобавлено: Чт ноя 27, 2003 12:39
А если без фаст-старта.
С уважением, Дмитрий Письменов
