Текущее время: Пт окт 30, 2026 13:37
 Заголовок сообщения: затруднения с DVX-7090
СообщениеДобавлено: Сб ноя 29, 2008 18:23
обновил прошивку
11/29/2008 17:15:45 App2007-12-13_6480_1 (current)
11/29/2008 17:14:35 App2008-03-20_6480_2.txt (previous)
при исправениях в учетной записи выдается
Server error in '/' application
Description: Error processing request.
Error Message: HTTP 500.
Stack Trace: System.UnauthorizedAccessException: Access to the path '/mera/Phoenix/Option.xml' is denied.
Server stack trace:
at System.IO.FileStream..ctor (System.String name, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, Boolean anonymous, FileOptions options) [0x00000]
at System.IO.FileStream..ctor (System.String name, FileMode mode, FileAccess access, FileShare share) [0x00000]
at (wrapper remoting-invoke-with-check) System.IO.FileStream:.ctor (string,System.IO.FileMode,System.IO.FileAccess,System.IO.FileShare)
at System.IO.StreamWriter..ctor (System.String path, Boolean append, System.Text.Encoding encoding, Int32 bufferSize) [0x00000]
at System.IO.StreamWriter..ctor (System.String path, Boolean append, System.Text.Encoding encoding) [0x00000]
at (wrapper remoting-invoke-with-check) System.IO.StreamWriter:.ctor (string,bool,System.Text.Encoding)
at System.Xml.XmlWriter.Create (System.String file, System.Xml.XmlWriterSettings settings) [0x00000]
at MeraSystems.VoIP.Phoenix.XmlDatabaseDll.XmlDataTable.Serialize (Boolean final) [0x00000]
at <0x00000> <unknown method>
at (wrapper managed-to-native) System.Runtime.Remoting.RemotingServices:InternalExecute (System.Reflection.MethodBase,object,object[],object[]&)
at System.Runtime.Remoting.RemotingServices.InternalExecuteMessage (System.MarshalByRefObject target, IMethodCallMessage reqMsg) [0x00000]
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (System.Runtime.Remoting.Proxies.RealProxy rp, IMessage msg, System.Exception& exc, System.Object[]& out_args) [0x00000]
http://uka.ru/?dlink
СообщениеДобавлено: Сб ноя 29, 2008 18:24
при исправлении юзера
СообщениеДобавлено: Сб ноя 29, 2008 18:25
при создании новых юзеров
Server stack trace:
СообщениеДобавлено: Пн дек 01, 2008 11:39
Модератор
Модератор
Напишите мне на почту
Виктор Колосов
