Текущее время: Чт сен 10, 2026 19:59
СообщениеДобавлено: Вс окт 21, 2007 20:19
Класная штука этот DVX-7090
И на 80% покрывает все наши потребности. Но!
Всё работало и потом всё чаще и чаще стало появляться следующее:
Server error in '/' application
Description: Error processing request.
Error Message: HTTP 500.
Stack Trace: System.IO.IOException: IO exception during read.
Server stack trace:
at Mono.Security.Protocol.Tls.SslStreamBase.Read (System.Byte[] buffer, Int32 offset, Int32 count) [0x00000]
at Mono.WebServer.XSPWorker.Read (System.Byte[] buffer, Int32 position, Int32 size) [0x00000]
at Mono.WebServer.BaseRequestBroker.Read (Int32 requestId, Int32 size, System.Byte[]& buffer) [0x00000]
at (wrapper remoting-invoke-with-check) Mono.WebServer.BaseRequestBroker:Read (int,int,byte[]&)
at (wrapper xdomain-dispatch) Mono.WebServer.BaseRequestBroker:Read (object,byte[]&,byte[]&,int,int,byte[]&)
Exception rethrown at [0]:
---> System.IO.IOException: Read failure ---> System.Net.Sockets.SocketException: Operation timed out.
at System.Net.Sockets.Socket.Receive (System.Byte[] buf, Int32 offset, Int32 size, SocketFlags flags) [0x00000]
at System.Net.Sockets.NetworkStream.Read (System.Byte[] buffer, Int32 offset, Int32 size) [0x00000] --- End of inner exception stack trace ---
at Mono.Security.Protocol.Tls.SslStreamBase.Read (System.Byte[] buffer, Int32 offset, Int32 count) [0x00000] --- End of inner exception stack trace ---
at (wrapper xdomain-invoke) Mono.WebServer.BaseRequestBroker:Read (int,int,byte[]&)
at Mono.WebServer.XSPWorkerRequest.ReadInput (System.Byte[] buffer, Int32 offset, Int32 size) [0x00000]
at Mono.WebServer.XSPWorkerRequest.ReadEntityBody (System.Byte[] buffer, Int32 size) [0x00000]
at System.Web.HttpRequest.MakeInputStream () [0x00000]
at System.Web.HttpRequest.get_InputStream () [0x00000]
at System.Web.HttpRequest.LoadWwwForm () [0x00000]
at System.Web.HttpRequest.get_Form () [0x00000]
at System.Web.UI.Page.DeterminePostBackMode () [0x00000]
at System.Web.UI.Page.InternalProcessRequest () [0x00000]
at System.Web.UI.Page.ProcessRequest (System.Web.HttpContext context) [0x00000]
ПРи попытке конфигурирования.
Текст собственно говоря всё время разный, и работает в зависимости какая страница открывается.
Закладки при кофигурировании через WEB (кликая переход по меню) тормозят страшно... при этом при той же прошивке и той-же конфигурации ранее - этого не было.
На работу самой голоса вроде как не сказалось.
Но! Мне кажется просто где-то у него память закончилась... в системе... тот же самый /tmp у линукса... только вот доступа туда нету, да и не горю желанием туда лезть. Что можете подсказать?
Если что - можете писать на aleksey.borisov@gmail.com
PS: Коннекчусь к системе по ssl ибо так секьюрнее.
СообщениеДобавлено: Пн окт 22, 2007 16:18
SOS!!!!!!!!
Warning: disk space is about to get full soon.
Current free space is: 39 Mb.
Please remove unused logs manually.
Чуть позже:
Alert: disk space was full.
The following logs have been removed automatically:
Logic-2007-10-21-00-00-40.zip
log-2007-10-21-07-48-41.zip
log-2007-10-21-09-46-55.zip
log-2007-10-21-11-45-15.zip
log-2007-10-21-13-43-33.zip
Что делать??? логи то удалены уже даже текущего месяца.
СообщениеДобавлено: Пн окт 22, 2007 17:32
IP-PBX member
Ultraviolet писал(а):
SOS!!!!!!!!
Чуть позже:
Посмотрите какие размеры у лог файлов. Если много генерируется, то никакого криминала не вижу в удалении старых логов. Если бы забилось на 100% было бы гораздо хуже.
Кстати- апдейты тоже место занимают- старыве можно и стереть
По первой проблеме обратитесь в поддержку
MERA
СообщениеДобавлено: Ср окт 24, 2007 15:18
Да не так уж и много генерируются они занимают каждый архив максимум мо мегабайту.
+ - раньше то такого не было!!!!
PS: Объём логов указан за месяц.
СообщениеДобавлено: Ср окт 24, 2007 15:34
IP-PBX member
Да, но непожатые логи за текущие сутки могут занимать на пару порядков больше.
Далее- сколько у Вас живет Апп апдейтов и какого размера. Сколько вы заливали системных апдейтов и какого размера (они тоже место отжирают)
Место просто так никуда не девается, кто нибудь там обязательно лежит :-)
MERA
СообщениеДобавлено: Ср окт 24, 2007 15:56
Почему раньше такого не было, при том же объёме звонков?
И как от этого избавиться?
СообщениеДобавлено: Ср окт 24, 2007 16:01
IP-PBX member
Повторяю в третий раз- раньше вы не заливали апдейтов, которые сейчас занимают место. Как минимум сотрите ненужные апп апдейты
MERA
СообщениеДобавлено: Ср окт 24, 2007 16:05
Да я апдейт последний раз заливал в июле последний раз.
И стёр ненужные. И те которые не использую
СообщениеДобавлено: Ср окт 31, 2007 16:17
И что дальше?
Как мне решить проблему?
Проблема осталась!!!!! Удалил всё что возможно!
СообщениеДобавлено: Ср окт 31, 2007 16:19
IP-PBX member
А в официальный саппорт обратиться чтоб посмотрели что на железке творится никак?
MERA
СообщениеДобавлено: Чт ноя 01, 2007 02:11
А тут разве не официальный Длинк?? Скажите куда!
