Текущее время: Вс авг 09, 2026 12:15
СообщениеДобавлено: Пт сен 07, 2007 14:46
2016 работает на Zyxel 791 на статическом ip без проблем. Звонит и на сип и к партнерам на шлюз включенный в мини-АТС.
Вот лог:
12:57:54 [000513] 1: Line DialNum_New [111]
12:57:54 [000513] 1: OutPinCode=<>, dial_no=<111>
12:57:54 [000513] 1: PhoneBook has GwNo=111, addr=IPдругой стороны:5060
12:57:54 [000513] 1: ==7:Inviting
12:57:54 [000513] 1: VoIP CallOut, Invite <sip:111@IPдругой стороны:5060;user=phone>
12:57:54 [000514] 16: 2753734=DIALING
12:57:55 [000515] 16: 2753734=PROCEEDING
12:57:55 [000529] 16: 2753734=CONNECTED
12:57:55 [000529] 1: Peer=IPдругой стороны:9024, PT=0, RecvOnly=0
12:57:55 [000529] 1: RtpApiTalk[1,1], Peer=IPдругой стороны:9024, PT=0, FC=6, NewOOB=1
12:57:56 [000529] 1: ==14:Talking
12:57:58 [000559] 1: Get(1)
12:57:58 [000562] 1: Get(0)
12:58:00 [000577] 1: Get(6)
- пошла связь
12:58:05 [000627] DSP_ch1_check=0
12:58:05 [000627] 1: Fxs Hangup
12:58:05 [000627] 1: Bye at Talking
12:58:05 [000627] 1: ==3:Idle
12:58:05 [000627] 1: SetFax(1)=0
12:58:05 [000628] 16: 2753734=DISCONNECT
12:58:06 [000628] 16: Release Old Dlg #1
Как только переключаю в Zyxel 660 с динамическим ip:
13:03:02 [001818] 0: Line DialNum_New [111]
13:03:02 [001818] 0: OutPinCode=<>, dial_no=<111>
13:03:02 [001818] 0: PhoneBook has GwNo=111, addr=IPдругой стороны:5060
13:03:02 [001818] 0: ==7:Inviting
13:03:02 [001820] 0: VoIP CallOut, Invite <sip:111@IPдругой стороны:5060;user=phone>
13:03:02 [001821] 16: 2753734=DIALING
13:03:02 [001823] 16: 2753734=PROCEEDING
13:03:03 [001836] 16: 2753734=CONNECTED
13:03:03 [001837] 0: Peer=IPдругой стороны:9022, PT=0, RecvOnly=0
13:03:03 [001837] 0: RtpApiTalk[1,1], Peer=IPдругой стороны:9022, PT=0, FC=6, NewOOB=1
13:03:03 [001837] 0: ==14:Talking
13:03:15 [001951] 16: 2753734=DISCONNECT
13:03:15 [001952] 0: Release Active Dlg
13:03:15 [001952] 0: ==15:PlayBusyTone
- попытка и короткие гудки
13:03:19 [001992] DSP_ch0_check=0
13:03:19 [001992] 0: Fxs Hangup
13:03:19 [001993] 0: ==3:Idle
13:03:19 [001993] 0: SetFax(1)=0
13:03:23 [002033] 1: Fxs Pickup
13:03:23 [002033] 1: ==4:GetDtmf
13:03:28 [002086] 1: DTMF Timeout #1
13:03:28 [002086] 1: End Input Default Route [0]
Может кто подскажет что за ерунда происходит? Запарился уже... :(
СообщениеДобавлено: Пн сен 10, 2007 11:29
Модератор
Модератор
Вообще нужно иметь представления о топологии сети и маршрутизации звонков. Предположу что шлюз просто не знает куда слать пакеты или кто то их режет.
Виктор Колосов
СообщениеДобавлено: Пн сен 10, 2007 16:48
Почему же не знает, IP адрес модема в качестве шлюза прописан, (192.168.1.1 работает, а меняю на 192.168.1.4 уже не хочет). На обоих модемах настройки и по пробросу портов и фильтры одинаковые.
И при включении шлюза нормально регистрируется на сипе.
СообщениеДобавлено: Чт сен 20, 2007 15:35
Уточнил у провайдера, утверждают что ничего подобного не режут :(
СообщениеДобавлено: Чт сен 20, 2007 16:01
Впрочем не регистрируется, в личном кабинете написано ...нет подключенных устройств...
