Текущее время: Вт окт 27, 2026 05:22
СообщениеДобавлено: Пт авг 20, 2004 10:47
При попытке отправить факсы с DG-102SH или с DG-104SH связь через некоторой время разрывается и всё.
Прошивки:
на DG-102SH - dg102SH_firmware_b43
на DG-104SH - 104nmm._NEWEST!!!tfp и 104P_B13.tfp
Настройки:
set h323 t38 on
set h323 t38_req_initiater callee
set coding 6 fax_tcf_method 2
set coding 6 fax_t30_features ecmon
set coding 6 vad off
еще пробовал и доп. настройки:
h323 h245_term_type = 60
h323 endpoint_reg_type = terminal
h323 fast_start = off
что на том, что на другом шлюзе :( .
В итоге выдает в терминале:
Get_Tcid_By_LocNum() fail of hsmup_send_rtcp_sr
Как можно поправить?
СообщениеДобавлено: Пт авг 20, 2004 10:51
Вот еще конфигурация при команде show coding:
Configuration for coding profile id 6:
Tx Coding = T.38 FAX
Rx Coding = T.38 FAX
Coding profile for fax
Tx VIF size = 288 (bits)
Rx VIF size = 288 (bits)
VAD = Disabled
VAD threshold = Adaptive VAD
Playout nominal delay = 300 (msec)
Playout maximum delay = 300 (msec)
Playout minimum delay = 20 (msec)
Adaptive Playout = Disabled
Rate = 14400
DTMF Relay = Disabled
Tone detect = Enabled
Call Progress Tone detect = Disabled
V.18 Tone detect = Disabled
SS7 COT Tone detect = Disabled
SF Sig Tone detect = Disabled
EC = Disabled
EC NL = Disabled
EC NL Sens = 0
EC Tail = 8 (msec)
EC Refresh = Update
EC Coeffs = Normal
EC Auto Update = Disabled
EC Auto Search = Disabled
EC Search Freeze = Disabled
Modem TX level = -10 (dB)
Modem CD threshold = 1
Modem no activity timeout = 30 (sec)
Silence detection time = 0 (msec)
Silence detection level = 0 (dB)
Fax debug level = 0
TCF handling = Method 2 (Sent over the network)
Max low speed packetization = 1 (bytes)
Tx network timeout = 150 (sec)
Eflag start timer = 2600 (ms)
Eflag stop timer = 2300 (ms)
Scan line fix up = Enabled
Eflags for fast DIS = Enabled
TFOP proto enhancement = Enabled
NSF override = Disabled
T30 ECM = Enabled
T30 MR page compression = Disabled
T.38 Fax Parameters
Fax high-speed packet rate = 10 (msec)
Fax low-speed redundancy for T.38 UDP = 3
Fax high-speed redundancy for T.38 UDP = 0
Caller ID Support = Disabled
Resampling = Disabled
EC Config = NLP_FIXED
NLP Confort Noise = 0
SID Retx Rate = 2000
Encapsulation = UDP.
СообщениеДобавлено: Пт авг 20, 2004 11:46
Прошивки:
Настройки:
set h323 t38 on
Смените на 104 до 53 и покажите лог сессии
С уважением, Дмитрий Письменов
