Текущее время: Вт окт 27, 2026 04:47
 Заголовок сообщения: зависание DG 104s
СообщениеДобавлено: Пн авг 02, 2004 07:37
D-Link DG-104S: Initializing Device OS
-> DUPLICATED IP CHECKING: (Hit CTRL-C to stop system boot/load )k: 255.255.255.255
ARP Req Send
.. IP Address: 192.168.1.4y
.. Subnet Mask: 255.255.255.255
ARP Req Send ARP Reply ARP Retry Time (Sec)
After mem init
Afte
In MXP Root before lock
NWIF: hwu_get_ip_addre
In MXP Root after lock
After mem init hwu_get_netma
After hwu_init5.255
NWIF: hwu_get_ip_address()=192.168.1.4u_get_gateway_address()=192.168.1.1
NWIF: hwu_get_netmask()=255.255.255.255
NWIF: hwu_get_mac_address()=00:50:ba:1
NWIF: hwu_get_gateway_address()=192.168.1.1
000000301 NWIF: nw_create() failed
After Web_create
After Nat
After Tftp_create
After PPPoE
After Snmp_create
After cha
After Dhcpserv_createalf driving
After Nat_create
After PPPoE_createopen() - Can't ope
After changes clock source to half driving
After unlock
000000334 NMM: 0, Signaling: xGCP, Protocol: FXS Loop Start
000000334 NMM: 0, Set Channel State Done (SUCCESS)
000000334 NMM: 0, Channel Config Done (SUCCESS)
000000334 NMM: 1, Signaling: xGCP, Protocol: FXS Loop Start
000000334 NMM: 1, Set Channel State Done (SUCCESS)
000000334 NMM: 1, Channel Config Done (SUCCESS)
000000334 NMM: 2, Signaling: xGCP, Protocol: FXS Loop Start
000000334 NMM: 2, Set Channel State Done (SUCCESS)
000000334 NMM: 2, Channel Config Done (SUCCESS)
000000334 NMM: 3, Signaling: xGCP, Protocol: FXS Loop Start
000000334 NMM: 3, Set Channel State D
000000334 NMM: 3, Channel Config Done (SUCCESS)
000000334 NMM: 3, Set Channel State Done (SUCCESS)
000000334 NWIF: nw_open() - Can't open a connection. No free CCBs (connection po
ints).
000000334 xGCP: ERROR 0X106 in .\src\ggcaif.c at line 112 (nw_open failed for caif)
Username:
на этом деле намерво виснет
 Заголовок сообщения: Re: зависание DG 104s
СообщениеДобавлено: Пн авг 02, 2004 12:24
Попробовать сделать сброс в заводские настройки
Сейчас этот форум просматривают: Google [Bot] и гости: 5
