Текущее время: Ср окт 28, 2026 06:51
 Заголовок сообщения: [DG-104S] FAIL-to many Calls on this Endpoint
СообщениеДобавлено: Вс май 23, 2004 20:34
Vremja ot vremeni polucgaju vot takuju oshibku ot DG-104S. Kommanda xgcp restart 0 privodit k oshibke ENDPOINT IS OUT OF SERVICE. Pomogajet toljko nwdbg system reboot. K tomu zhe nomer porta, po kotoromu proishodit vysylka i prijom kakoj-to strannyj: 54216(d3c8), hotja na drugoj storone javno vidno, chto vsje soobschenije uhodjat cherez 2427. Ja polagaju, chto eto BUG, kotoryje zhivjot uzhe na protjazeniji mnogih relizov. Moj firmware: DG104S_promD.B38 i DG104S_rtD.T86.
ggdbg>000166620 XGCP CAIF: recvd msg from xxx.xxx.xxx.xxx:d3c8,msg=
000166620 msgline[0]=CRCX 393 aaln/1@dlink_terminal MGCP 1.0
000166620 msgline[1]=C: 63035c67184c96de
000166620 msgline[2]=L: p:20, a:G729A
000166620 msgline[3]=M: recvonly
000166620 msgline[4]=X: 184c96de
000166620 msgline[5]=
000166620 msgline[6]=v=0
000166620 msgline[7]=o=root 23892 23892 IN IP4 xxx.xxx.xxx.xxx
000166620 msgline[8]=s=session
000166621 msgline[9]=c=IN IP4 xxx.xxx.xxx.xxx
000166621 msgline[10]=t=0 0
000166621 msgline[11]=m=audio 30144 RTP/AVP 18 101
000166621 msgline[12]=a=rtpmap:18 G729A/8000
000166621 msgline[13]=a=rtpmap:101 telephone-event/8000
000166621 msgline[14]=a=fmtp:101 0-16
000166621 parsing msg @ 2cb634, len=369
000166621 XGCP parse SDP - rtpmap fmt 18 (g729a) mapped to telogy type 68
000166621 XGCP parse SDP - bogus rtpmap encode name 101 -> telephone-event
000166621 XGCP parse SDP - dtmf relay payload type=101
000166621 MSPUCM: nacking crcx/mdcx/del, code=403, reason=FAIL-to many Calls on
this Endpoint
000166621 sending(PB)[len=44][addr=xxx.xxx.xxx.xxx][port=54216]
000166621 403 393 FAIL-to many Calls on this Endpoint
000166638 XGCP CAIF: recvd msg from xxx.xxx.xxx.xxx:d3c8,msg=
000166638 msgline[0]=RQNT 394 aaln/1@dlink_terminal MGCP 1.0
000166638 msgline[1]=X: 184c96de
000166638 msgline[2]=R: L/hd(N)
000166638 msgline[3]=S: L/rg,L/ci(05/23/11/09,1000,Vlad)
000166638 parsing msg @ 2cb634, len=136
000166638 t0 ring48
000166638 report ring callback, tcid 0, ringing = 1, type = 0, count = 0
000166638 **TCID 0 CI MESSAGE: 05/23/11/09,1000,Vlad**
000166638 sending(PB)[len=11][addr=xxx.xxx.xxx.xxx][port=54216]
000166638 200 394 OK
000166656 XGCP CAIF: recvd msg from xxx.xxx.xxx.xxx:d3c8,msg=
000166656 msgline[0]=RQNT 397 aaln/1@dlink_terminal MGCP 1.0
000166656 msgline[1]=X: 184c96de
000166656 msgline[2]=R: hd(N)
000166656 parsing msg @ 2c223c, len=85
000166656 t0 stop ring48
000166656 report ring callback, tcid 0, ringing = 0, type = 1, count = 1
000166656 sending(PB)[len=11][addr=xxx.xxx.xxx.xxx][port=54216]
000166656 200 397 OK
000166672 XGCP CAIF: recvd msg from xxx.xxx.xxx.xxx:d3c8,msg=
000166672 msgline[0]=RQNT 398 aaln/1@dlink_terminal MGCP 1.0
000166672 msgline[1]=X: 184c96de
000166672 msgline[2]=R: hd(N)
000166672 msgline[3]=S: vmwi(-)
000166672 parsing msg @ 2c223c, len=101
000166672 **TCID 0 MESSAGE WAITING OFF** hook=on
000166672 sending(PB)[len=11][addr=xxx.xxx.xxx.xxx][port=54216]
000166672 200 398 OK
000167253 TCID: 0 Caller ID timeout waiting for ring:
Spasibo,
Vlad.
