Текущее время: Вт окт 27, 2026 17:51
СообщениеДобавлено: Ср июн 07, 2006 16:04
Перезагрузка телефона http://$ip:9999/restart.htm
Сброс параметров в начальные значения http://$ip:9999/initcf.htm
Возможно неполный список параметров телефонов. Буду благодарен за ошибки и очепятки.
[code]
% cat dph.tag
[fwupd.htm]
AP_HOST="FTP Server"
AP_USER="Login ID"
FTP_PWD="Login Password"
AP_FILE="Firmware Filename"
[network.htm]
DHCP="0=Static IP, 1=DHCP, 2=PPPoE"
adsl_id="PPPoE ID"
adsl_pwd="PPPoE Password"
ip="IP Address"
router="Router IP"
mask="Subnet Mask (255.255.255.0)"
dns="DNS Server"
button="bntSubmit"
[normal.htm]
web_name="User Name"
c_password="Password"
password="hidden password"
sntp="NTP Server IP"
tz="Time Zone, -12..+12"
day_li="Daylight Saving, 0=Disable, 1=Enable (0)"
useTftp="TFTP Server: 0="Disable, 1=Enable (0)"
useFtp="FTP Client: 0=Disable, 1=Enable (0)"
r_password="Remote Config Password (1234)"
[phone.htm]
tone1="Tone Setting: 2=us 3=jp 4=kr 5=sg 6=tw 7=es 8=de 9=fr 10=bg 11=cn 12=it 14=uk (2)"
ring1="Ringer Type, 0=Type1, 1=Type2, 2=Type3, 3=Type4"
HOLD="Hold Tone: 0=Melody, 1=Tone (0)"
dnd="Do Not Disturb: 0=Disable, 1=Enable (0)"
wait="Call Waiting: 0="Disable, 1=Enable (1)"
cif="Anonymous Call, 0=Disable, 1=Full URI, 2=Display Name (0)"
rejncif="Anonymous Call Reject, 0=Disable, 1=Enable (0)"
pond_key="Pound Key Dial, 0=Disable 1=Enable (0)"
fwd_nc="No Answer"
fwd_n="No Answer Number"
fwd_bc="Busy"
fwd_b="Busy Number"
fwd_ac="Unconditional"
fwd_a="Unconditional Number"
sntp_cycle="Network Time Adjustment Period, sec. [0 - 60] 0: Disable"
dialTo="Inter Digit Timer, sec. [0 - 60] 0: Disable"
ansTo="Originating Not Accept Timer, sec. [0 - 600] 0: Disable"
ringTo="Incoming No Answer Timer, sec. [0 - 600] 0: Disable"
holdTo="Hold Recall Timer, sec. [0 - 600] 0: Disable"
idleTo="Auto Speaker Off Timer, sec. [0 - 600] 0: Disable"
[pswd.htm]
OldPwd="Old Password"
NewPwd="New Password"
ConfirmPwd="Confirm New Password"
[sipAccount.htm]
defAcc="Default Account 1,2,3,4 (1, в htm все номера на 1 больше)"
regAct0="Account Active 0=Disable, 1=Enable (1)"
my_name="Display Name 1"
my_tel="SIP User Name 1"
reg_name="Authentication User Name 1"
my_sip_pwd="Authentication Password 1"
regAct1="Account 2 Active 0=Disable, 1=Enable (0)"
my_name1="Display Name 2"
my_tel1="SIP User Name 2"
reg_name1="Authentication User Name 2"
my_sip_pwd1="Authentication Password 2"
regAct2="Account 3 Active 0=Disable, 1=Enable (0)"
my_name2="Display Name 3"
my_tel2="SIP User Name 3"
reg_name2="Authentication User Name 3"
my_sip_pwd2="Authentication Password 3"
regAct3="Account 4 Active 0=Disable, 1=Enable (0)"
my_name3="Display Name 4"
my_tel3="SIP User Name 4"
reg_name3="Authentication User Name 4"
my_sip_pwd3="Authentication Password 4"
[sip.htm]
my_sip_port="SIP Phone Port Number (5060)"
reg_svr="Registrar Server Domain Name/IP Address"
reg_port="Registrar Server Port Number (5060)"
reg_to="Authentication Expire Time (3600 sec)"
pxy_svr="Outbound Proxy Domain Name/IP Address"
pxy_port="Outbound Proxy Port Number (5060)"
msg_svr="MWI Message Server Domain Name/IP Address"
msg_port="MWI Message Server Port Number (5060)"
msg_to="MWI Message Server Expire Time (3600)"
msg_account="Voice Message Account"
sess_to="Session Timer (1800)"
Rtp_Port="Media Port (41000)"
prack="Prack: 0=Disable, 1=Enable (1)"
sessref="Session Refresher: 0=None, 1=UAC, 2=UAS (0)"
sesstp="Session Timer Method: 0=Invite, 1=Update (0)"
sendreg="Register with Proxy 0=Enable, 1=Disable (0)"
[spdial.htm]
F1="Number 00"
F2="Number 01"
F3="Number 02"
F4="Number 03"
F5="Number 04"
F6="Number 05"
F7="Number 06"
F8="Number 07"
F9="Number 08"
F10="Number 09"
[stun.htm]
useStun="STUN: 0=Disable, 1=Enable (0)"
stun_ip="STUN Domain Name/IP Address"
upnp="UPnP: 0=Disable, 1=Enable (0)"
[voice.htm]
codec1="Codec1 1=ulaw, 2=alaw, 3=G723.1, 4=G729A (1)"
codec2="Codec2 0=n/a 1=ulaw, 2=alaw, 3=G723.1, 4=G729A (4)"
codec3="Codec3 0=n/a 1=ulaw, 2=alaw, 3=G723.1, 4=G729A (3)"
codec4="Codec4 0=n/a 1=ulaw, 2=alaw, 3=G723.1, 4=G729A (0)"
pt1="RTP Packet Length G.711-ulaw 0=10ms, 1=20ms, 2=30ms, 3=40ms (1)"
pt2="RTP Packet Length G.711-alaw 0=10ms, 1=20ms, 2=30ms, 3=40ms (1)"
pt3="RTP Packet Length G.729A 0=10,1=20,2=30,3=40,4=50,5=60,6=70,7=80ms (1)"
pt4="RTP Packet Length G.723.1 2=30ms, 5=60ms (2)"
VAD="VAD: 0=Off, 1=On (0)"
DTMF_KIND="DTMF Method: 0=OutBand, 1=InBand, 2=SIP_INFO (1)"
RTP_TOS="Voice TOS, 0-7, (5)"
VLAN_En="VLAN 0=Disable, 1=Enable (0)"
vlanPri="VLAN Priority, [0 - 7] (4)"
VlanID="VLAN ID, [0 - 4094] (0)"
[/code]
В телефон это засовываем при помощи:
[code]
my $req = HTTP::Request->new("POST" => "$url/$href");
$req->referer("$url/$href");
$req->authorization_basic($uname, $upassword);
$req->content_type('application/x-www-form-urlencoded');
$req->content($data);
my $res = $ua->request($req)->as_string;
foreach ( split /\n/, $res ) { print "$_\n"; last if /^$/; }
[code]
Всем превед :-)
cron
