Текущее время: Вт окт 27, 2026 03:48
 Заголовок сообщения: Рвутся звонки между 5350 и 104SH
СообщениеДобавлено: Вт апр 13, 2004 13:00
Примерно через 5 секунд после начала разговора происходит обрыв звонка с причиной Recovery on timer expiry
причем неважно с циски звонить или с длинка..
от кодека и режима фаст старт сия проблема не зависит..
залил прошивку 42 ситуация аналогичная
трейс с циски:
Apr 13 13:53:33.309: ISDN Se2/3:15 Q931: TX -> SETUP pd = 8 callref = 0x0022
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x0082, '666'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '123'
Apr 13 13:53:33.329: ISDN Se2/3:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8022
Apr 13 13:53:33.429: ISDN Se2/3:15 Q931: RX <- ALERTING pd = 8 callref = 0x8022
Progress Ind i = 0x8282 - Destination address is non-ISDN
Progress Ind i = 0x8288 - In-band info or appropriate now available
Apr 13 13:53:34.389: ISDN Se2/3:15 Q931: RX <- CONNECT pd = 8 callref = 0x8022
Date/Time i = 0x04040D0F3436
Apr 13 13:53:34.393: ISDN Se2/3:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0022
Apr 13 13:53:48.481: ISDN Se2/3:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x0022
Cause i = 0x80E6 - Recovery on timer expiry
Apr 13 13:53:48.497: ISDN Se2/3:15 Q931: RX <- RELEASE pd = 8 callref = 0x8022
Apr 13 13:53:48.501: ISDN Se2/3:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0022
трейс с длинка
ggdbg>000006033 HSMU: Enter call_profile->capabilities
000006034 HSMU: t.38 codec found at profile 6
000006037 HSMU: Exit call_profile->capabilities.
000006037 HSMU 1: Process outgoing H.323 call.
000006038 Dialing DEST = TA:192,168,10,10:1720,TEL:123
000006038 SOURCE = NAME:DEFAULT_H323_ID,TEL:666
000006038 USER_TO_USER = CID_NAME:tcid0, CID_NUM:901710 SETUP
000006038 HSMU 1: set timer for 50000 in state hsmup_state_h225_wait_alerting
000006063 HSMU 1: abort timer in state hsmup_state_h225_wait_alerting
000006063 HSMU 1: No product Id info
000006063 HSMU 1: No version Id info
000006063 HSMU 1: Starting Capabilities Exchange, capabilities_send=0
000006064 HSMU 1: Sending local capabilities.
000006064 HSMU 1: set timer for 30000 in state hsmup_state_h245_wait_complete
000006064 HSMU 1: cmEvCallMasterSlaveStatus_msg: Local station is Slave
000007557 HSMU 1: abort timer in state hsmup_state_h245_wait_complete
000007557 HSMU 1: H.323 release (IF)
000007609 HSMU 1: voice rtp open=0, rtcp open=0, nw_close(voice socked RTP0, RTCP0)
000007609 HSMU 1: nw_close(inchan local RTCP65535, RTP65535)
000007609 HSMU 1: nw_close(outchan local RTCP65535)
СообщениеДобавлено: Вт апр 13, 2004 14:03
h245 caps mode restricted
С уважением, Дмитрий Письменов
СообщениеДобавлено: Вт апр 13, 2004 20:18
А не предполагет ли d-link как-то в своих прошивках учесть сей выкрутас циски?
Ибо проблема, про которую я вам вчера писал по почте оказалась также именно в этом, разница только в том, что оператор отказывается менять это у себя, мотивируя это тем, что это на всех сразу повлияет, что не есть хорошо.
СообщениеДобавлено: Ср апр 14, 2004 10:09
Это не совсем "выкрутас циски" это различее в версиях Н.323.
СообщениеДобавлено: Ср апр 14, 2004 13:21
Тем более. Это как-то решаться будет?
СообщениеДобавлено: Ср апр 14, 2004 13:59
Нет. пока поддержка н.323 версии 3 и выше в данных продуктах не планируется.
СообщениеДобавлено: Чт апр 15, 2004 10:59
IP-PBX member
подскажи где найти это комманду?
у клиента стоит связи 1104-104
через примерно 7 минут при звонке с 104 на город через 1104 связь рвется
СообщениеДобавлено: Чт апр 15, 2004 11:27
Это на циске, на наших устройствах ее нет
Прошивки какие?
СообщениеДобавлено: Чт апр 15, 2004 11:39
IP-PBX member
104 - 1.0B13-g
fw 1.0b40-g
1104 - а там где версию узнать?
СообщениеДобавлено: Чт апр 15, 2004 11:53
alex_u2 писал(а):
104 - 1.0B13-g
fw 1.0b40-g
104 - поставить 53
1104 rom -print смотреть aplication rom
СообщениеДобавлено: Пт апр 23, 2004 13:42
IP-PBX member
поставили 53 на 104 - проблема пропала.
Сейчас проблема у клиентов следующая
иногда при звонках между 104sh и 1104 (без разницы - с какого идет вызов и на какой) одна сторона слышит хорошо, а другая плохо.
Заменили 104 на другую 104 - тоже самое. Периодичность не постоянная и ни с чем не связывается.
1. Каким образом можно поиграться с громкостью?
2. Для 1104 может быть нормальный список команд существует?
СообщениеДобавлено: Пт апр 23, 2004 17:35
Громкость со стороны 104-го регулирует Gain.
