Текущее время: Вт окт 27, 2026 13:08
 Заголовок сообщения: Факсы и DG102SH. В очередной раз...
СообщениеДобавлено: Ср дек 21, 2005 19:58
Никак не могу заставить ходить факсы через эту железяку, постоянно происходит обрыв связи после ответа факса на другой стороне.
000103490 Match found for codec "g7231".
000103490 HSMU 4: Capabilities match found for "g7231"
000103490 HSMU 4: CapabilitiesExt_msg
000103542 HSMU 4: cmEvCallMasterSlaveStatus_msg: Local station is Slave
000103542 HSMU 4: cmControlStateConnected, p_call->fast_start_on=0
000103542 HSMU 4: Slave mode, waiting for Logical Channel opening.
000103542 HSMU 4: abort timer in state hsmup_state_h245_wait_complete
000103542 HSMU 4: set timer for 10000 in state hsmup_state_slave_wait_open_in_lc
000103587 HSMU 4: Chan 0i cmEvChannelSetRTCPAddress_msg IP = 213.138.110.134, Port = 23419
000103587 HSMU 4: Chan 0i - slave offering channel "g7231"
000103587 Match found with element 2
000103587 HSMU 4: Chan 0i: Opened RTP socket = 3, cmChannel = 16392
000103587 HSMU 4: Chan 0i: Opened RTCP socket = 4, port 16393
000103587 HSMU 4: selected codec name=g7231, selected profile=4, slave
000103587 HSMU 4: Chan 0i - cmChannelStateConnected "g7231" local RTCP = 16393, remote RTCP =23419, RTP = :16392
000103587 HSMU 4: Chan 0o - hsmup_open_channel() codec = "g7231", p_assoc_chan=0x434571
000103588 HSMU 4: abort timer in state hsmup_state_slave_wait_open_in_lc
000104021 HSMU 4: Chan 0o cmEvChannelSetRTCPAddress_msg IP = 213.138.110.134, Port = 23419
000104021 HSMU 4: Chan 0o cmEvChannelSetAddress_msg IP = 213.138.110.134, Port = 23418
000104021 HSMU 4: Chan 0o - cmChannelStateConnected "g7231" local RTCP = 16393, remote RTCP =23419, RTP = :23418
000104021 HSMU 4: VOICE CONNECTED, coding=g7231, mode=Slave
000104021 HSMU 4: set timer for 30000 in state hsmup_state_voice_connected
000104021 HSMU 4: request mode "request"
000104021 HSMU 4: recv cmReqModeRequest name=t38fax, entryId=6892
000104021 HSMU 4: recv cmReqModeRequest Chan 1734960640i old codec name = "g7231"
000104105 HSMU 4: abort timer in state hsmup_state_voice_connected
000104105 HSMU: h323_get_static_cap_name capability name "t38fax"
000104105 HSMU 4: Chan 1i cmEvChannelSetRTCPAddress_msg IP = 213.138.110.134, Port = 23419
000104105 HSMU 4: Chan 1i - slave offering channel "t38fax"
000104105 Match found with element 5
000104105 hsmup_slave_incoming_lc: nw_open(RTP6), call_num=4 , port=16392, chan_num(i/o)=1i
000104106 HSMU 4: Chan 1i: Opened RTP socket = 6, cmChannel = 16392
000104106 hsmup_slave_incoming_lc: nw_open(RTCP5), call_num=4 , port=16393, chan_num(i/o)=1i
000104106 HSMU 4: Chan 1i: Opened RTCP socket = 5, port 16393
000104106 HSMU 4: selected codec name=t38fax, selected profile=6, slave
000104106 HSMU 4: H.323 release (IF)
000104106 HSMU: h323_get_static_cap_name capability name "t38fax"
000104106 HSMU 4: << coding_resp; ERROR: sent 6, received 4
000104106 HSMU 4: Chan 1i - cmChannelStateConnected "t38fax" local RTCP = 16393, remote RTCP =23419, RTP = :16392
000106999 HSMU: h323_get_static_cap_name capability name "t38fax"
и после этого короткие гудки в трубке... :cry:
прошивки последнии...
дайте же вразумительный ответ, ходят ли вообще факсы через сей девайс впринципе или нет?..
СообщениеДобавлено: Чт дек 22, 2005 10:18
IP-PBX member
говорилось 1,5 млн раз!
http://dlink.ru/tests/test_24.php
Даешь связистов без брака!
AB4790-RIPE
СообщениеДобавлено: Чт дек 22, 2005 11:54
Странно... :oops: но перенабрав еще раз
set h323 t38 on
set h323 t38_req_initiater callee
set coding 6 fax_tcf_method 2
set coding 6 fax_t30_features ecmon
set coding 6 vad off
commit
заработало :oops: хотя раньше был обрыв канала...
спасибо.
СообщениеДобавлено: Вт янв 24, 2006 14:27
И все же не хочет он слать факсы, рвет все время связь, как только услышит сигнал факса:
000081204 HSMU 1: VOICE CONNECTED, coding=g729AnnexA, mode=Slave
000081204 HSMU 1: set timer for 30000 in state hsmup_state_voice_connected
000081394 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000081403 HSMU 1: request mode "request"
000081403 HSMU 1: recv cmReqModeRequest name=t38fax, entryId=5107
000081403 HSMU 1: recv cmReqModeRequest Chan 791752241i old codec name = "g729An
nexA"
000081627 HSMU 1: abort timer in state hsmup_state_voice_connected
000081627 HSMU:   h323_get_static_cap_name capability name "t38fax"
000081627 HSMU 1: H.323 release (IF)
000081627 HSMU 1: Chan 1i cmEvChannelSetRTCPAddress_msg IP = 66.55.148.130, Port
 = 20067
000081627 HSMU 1: Chan 1i - slave offering channel "t38fax"
000081627 Match found with element 5
000081627 hsmup_slave_incoming_lc: nw_open(RTP3), call_num=1 , port=16386, chan_
num(i/o)=1i
000081627 HSMU 1: Chan 1i: Opened RTP socket = 3, cmChannel = 16386
000081627 hsmup_slave_incoming_lc: nw_open(RTCP4), call_num=1 , port=16387, chan
_num(i/o)=1i
000081627 HSMU 1: Chan 1i: Opened RTCP socket = 4, port 16387
000081627 HSMU 1: selected codec name=t38fax, selected profile=6, slave
000081627 HSMU 1: << coding_resp; ERROR: sent 6, received 5
000081627 HSMU 1: Chan 1i - cmChannelStateConnected "t38fax"
       local RTCP = 16387, remote RTCP =20067, RTP = 213.184.225.135:16386
000085676 HSMU:   h323_get_static_cap_name capability name "t38fax"
000085743 HSMU 1: voice rtp open=0, rtcp open=0, nw_close(voice socked RTP2, RTC
P1)
000085743 HSMU 1: nw_close(inchan local RTCP1, RTP2)
000085743 HSMU 1: nw_close(inchan local RTCP4, RTP3)
000085743 HSMU 1: nw_close(inchan local RTCP65535, RTP65535)
000085743 HSMU 1: nw_close(outchan local RTCP65535)
СообщениеДобавлено: Вт янв 24, 2006 15:07
IP-PBX member
вы куда звоните?
через ип-провайдера ?
на других сторонах какие устройства?
AB4790-RIPE
