Текущее время: Пн окт 26, 2026 00:03
 Заголовок сообщения: 7111S Треск по порту FXO
СообщениеДобавлено: Вс май 23, 2010 17:35
Установил 7111S
Когда приходят звонки на порт FXO в половине случаев треск в линии с щелчками:
http://rapidshare.com/files/390714764/sound.wma
Снятие логов через slmon ничего не дает - они абсолютно одинаковы
На всякий случай прикладываю:
#Нормальный звонок
17:15:38 [021939] 1: Fxo Ringing
17:15:38 [021940] 1: RingTime(185) First Stop
17:15:40 [021958] 1: RingTime(382) Second Ring
17:15:42 [021981] 1: CallerId=
17:15:42 [021981] 1: ==17:WaitAnswerDeviceOk
17:15:42 [021981] 1: HotLineEnabled with [3390]
17:15:42 [021981] 1: End Input Default Route [0]
17:15:42 [021981] 1: Local Calling Fxs [3390]
17:15:42 [021981] 1: ==7:Inviting
17:15:42 [021981] 0: Local Called By Line 1
17:15:42 [021981] 0: ==12:Alerting
17:15:42 [021981] 1: ==8:RingBack
17:15:44 [022000] 0: Fxs Pickup
17:15:44 [022000] 0: Local Talk at ToAnswer
17:15:44 [022000] 0: RtpApiTalk[1,1], Peer=192.168.100.103:9002, PT=0, FC=4, NewOOB=0
17:15:44 [022000] 1: Local Talk at RingBack
17:15:44 [022000] 1: FxoHookOff
17:15:44 [022000] 1: SetInputGain(0)
17:15:44 [022000] 1: RtpApiTalk[0,0], Peer=192.168.100.103:9000, PT=0, FC=4, NewOOB=0
17:15:44 [022000] 0: ==14:Talking
17:15:44 [022000] 1: ==14:Talking
17:15:44 [022000] 1: SetTalkMode[1,1]
17:15:47 [022031] 0: Fxs Hangup
17:15:47 [022031] 0: Bye at Talking
17:15:47 [022031] 0: ==3:Idle
17:15:47 [022031] 0: SetFax(1)=0
17:15:47 [022031] 1: ==15:PlayBusyTone
17:15:50 [022061] 1: FxoHookOn
17:15:50 [022061] 1: ==3:Idle
17:15:50 [022061] 1: SetInputGain(6)
17:15:50 [022061] 1: SetFax(1)=0
# Звонок с щелчками.
17:15:59 [022151] 1: Fxo Ringing
17:15:59 [022152] 1: RingTime(186) First Stop
17:16:01 [022170] 1: RingTime(380) Second Ring
17:16:03 [022193] 1: CallerId=
17:16:03 [022193] 1: ==17:WaitAnswerDeviceOk
17:16:03 [022193] 1: HotLineEnabled with [3390]
17:16:03 [022193] 1: End Input Default Route [0]
17:16:03 [022193] 1: Local Calling Fxs [3390]
17:16:03 [022193] 1: ==7:Inviting
17:16:03 [022193] 0: Local Called By Line 1
17:16:03 [022193] 0: ==12:Alerting
17:16:03 [022193] 1: ==8:RingBack
17:16:05 [022214] 0: Fxs Pickup
17:16:05 [022214] 0: Local Talk at ToAnswer
17:16:05 [022214] 0: RtpApiTalk[1,1], Peer=192.168.100.103:9002, PT=0, FC=4, NewOOB=0
17:16:05 [022214] 1: Local Talk at RingBack
17:16:05 [022214] 1: FxoHookOff
17:16:05 [022214] 1: SetInputGain(0)
17:16:05 [022214] 1: RtpApiTalk[0,0], Peer=192.168.100.103:9000, PT=0, FC=4, NewOOB=0
17:16:05 [022214] 0: ==14:Talking
17:16:05 [022214] 1: ==14:Talking
17:16:05 [022215] 1: SetTalkMode[1,1]
17:16:11 [022275] 0: Fxs Hangup
17:16:11 [022275] 0: Bye at Talking
17:16:11 [022275] 0: ==3:Idle
17:16:11 [022275] 0: SetFax(1)=0
17:16:11 [022275] 1: ==15:PlayBusyTone
17:16:14 [022298] 1: Fxo Detected BTC(9)
17:16:14 [022298] 1: FxoHookOn
17:16:14 [022298] 1: ==3:Idle
17:16:14 [022298] 1: SetInputGain(6)
17:16:14 [022298] 1: SetFax(1)=0
Снифером не получается - он не видит данный трафик. даже если компьютер переключить с порта LAN DVG на отдельный порт в модеме.
Прошивка новая, с сайта
Куда копать?
СообщениеДобавлено: Вс май 23, 2010 20:21
что сейчас не могу высказаться - вынужден уйти. Освобожусь - обязательно выскажу своё мнение по этому вопросу.
СообщениеДобавлено: Ср июл 14, 2010 06:40
не совсем понятно, что за треск.. Если на FXO порту стоит настроено усиление, то попробуйте убрать усиление.
СообщениеДобавлено: Ср июл 14, 2010 08:33
Также попробуйте отключить эхокомпенсацию
 Заголовок сообщения: Re: 7111S Треск по порту FXO
СообщениеДобавлено: Ср апр 29, 2020 16:16
Здравствуйте, подниму еще раз этот вопрос.
Подключаем древнюю АТС Ростелеком с импульсным набором в IP-АТС.
Для импульсного набора и подключения аналоговой линии используем шлюз DVG-7111S.
В шлюз в FХS так же воткнут аналоговый телефон.
При звонке с аналогового телефона на внутренние номера IP-АТС - качество отличное.
При звонке через городскую линию FXO - в линии очень сильный треск и шум еле слышно голос.
При подключении в городскую линию телефона - голос слышно нормально.
В чем может быть причина?
отключение ЭХО, уровни звука - ничего не помогает.
