Текущее время: Ср сен 23, 2026 03:49
 Заголовок сообщения: Addpac ap100 и D-link 7111s
СообщениеДобавлено: Чт фев 12, 2015 09:04
Здравствуйте, проблема следующая: адпак и длинк настроены в режиме точка-точка.
С адпака звонок проходит хорошо но в обратную сторону никак. В трубке гудок идет, но адпак не реагирует. Подскажите в чем проблема. Лог slmon прилагаю
10:28:20 *** SLMON start to log ***
10:29:10 [000063] Receive Cmd=1100, ParaLen=5, Para=[Login]
10:29:10 [000063] Login RU_1.00 == Ver(1.02.38.96.11648 2014/07/17 16:27:33) PId(281.DLink.RU.Pocket.ProfileProv.DhcpOpt195.l2tp.DualAccess.NoPrefix.drtp) Drv(
10:29:10 1.4.2.216) Hw(SP350SO) ==
10:29:10 [000063] gw_msg: send cmd[9]
10:30:04 [000606] 1: Fxo Ringing
10:30:04 [000607] 1: RingTime(520) First Stop
10:30:04 [000608] 1: RingTime(760) Second Ring
10:30:06 [000624] 1: StopPlayTone()=0
10:30:06 [000624] 1: ### Fxo Get Fsk CallerId [12,], Len=2
10:30:06 [000624] 1: CallerId=12
10:30:06 [000624] 1: ==17:WaitAnswerDeviceOk
10:30:06 [000624] 1: StopDeviceVoiceTone
10:30:06 [000624] 1: HotLineEnabled with [701]
10:30:06 [000624] 1: End Input Default Route [1]
10:30:06 [000624] 1: PhoneBook has GwNo=701, addr=192.168.111.252:5062
10:30:06 [000624] 1: ==7:Inviting
10:30:06 [000624] 1: VoIP CallOut, Invite <sip:701@192.168.111.252:5062;user=phone>
10:30:06 [000624] 1: 601=DIALING
10:30:10 [000664] 1: RingTime Stopped
10:30:10 [000664] 1: Rtp Talk Stop !
10:30:10 [000664] 1: StopDeviceVoiceTone
10:30:10 [000664] 1: ### NewStatus Overlap: PlayBusyTone->PlayBusyTone ###
10:30:10 [000664] 1: ==15:PlayBusyTone
10:30:10 [000665] 1: StopPlayTone()=0
10:30:10 [000665] 1: FxoHookOn
10:30:10 [000665] 1: ==3:Idle
10:30:10 [000665] 1: InputGain(6)
10:30:10 [000665] 1: OpenFaxDetection, fax_setting=2
10:30:10 [000665] 1: SetFax(1)=0
10:30:14 [000708] 1: Fxo Ringing
10:30:15 [000709] 1: RingTime(520) First Stop
10:30:15 [000711] 1: RingTime(770) Second Ring
10:30:16 [000726] 1: StopPlayTone()=0
10:30:16 [000726] 1: *** OT_GetDtmfs, handle=11, dtmfs=
10:30:16 [000726] 1: CallerId=
10:30:16 [000726] 1: ==17:WaitAnswerDeviceOk
10:30:16 [000726] 1: StopDeviceVoiceTone
10:30:16 [000726] 1: HotLineEnabled with [701]
10:30:16 [000726] 1: End Input Default Route [1]
10:30:16 [000726] 1: PhoneBook has GwNo=701, addr=192.168.111.252:5062
10:30:16 [000726] 1: ==7:Inviting
10:30:16 [000726] 1: VoIP CallOut, Invite <sip:701@192.168.111.252:5062;user=phone>
10:30:16 [000726] 1: 601=DIALING
10:30:20 [000767] 1: RingTime Stopped
10:30:20 [000767] 1: Rtp Talk Stop !
10:30:20 [000767] 1: StopDeviceVoiceTone
10:30:20 [000767] 1: ### NewStatus Overlap: PlayBusyTone->PlayBusyTone ###
10:30:20 [000767] 1: ==15:PlayBusyTone
10:30:20 [000767] 1: StopPlayTone()=0
10:30:20 [000767] 1: FxoHookOn
10:30:20 [000767] 1: ==3:Idle
10:30:20 [000767] 1: InputGain(6)
10:30:20 [000767] 1: OpenFaxDetection, fax_setting=2
10:30:20 [000767] 1: SetFax(1)=0
10:30:25 [000811] 1: Fxo Ringing
10:30:25 [000812] 1: RingTime(520) First Stop
10:30:25 [000813] 1: RingTime(770) Second Ring
10:30:26 [000829] 1: StopPlayTone()=0
10:30:26 [000829] 1: *** OT_GetDtmfs, handle=11, dtmfs=
10:30:26 [000829] 1: CallerId=
10:30:26 [000829] 1: ==17:WaitAnswerDeviceOk
10:30:26 [000829] 1: StopDeviceVoiceTone
10:30:27 [000829] 1: HotLineEnabled with [701]
10:30:27 [000829] 1: End Input Default Route [1]
10:30:27 [000829] 1: PhoneBook has GwNo=701, addr=192.168.111.252:5062
10:30:27 [000829] 1: ==7:Inviting
10:30:27 [000829] 1: VoIP CallOut, Invite <sip:701@192.168.111.252:5062;user=phone>
10:30:27 [000829] 1: 601=DIALING
10:30:30 [000869] 1: RingTime Stopped
10:30:31 [000869] 1: Rtp Talk Stop !
10:30:31 [000869] 1: StopDeviceVoiceTone
10:30:31 [000869] 1: ### NewStatus Overlap: PlayBusyTone->PlayBusyTone ###
10:30:31 [000869] 1: ==15:PlayBusyTone
10:30:31 [000870] 1: StopPlayTone()=0
10:30:31 [000870] 1: FxoHookOn
10:30:31 [000870] 1: ==3:Idle
10:30:31 [000870] 1: InputGain(6)
10:30:31 [000870] 1: OpenFaxDetection, fax_setting=2
10:30:31 [000870] 1: SetFax(1)=0
10:30:35 [000913] 1: Fxo Ringing
10:30:35 [000914] 1: RingTime(510) First Stop
10:30:35 [000916] 1: RingTime(770) Second Ring
10:30:37 [000931] 1: StopPlayTone()=0
10:30:37 [000931] 1: *** OT_GetDtmfs, handle=11, dtmfs=
10:30:37 [000931] 1: CallerId=
10:30:37 [000931] 1: ==17:WaitAnswerDeviceOk
10:30:37 [000931] 1: StopDeviceVoiceTone
10:30:37 [000931] 1: HotLineEnabled with [701]
10:30:37 [000931] 1: End Input Default Route [1]
10:30:37 [000931] 1: PhoneBook has GwNo=701, addr=192.168.111.252:5062
10:30:37 [000931] 1: ==7:Inviting
10:30:37 [000931] 1: VoIP CallOut, Invite <sip:701@192.168.111.252:5062;user=phone>
10:30:37 [000931] 1: 601=DIALING
10:30:38 [000949] 1: $$$ [TX_TIMEOUT], dlg_state=32
10:30:38 [000949] 1: Release Old Dlg #2
10:30:41 [000972] 1: RingTime Stopped
10:30:41 [000972] 1: Rtp Talk Stop !
10:30:41 [000972] 1: StopDeviceVoiceTone
10:30:41 [000972] 1: ### NewStatus Overlap: PlayBusyTone->PlayBusyTone ###
10:30:41 [000972] 1: ==15:PlayBusyTone
10:30:41 [000972] 1: StopPlayTone()=0
10:30:41 [000972] 1: FxoHookOn
10:30:41 [000972] 1: ==3:Idle
10:30:41 [000972] 1: InputGain(6)
10:30:41 [000972] 1: OpenFaxDetection, fax_setting=2
10:30:41 [000972] 1: SetFax(1)=0
10:30:45 [001016] 1: Fxo Ringing
10:30:45 [001017] 1: RingTime(520) First Stop
10:30:45 [001018] 1: RingTime(770) Second Ring
10:30:47 [001033] 1: StopPlayTone()=0
10:30:47 [001033] 1: *** OT_GetDtmfs, handle=11, dtmfs=
10:30:47 [001033] 1: CallerId=
10:30:47 [001033] 1: ==17:WaitAnswerDeviceOk
10:30:47 [001034] 1: StopDeviceVoiceTone
10:30:47 [001034] 1: HotLineEnabled with [701]
10:30:47 [001034] 1: End Input Default Route [1]
10:30:47 [001034] 1: PhoneBook has GwNo=701, addr=192.168.111.252:5062
10:30:47 [001034] 1: ==7:Inviting
10:30:47 [001034] 1: VoIP CallOut, Invite <sip:701@192.168.111.252:5062;user=phone>
10:30:47 [001034] 1: 601=DIALING
10:30:49 [001051] 1: $$$ [TX_TIMEOUT], dlg_state=32
10:30:49 [001051] 1: Release Old Dlg #2
10:30:51 [001074] 1: RingTime Stopped
10:30:51 [001074] 1: Rtp Talk Stop !
10:30:51 [001074] 1: StopDeviceVoiceTone
10:30:51 [001074] 1: ### NewStatus Overlap: PlayBusyTone->PlayBusyTone ###
10:30:51 [001074] 1: ==15:PlayBusyTone
10:30:51 [001074] 1: StopPlayTone()=0
10:30:51 [001074] 1: FxoHookOn
10:30:51 [001074] 1: ==3:Idle
10:30:51 [001074] 1: InputGain(6)
10:30:51 [001074] 1: OpenFaxDetection, fax_setting=2
10:30:51 [001074] 1: SetFax(1)=0
10:30:59 [001153] 1: $$$ [TX_TIMEOUT], dlg_state=32
10:30:59 [001153] 1: Release Old Dlg #2
10:31:09 [001255] 1: $$$ [TX_TIMEOUT], dlg_state=32
10:31:09 [001255] 1: Release Old Dlg #2
10:31:19 [001357] 1: $$$ [TX_TIMEOUT], dlg_state=32
 Заголовок сообщения: Re: Addpac ap100 и D-link 7111s
СообщениеДобавлено: Чт фев 12, 2015 10:12
Здравствуйте. Судя по логам шлюз принимает вызов FXO и отправляет его на номер 701. Опишите схему включения и выложите скриншоты настроек.
СообщениеДобавлено: Чт фев 12, 2015 10:26
АТС - dvg-7111s(FXO) - addpac(fxs) - телефон. У длинка номер 601 у аддпака 701.
Безымянный3.png [ 49.61 KiB | Просмотров: 2770 ]
Безымянный1.png [ 43.51 KiB | Просмотров: 2770 ]
Безымянный.png [ 62.33 KiB | Просмотров: 2770 ]
СообщениеДобавлено: Чт фев 12, 2015 13:40
Приведённые настройки корректные и по логам всё срабатывает нормально. Ещё можно посмотреть дамп трафика между устройствами, если остаётся подозрение на DVG-7111S, но больше похоже, что на втором шлюзе что-то не так.
СообщениеДобавлено: Чт фев 12, 2015 14:44
Спасибо за помощь буду ковырять)
