Текущее время: Чт сен 24, 2026 17:24
 Заголовок сообщения: DVG-5008S на Asterisk 10
СообщениеДобавлено: Ср июл 04, 2012 12:57
Приветствую всех
Возникла проблема с DVG-5008S: при работе с Asterisk 1.6.2.21 устройство работает, а при подключению к Asterisk 10.2.0 НЕТ
Говорит ошибка регистрации - пароли проверил - они идентичные, дважды или трижды вбивал.
Лог с устройства:
15:36:49 *** SLMON start to log ***
15:36:59 [001734] Receive Cmd=1100, ParaLen=5, Para=[Login]
15:36:59 [001734] Login == Ver(1.02.38.43.9367 2009/08/25 17:45:23) PId(242.DLink.NoPrefix.drtp.vlan) Drv(0.9.5.1.1928) Hw(SA7S8) == 0.6.7-1
15:37:00 [001747] 0: Register Retry (Last was rejected)
15:37:00 [001748] 0: 250=REGISTER
15:37:00 [001748] 1: Register Retry (Last was rejected)
15:37:00 [001748] 1: 251=REGISTER
15:37:00 [001749] 0: 250=REGISTER_AUTHN
15:37:01 [001750] 1: 251=REGISTER_AUTHN
15:37:01 [001751] 0: 250=REGISTERFAIL
15:37:01 [001751] 1: 251=REGISTERFAIL
15:37:01 [001752] 0: Register New
15:37:01 [001752] 0: 250=REGISTER
15:37:01 [001752] 1: Register New
15:37:01 [001752] 1: 251=REGISTER
15:37:01 [001754] 0: 250=REGISTER_AUTHN
15:37:01 [001754] 1: 251=REGISTER_AUTHN
15:37:01 [001755] 0: 250=REGISTERFAIL
15:37:01 [001756] 1: 251=REGISTERFAIL
15:37:08 [001827] 2: Register Retry (Last was rejected)
15:37:08 [001828] 2: 252=REGISTER
15:37:08 [001828] 3: Register Retry (Last was rejected)
15:37:08 [001828] 3: 253=REGISTER
15:37:08 [001828] 4: Register Retry (Last was rejected)
15:37:08 [001829] 4: 254=REGISTER
15:37:08 [001829] 5: Register Retry (Last was rejected)
15:37:08 [001829] 5: 255=REGISTER
15:37:08 [001829] 6: Register Retry (Last was rejected)
15:37:08 [001829] 6: 256=REGISTER
15:37:08 [001829] 7: Register Retry (Last was rejected)
Asterisk 1.6.2.21 sip.conf:
[250]
deny=0.0.0.0/0.0.0.0
secret=iAPbbgSjzhiq
dtmfmode=rfc2833
canreinvite=no
context=from-internal
host=dynamic
type=friend
nat=yes
port=5060
qualify=yes
callgroup=
pickupgroup=
dial=SIP/250
accountcode=
mailbox=250@device
permit=0.0.0.0/0.0.0.0
callerid=device <250>
call-limit=50
faxdetect=no
Asterisk 10.2.0 sip.conf:
[250]
secret=iAPbbgSjzhiq
dtmfmode=rfc2833
canreinvite=no
host=dynamic
type=friend
nat=no
port=5060
qualify=yes
dial=SIP/250
mailbox=250@device
trustrpid=yes
sendrpid=no
qualifyfreq=60
transport=udp
encryption=no
callerid=250 <250>
callcounter=yes
faxdetect=no
cc_monitor_policy=generic
Отличия кое-какие есть, но они не принципиальные (тем более, что DVG-4032S работает как на Asterisk 1.6.2.21 так и Asterisk 10.2.0).
При подключении software ip-phone тоже без проблем регистрируется.
Хотелось бы комментариев от support DLINK
 Заголовок сообщения: Re: DVG-5008S на Asterisk 10
СообщениеДобавлено: Ср июл 04, 2012 13:23
Дамп трафика со шлюза можете сделать?
СообщениеДобавлено: Ср июл 04, 2012 15:11
Дамп сессии https://rapidshare.com/files/2951408887/asterisk-10-dvg5008s.rar
PS: Единственно - пароли в сессии в MD5, а в конфиге изненены (чтобы не светить)
СообщениеДобавлено: Чт июл 05, 2012 14:29
ау
СообщениеДобавлено: Пт июл 06, 2012 11:47
И дамп нормальной регистрации
СообщениеДобавлено: Пн июл 09, 2012 05:51
Ну я и говорю - странно. У меня таких железки 2. Сначала на "боевой" настроил - не работает, потом вторую сбросил в ноль, настроил - тоже не работает.
Если бы DVG-4032S не работал или softphone не регистрировался - было бы подозрение на Asterisk 10. А так на двух железках DVG-5008S проблема.
Asterisk брал отсюда - http://downloads.freepbxdistro.org/ISO/ ... 443202.iso
СообщениеДобавлено: Пн июл 09, 2012 09:41
Попробуйте в sip.conf поставить
pedantic=no
Такая же ситуация у меня с нсгейтом была, когда с астериска 1.6 перешёл на 1.8. Может и с длинком прокатит.
