Текущее время: Вс ноя 01, 2026 01:05
СообщениеДобавлено: Ср май 02, 2012 14:50
15:38:39 *** SLMON start to log ***
15:38:49 [024289] Receive Cmd=1100, ParaLen=5, Para=[Login]
15:38:49 [024289] Login == Ver(1.02.38.43.9367 2009/08/25 17:45:23) PId(242.DLink.NoPrefix.drtp.vlan) Drv(0.9.5.1.1928) Hw(SA7O4) == 0.6.7-1
15:39:23 [024630] 0: Fxo Ringing
15:39:24 [024631] 0: RingTime(7) First Stop
15:39:24 [024633] 0: RingTime(46) Second Ring
15:39:26 [024656] 0: CallerId=
15:39:26 [024656] 0: ==17:WaitAnswerDeviceOk
15:39:26 [024656] 0: HotLineEnabled with [701]
15:39:26 [024656] 0: End Input Default Route [2]
15:39:26 [024657] 0: Local Calling Fxo [701]
15:39:26 [024657] 0: ==7:Inviting
15:39:26 [024657] 0: No Free Fxo Line
15:39:26 [024657] 0: Offhook Fxo for PlayBusy
15:39:26 [024657] 0: FxoHookOff
15:39:26 [024657] 0: SetInputGain(-2)
15:39:26 [024657] 0: ==15:PlayBusyTone
15:39:29 [024687] DSP_ch0_check=0
15:39:29 [024687] 0: FxoHookOn
15:39:29 [024687] 0: ==3:Idle
15:39:29 [024688] 0: SetInputGain(4)
15:39:29 [024688] 0: SetFax(0)=0
СообщениеДобавлено: Ср май 02, 2012 15:29
Какие скриншоты добавить ?
СообщениеДобавлено: Чт май 03, 2012 07:07
Вроде разобрался, Все проходит в разные стороны...., а по логу все правильно работает можно сказать ?
07:58:34 ======================================== FXO========================================
07:59:08 [350520] 0: Fxo Ringing
07:59:08 [350521] 0: RingTime(6) First Stop
07:59:08 [350524] 0: RingTime(44) Second Ring
07:59:09 [350536] 0: CallerId=
07:59:09 [350536] 0: ==17:WaitAnswerDeviceOk
07:59:09 [350537] 0: HotLineEnabled with [701]
07:59:09 [350537] 0: End Input Default Route [0]
07:59:09 [350537] 0: PhoneBook has GwNo=701, addr=192.168.1.13:5060
07:59:09 [350537] 0: ==7:Inviting
07:59:10 [350537] 0: VoIP CallOut, Invite <sip:701@192.168.1.13;user=phone>
07:59:10 [350538] 0: 601=DIALING
07:59:10 [350539] 0: 601=PROCEEDING
07:59:10 [350540] 0: 601=RINGBACK
07:59:10 [350540] 0: ==8:RingBack
07:59:13 [350568] 0: 601=CONNECTED
07:59:13 [350568] 0: Peer=192.168.1.13:5010, PT=8, RecvOnly=0
07:59:13 [350568] 0: FxoHookOff
07:59:13 [350568] 0: RtpApiTalk[0,0], Peer=192.168.1.13:5010, PT=8, FC=2, NewOOB=1
07:59:13 [350568] 0: ==14:Talking
07:59:13 [350569] 0: SetTalkMode[1,1]
07:59:26 [350698] 0: 601=DISCONNECT
07:59:26 [350698] 0: Release Active Dlg
07:59:26 [350698] 0: ==15:PlayBusyTone
07:59:29 [350728] DSP_ch0_check=0
07:59:29 [350728] 0: FxoHookOn
07:59:29 [350728] 0: ==3:Idle
07:59:29 [350729] 0: SetFax(0)=0
08:00:59 ======================================== SIP========================================
08:01:04 [351678] 5: =OFFERING
08:01:04 [351678] 5: Get CallerId=305
08:01:04 [351678] 5: Default Dial-Out []
08:01:04 [351678] 5: Check Trunk FixLine
08:01:04 [351678] 5: Hunting Trunk Line
08:01:04 [351678] 0: Peer=192.168.1.13:5018, PT=8, RecvOnly=0
08:01:04 [351678] 0: TrunkPrefix=, Dest=, Dialno=
08:01:04 [351678] 0: FxoHookOff
08:01:04 [351678] 0: ==18:TrunkDialOut
08:01:04 [351679] 0: Fxo DialOut OK
08:01:04 [351680] 5: =ACCEPT
08:01:04 [351680] 0: ==13:VoipAnswering
08:01:04 [351681] 5: =CONNECTED
08:01:04 [351681] 0: RtpApiTalk[1,1], Peer=192.168.1.13:5018, PT=8, FC=10, NewOOB=1
08:01:04 [351681] 0: ==14:Talking
08:01:05 [351694] 0: Play(3)
08:01:06 [351701] 0: Play(0)
08:01:06 [351704] 0: Play(0)
08:01:07 [351709] 0: Play(0)
08:01:07 [351711] 0: Play(0)
08:01:32 [351967] 5: =DISCONNECT
08:01:32 [351967] 0: Release Active Dlg
08:01:32 [351967] 0: ==15:PlayBusyTone
08:01:33 [351968] 0: Start Btc Learning
08:01:33 [351973] 0: Btc Learning Exception Len 0
08:01:33 [351973] DSP_ch0_check=0
08:01:33 [351973] 0: FxoHookOn
08:01:33 [351973] 0: ==3:Idle
08:01:33 [351974] 0: SetFax(0)=0
СообщениеДобавлено: Чт май 10, 2012 10:31
Ничего криминального в логе не вижу.
