Текущее время: Ср сен 23, 2026 18:49
 Заголовок сообщения: Проблема с входящими с PSTN на DVG-7111S
СообщениеДобавлено: Вт июн 21, 2011 23:31
К DVG-7111S подключены линия МГТС и обычный аналоговый телефон. Для FXO в качестве HotLine указан FXS.
Входящий вызов с PSTN доходит до FXS, но в виде нескольки отдельных вызовов. Вот лог, где
на один входящий с PSTN получается 3 отдельных вызова на FXS.
20:46:17 *** SLMON start to log ***
20:46:27 [000843] Receive Cmd=1100, ParaLen=5, Para=[Login]
20:46:27 [000843] Login RU_1.00 == Ver(1.02.38.56.2876 2010/05/21 14:06:11) PId(281.DLink.RU.DecodeProf.DhcpOpt195.l2tp.DualAccess.NoPrefix.drtp) Drv(0.10.55.1
20:46:27 ) Hw(TSO) == 0.6.8
20:46:37 [000938] 1: Fxo Ringing
20:46:37 [000939] 1: RingTime(98) First Stop
20:46:42 [000988] 1: RingTime(100) Second Ring
20:46:42 [000988] 1: CallerId=
20:46:42 [000988] 1: ==17:WaitAnswerDeviceOk
20:46:42 [000988] 1: HotLineEnabled with [fxs.port]
20:46:42 [000988] 1: End Input Default Route [0]
20:46:42 [000988] 1: Local Calling Fxs [fxs.port]
20:46:42 [000989] 1: ==7:Inviting
20:46:42 [000989] 0: Local Called By Line 1
20:46:42 [000989] 0: ==12:Alerting
20:46:42 [000989] 1: ==8:RingBack
20:46:47 [001039] 1: RingTime Stopped
20:46:47 [001039] 1: Cancel at Ringback
20:46:47 [001039] 1: ==15:PlayBusyTone
20:46:47 [001039] 0: ==3:Idle
20:46:47 [001039] 0: SetFax(1)=0
20:46:47 [001039] 0: SetModem(0)=-1
20:46:47 [001040] 1: FxoHookOn
20:46:47 [001040] 1: ==3:Idle
20:46:47 [001040] 1: SetFax(1)=0
20:46:47 [001040] 1: SetModem(0)=-1
20:46:52 [001088] 1: Fxo Ringing
20:46:52 [001089] 1: RingTime(102) First Stop
20:46:57 [001138] 1: CallerId=
20:46:57 [001138] 1: ==17:WaitAnswerDeviceOk
20:46:57 [001138] 1: HotLineEnabled with [fxs.port]
20:46:57 [001138] 1: End Input Default Route [0]
20:46:57 [001138] 1: Local Calling Fxs [fxs.port]
20:46:57 [001138] 1: ==7:Inviting
20:46:57 [001138] 0: Local Called By Line 1
20:46:57 [001139] 0: ==12:Alerting
20:46:57 [001139] 1: ==8:RingBack
20:46:59 [001158] 1: RingTime Stopped
20:46:59 [001158] 1: Cancel at Ringback
20:46:59 [001158] 1: ==15:PlayBusyTone
20:46:59 [001158] 0: ==3:Idle
20:46:59 [001159] 0: SetFax(1)=0
20:46:59 [001159] 0: SetModem(0)=-1
20:46:59 [001159] 1: FxoHookOn
20:46:59 [001159] 1: ==3:Idle
20:46:59 [001159] 1: SetFax(1)=0
20:46:59 [001159] 1: SetModem(0)=-1
20:47:02 [001187] 1: Fxo Ringing
20:47:02 [001188] 1: RingTime(87) First Stop
20:47:09 [001257] 1: RingTime Stopped
20:47:09 [001257] 1: ==3:Idle
20:47:09 [001257] 1: SetFax(1)=0
20:47:09 [001257] 1: SetModem(0)=-1
Как заставить устройство работать правильно?
СообщениеДобавлено: Вт июн 28, 2011 23:52
И тишина... :evil:
Тут техподдержка есть? Или после оплаты я уже никому тут не интересен?
СообщениеДобавлено: Ср июн 29, 2011 11:02
Модератор
Модератор
Указывайте в HotLine номер порта, 701, вместо fxs.port
Виктор Колосов
СообщениеДобавлено: Чт июн 30, 2011 22:54
Как-бы это помягче сказать...
Спецификации SIP не накладывают подобных ограничений. Но будь по вашему, сбросил всё в дефолт, но проблема осталась:
21:42:35 *** SLMON start to log ***
21:42:45 [001266] Receive Cmd=1100, ParaLen=5, Para=[Login]
21:42:45 [001266] Login RU_1.00 == Ver(1.02.38.56.2876 2010/05/21 14:06:11) PId(281.DLink.RU.DecodeProf.DhcpOpt195.l2tp.DualAccess.NoPrefix.drtp) Drv(0.10.55.1
21:42:45 ) Hw(TSO) == 0.6.8
21:43:20 [001618] 1: Fxo Ringing
21:43:20 [001618] 1: CallerId=
21:43:20 [001618] 1: ==17:WaitAnswerDeviceOk
21:43:20 [001618] 1: HotLineEnabled with [701]
21:43:20 [001618] 1: End Input Default Route [0]
21:43:20 [001618] 1: Local Calling Fxs [701]
21:43:20 [001618] 1: ==7:Inviting
21:43:20 [001618] 0: Local Called By Line 1
21:43:20 [001619] 0: ==12:Alerting
21:43:20 [001619] 1: ==8:RingBack
21:43:20 [001619] 1: RingTime(100) First Stop
21:43:27 [001688] 1: RingTime Stopped
21:43:27 [001688] 1: Cancel at Ringback
21:43:27 [001688] 1: ==15:PlayBusyTone
21:43:27 [001689] 0: ==3:Idle
21:43:27 [001689] 0: SetFax(1)=0
21:43:27 [001689] 0: SetModem(0)=-1
21:43:27 [001689] 1: FxoHookOn
21:43:27 [001689] 1: ==3:Idle
21:43:27 [001689] 1: InputGain(6)
21:43:27 [001689] 1: SetFax(1)=0
21:43:27 [001689] 1: SetModem(0)=-1
21:43:30 [001718] 1: Fxo Ringing
21:43:30 [001718] 1: CallerId=
21:43:30 [001718] 1: ==17:WaitAnswerDeviceOk
21:43:30 [001718] 1: HotLineEnabled with [701]
21:43:30 [001718] 1: End Input Default Route [0]
21:43:30 [001718] 1: Local Calling Fxs [701]
21:43:30 [001718] 1: ==7:Inviting
21:43:30 [001718] 0: Local Called By Line 1
21:43:30 [001719] 0: ==12:Alerting
21:43:30 [001719] 1: ==8:RingBack
21:43:30 [001719] 1: RingTime(100) First Stop
21:43:37 [001788] 1: RingTime Stopped
21:43:37 [001788] 1: Cancel at Ringback
21:43:37 [001788] 1: ==15:PlayBusyTone
21:43:37 [001789] 0: ==3:Idle
21:43:37 [001789] 0: SetFax(1)=0
21:43:37 [001789] 0: SetModem(0)=-1
21:43:37 [001789] 1: FxoHookOn
21:43:37 [001789] 1: ==3:Idle
21:43:37 [001789] 1: InputGain(6)
21:43:37 [001789] 1: SetFax(1)=0
21:43:37 [001789] 1: SetModem(0)=-1
21:43:40 [001818] 1: Fxo Ringing
21:43:40 [001818] 1: CallerId=
21:43:40 [001818] 1: ==17:WaitAnswerDeviceOk
21:43:40 [001818] 1: HotLineEnabled with [701]
21:43:40 [001818] 1: End Input Default Route [0]
21:43:40 [001818] 1: Local Calling Fxs [701]
21:43:40 [001818] 1: ==7:Inviting
21:43:40 [001818] 0: Local Called By Line 1
21:43:40 [001819] 0: ==12:Alerting
21:43:40 [001819] 1: ==8:RingBack
21:43:40 [001819] 1: RingTime(98) First Stop
21:43:47 [001888] 1: RingTime Stopped
21:43:47 [001888] 1: Cancel at Ringback
21:43:47 [001888] 1: ==15:PlayBusyTone
21:43:47 [001888] 0: ==3:Idle
21:43:47 [001888] 0: SetFax(1)=0
21:43:47 [001888] 0: SetModem(0)=-1
21:43:47 [001888] 1: FxoHookOn
21:43:47 [001888] 1: ==3:Idle
21:43:47 [001889] 1: InputGain(6)
21:43:47 [001889] 1: SetFax(1)=0
21:43:47 [001889] 1: SetModem(0)=-1
21:43:50 [001918] 1: Fxo Ringing
21:43:50 [001918] 1: CallerId=
21:43:50 [001918] 1: ==17:WaitAnswerDeviceOk
21:43:50 [001918] 1: HotLineEnabled with [701]
21:43:50 [001918] 1: End Input Default Route [0]
21:43:50 [001918] 1: Local Calling Fxs [701]
21:43:50 [001918] 1: ==7:Inviting
21:43:50 [001918] 0: Local Called By Line 1
21:43:50 [001919] 0: ==12:Alerting
21:43:50 [001919] 1: ==8:RingBack
21:43:50 [001919] 1: RingTime(102) First Stop
21:43:57 [001988] 1: RingTime Stopped
21:43:57 [001988] 1: Cancel at Ringback
21:43:57 [001988] 1: ==15:PlayBusyTone
21:43:57 [001988] 0: ==3:Idle
21:43:57 [001988] 0: SetFax(1)=0
21:43:57 [001988] 0: SetModem(0)=-1
21:43:57 [001988] 1: FxoHookOn
21:43:57 [001989] 1: ==3:Idle
21:43:57 [001989] 1: InputGain(6)
21:43:57 [001989] 1: SetFax(1)=0
21:43:57 [001989] 1: SetModem(0)=-1
21:44:00 [002018] 1: Fxo Ringing
21:44:00 [002018] 1: CallerId=
21:44:00 [002018] 1: ==17:WaitAnswerDeviceOk
21:44:00 [002018] 1: HotLineEnabled with [701]
21:44:00 [002018] 1: End Input Default Route [0]
21:44:00 [002018] 1: Local Calling Fxs [701]
21:44:00 [002018] 1: ==7:Inviting
21:44:00 [002018] 0: Local Called By Line 1
21:44:00 [002019] 0: ==12:Alerting
21:44:00 [002019] 1: ==8:RingBack
21:44:00 [002019] 1: RingTime(102) First Stop
21:44:07 [002088] 1: RingTime Stopped
21:44:07 [002088] 1: Cancel at Ringback
21:44:07 [002088] 1: ==15:PlayBusyTone
21:44:07 [002088] 0: ==3:Idle
21:44:07 [002088] 0: SetFax(1)=0
21:44:07 [002088] 0: SetModem(0)=-1
21:44:07 [002089] 1: FxoHookOn
21:44:07 [002089] 1: ==3:Idle
21:44:07 [002089] 1: InputGain(6)
21:44:07 [002089] 1: SetFax(1)=0
21:44:07 [002089] 1: SetModem(0)=-1
21:44:10 [002118] 1: Fxo Ringing
21:44:10 [002118] 1: CallerId=
21:44:10 [002118] 1: ==17:WaitAnswerDeviceOk
21:44:10 [002118] 1: HotLineEnabled with [701]
21:44:10 [002118] 1: End Input Default Route [0]
21:44:10 [002118] 1: Local Calling Fxs [701]
21:44:10 [002118] 1: ==7:Inviting
21:44:10 [002118] 0: Local Called By Line 1
21:44:10 [002118] 0: ==12:Alerting
21:44:10 [002118] 1: ==8:RingBack
21:44:10 [002119] 1: RingTime(100) First Stop
21:44:17 [002188] 1: RingTime Stopped
21:44:17 [002188] 1: Cancel at Ringback
21:44:17 [002188] 1: ==15:PlayBusyTone
21:44:17 [002188] 0: ==3:Idle
21:44:17 [002188] 0: SetFax(1)=0
21:44:17 [002188] 0: SetModem(0)=-1
21:44:17 [002188] 1: FxoHookOn
21:44:17 [002188] 1: ==3:Idle
21:44:17 [002188] 1: InputGain(6)
21:44:17 [002188] 1: SetFax(1)=0
21:44:17 [002188] 1: SetModem(0)=-1
21:44:20 [002218] 1: Fxo Ringing
21:44:20 [002218] 1: CallerId=
21:44:20 [002218] 1: ==17:WaitAnswerDeviceOk
21:44:20 [002218] 1: HotLineEnabled with [701]
21:44:20 [002218] 1: End Input Default Route [0]
21:44:20 [002218] 1: Local Calling Fxs [701]
21:44:20 [002218] 1: ==7:Inviting
21:44:20 [002218] 0: Local Called By Line 1
21:44:20 [002218] 0: ==12:Alerting
21:44:20 [002218] 1: ==8:RingBack
21:44:20 [002219] 1: RingTime(102) First Stop
21:44:27 [002288] 1: RingTime Stopped
21:44:27 [002288] 1: Cancel at Ringback
21:44:27 [002288] 1: ==15:PlayBusyTone
21:44:27 [002288] 0: ==3:Idle
21:44:27 [002288] 0: SetFax(1)=0
21:44:27 [002288] 0: SetModem(0)=-1
21:44:27 [002288] 1: FxoHookOn
21:44:27 [002288] 1: ==3:Idle
21:44:27 [002288] 1: InputGain(6)
21:44:27 [002288] 1: SetFax(1)=0
21:44:27 [002288] 1: SetModem(0)=-1
почему вот это происходит?
[code21:43:20 [001619] 1: RingTime(100) First Stop
21:43:27 [001688] 1: RingTime Stopped][/code]
стабильно через 7 сек.
PSTN Ring OFF Length: 5000 (в линии 1 сек - сигнал вызова, 4 сек - пауза)
Изменение этого параметра (пробовал от 1000 до 10000) проблему не решает.
СообщениеДобавлено: Пн июл 04, 2011 10:21
Модератор
Модератор
Проверьте, выставленны ли галки в полях
Enable FXO/Trunk Extension Number:
Pick up Line by Dialing Extension Number:
Enable Non-SIP Inbox Call
Виктор Колосов
СообщениеДобавлено: Чт июл 07, 2011 00:13
Да, все 3 галки стоят.
Есть у меня ещё аппрат Planet VIP-480, сэмулировал на нём PSTN, даже частоты вызывного сигнала подстроил как у меня на МГТС - с него звонки нормально идут.
СообщениеДобавлено: Пт июл 15, 2011 13:08
На этом поддержка окончена?
