Текущее время: Пт окт 30, 2026 08:42
 Заголовок сообщения: Помогите 7022s -> internet <- 7111s
СообщениеДобавлено: Ср мар 16, 2011 12:14
настраивал в локальной сети все работало... когда отвез 7111s на удаленный офис звонок не проходит, на роутерах настрол проброс порта 5060 UDP сигнал вызова на VoIP приходит но потом выдает занято....
Лог 7022s:
09:26:33 *** SLMON start to log ***
09:26:43 [547378] Receive Cmd=1100, ParaLen=5, Para=[Login]
09:26:43 [547378] Login == Ver(1.02.38.28.8749 2008/08/22 15:48:39) PId(242.DLink.NoPrefix.drtp.vlan) Drv(0.9.5.1.1140 30/Jul/2008 12:27:59) Hw(IAD202) == 0.6.
09:26:43 7-1
// исходящий звонок на 7111s
09:26:58 [547532] 0: Fxs Pickup
09:26:58 [547532] 0: HotLineEnabled with [702]
09:26:58 [547532] 0: End Input Default Route [0]
09:26:58 [547532] 0: PhoneBook has GwNo=702, addr=195.58.239.102:5060
09:26:58 [547532] 0: ==7:Inviting
09:26:58 [547532] 0: VoIP CallOut, Invite <sip:702@195.58.239.102:5060;user=phone>
09:26:58 [547534] 0: 603=DIALING
09:27:06 [547612] 0: Inviting Timeout, Try Local Fxo ========
09:27:06 [547612] 0: Local Calling Fxo [702]
09:27:06 [547613] 0: Get Local Fxo Line 2
09:27:06 [547613] 2: TrunkPrefix=, Dest=702, Dialno=702
09:27:06 [547613] 2: FxoHookOff
09:27:06 [547613] 2: SetInputGain(-2)
09:27:06 [547613] 2: ==18:TrunkDialOut
09:27:07 [547623] 2: DialOut(702)=0
09:27:08 [547630] 2: Fxo DialOut OK
09:27:08 [547630] 2: Local Talk at ToAnswer
09:27:08 [547630] 2: RtpApiTalk[1,1], Peer=127.0.0.1:9000, PT=0, FC=4, NewOOB=0
09:27:08 [547630] 0: Local Talk at RingBack
09:27:08 [547630] 0: RtpApiTalk[1,1], Peer=127.0.0.1:9004, PT=0, FC=4, NewOOB=0
09:27:08 [547630] 2: ==14:Talking
09:27:08 [547631] 0: ==14:Talking
09:27:10 [547653] 2: Fxo Detected BTC(0)
09:27:10 [547653] DSP_ch2_check=0
09:27:10 [547653] 2: FxoHookOn
09:27:10 [547653] 2: Bye at Talking
09:27:10 [547654] 2: ==15:PlayBusyTone
09:27:11 [547654] 0: ==15:PlayBusyTone
09:27:11 [547654] DSP_ch2_check=0
09:27:11 [547654] 2: FxoHookOn
09:27:11 [547654] 2: ==3:Idle
09:27:11 [547654] 2: SetInputGain(4)
09:27:11 [547654] 2: SetFax(1)=0
09:27:18 [547729] DSP_ch0_check=0
09:27:18 [547729] 0: Fxs Hangup
09:27:18 [547729] 0: ==3:Idle
09:27:18 [547729] 0: SetFax(1)=0
// теперь входящий звонок от 7111s
09:32:13 [550685] 2: 601=OFFERING
09:32:13 [550685] 2: Get CallerId=701
09:32:14 [550685] 2: Peer=192.168.1.205:9000, PT=0, RecvOnly=0
09:32:14 [550685] 2: TrunkPrefix=, Dest=, Dialno=
09:32:14 [550685] 2: FxoHookOff
09:32:14 [550685] 2: SetInputGain(-2)
09:32:14 [550685] 2: ==18:TrunkDialOut
09:32:14 [550686] 2: Fxo DialOut OK
09:32:14 [550687] 2: 601=ACCEPT
09:32:14 [550687] 2: ==13:VoipAnswering
09:32:26 [550808] 2: Fxo Detected BTC(0)
09:32:26 [550808] DSP_ch2_check=0
09:32:26 [550808] 2: FxoHookOn
09:32:26 [550809] 2: ==15:PlayBusyTone
09:32:26 [550809] DSP_ch2_check=0
09:32:26 [550809] 2: FxoHookOn
09:32:26 [550809] 2: ==3:Idle
09:32:26 [550809] 2: SetInputGain(4)
09:32:26 [550809] 2: SetFax(1)=0
 Заголовок сообщения: Re: Помогите 7022s -> internet <- 7111s
СообщениеДобавлено: Ср мар 16, 2011 12:29
лог со второго шлюза выложите.
СообщениеДобавлено: Ср мар 16, 2011 12:32
воть
я звоню на него
11:38:53 [004592] Receive Cmd=1100, ParaLen=5, Para=[Login]
11:38:53 [004592] Login RU_1.00 == Ver(1.02.38.39.2597 2009/06/25 13:29:25) PId(281.DLink.RU.DecodeProf.DhcpOpt195.l2tp.DualAccess.NoPrefix.drtp) Drv(0.10.37.1
11:38:53 ) Hw(TSO) == 0.6.8
11:39:33 [004991] Receive Cmd=1100, ParaLen=5, Para=[Login]
11:39:33 [004991] Login RU_1.00 == Ver(1.02.38.39.2597 2009/06/25 13:29:25) PId(281.DLink.RU.DecodeProf.DhcpOpt195.l2tp.DualAccess.NoPrefix.drtp) Drv(0.10.37.1
11:39:33 ) Hw(TSO) == 0.6.8
11:39:40 [005060] 1: 702=OFFERING
11:39:40 [005060] 1: Get CallerId=603
11:39:40 [005060] 1: Peer=192.168.0.113:9000, PT=0, RecvOnly=0
11:39:40 [005060] 1: TrunkPrefix=, Dest=, Dialno=
11:39:40 [005060] 1: FxoHookOff
11:39:40 [005060] 1: SetInputGain(0)
11:39:40 [005060] 1: ==18:TrunkDialOut
11:39:40 [005061] 1: Fxo DialOut OK
11:39:40 [005062] 1: 702=ACCEPT
11:39:40 [005062] 1: ==13:VoipAnswering
11:39:52 [005183] 1: Fxo Detected BTC(0)
11:39:52 [005183] 1: FxoHookOn
11:39:52 [005183] 1: ==15:PlayBusyTone
11:39:52 [005184] 1: FxoHookOn
11:39:52 [005184] 1: ==3:Idle
11:39:52 [005184] 1: SetInputGain(6)
11:39:52 [005184] 1: SetFax(1)=0
звонок с него на 7022s
11:40:35 [005617] 0: Fxs Pickup
11:40:35 [005617] 0: HotLineEnabled with [601]
11:40:35 [005617] 0: End Input Default Route [0]
11:40:35 [005617] 0: PhoneBook has GwNo=601, addr=195.225.157.188:5060
11:40:35 [005617] 0: ==7:Inviting
11:40:36 [005617] 0: VoIP CallOut, Invite <sip:601@195.225.157.188;user=phone>
11:40:36 [005618] 0: 701=DIALING
11:40:43 [005697] 0: Inviting Timeout, Try Local Fxo ========
11:40:43 [005697] 0: Local Calling Fxo [601]
11:40:43 [005697] 0: Get Local Fxo Line 1
11:40:44 [005697] 1: TrunkPrefix=, Dest=601, Dialno=601
11:40:44 [005697] 1: FxoHookOff
11:40:44 [005697] 1: SetInputGain(0)
11:40:44 [005697] 1: ==18:TrunkDialOut
11:40:44 [005708] 1: DialOut(601)=0
11:40:45 [005716] 1: Fxo DialOut OK
11:40:45 [005716] 1: Local Talk at ToAnswer
11:40:45 [005716] 1: RtpApiTalk[1,1], Peer=192.168.1.205:9000, PT=0, FC=4, NewOOB=0
11:40:45 [005716] 0: Local Talk at RingBack
11:40:45 [005716] 0: RtpApiTalk[1,1], Peer=192.168.1.205:9002, PT=0, FC=4, NewOOB=0
11:40:46 [005716] 1: ==14:Talking
11:40:46 [005717] 0: ==14:Talking
11:40:52 [005783] 1: Fxo Detected BTC(0)
11:40:52 [005783] 1: FxoHookOn
11:40:52 [005783] 1: Bye at Talking
11:40:52 [005783] 1: ==15:PlayBusyTone
11:40:52 [005784] 0: ==15:PlayBusyTone
11:40:52 [005784] 1: FxoHookOn
11:40:52 [005784] 1: ==3:Idle
11:40:52 [005784] 1: SetInputGain(6)
11:40:53 [005784] 1: SetFax(1)=0
11:41:02 [005880] 0: Fxs Hangup
11:41:02 [005880] 0: ==3:Idle
11:41:02 [005880] 0: SetFax(1)=0
СообщениеДобавлено: Чт мар 17, 2011 00:54
Схему сети опишите подробнее.
СообщениеДобавлено: Чт мар 17, 2011 10:49
МиниАТС TDA30 -> VoIP 7022s -> windows 2008 R2 (инет раздает) -> инет <- Asus WL-500GP <- VoIP 7111s <- миниАТС T616
CO5, CO6 в FXS 1-2, EXT120, EXT121 в FXO 1,2 <---------------------------------------------------------------------> CO2 в FXS, EXT25 в FXO
1 FXS - 603 Hotline 702 (PhoneBook 702 ip асуса порт 5060) <-> Hotline 601 (PhoneBook 601 ip win2008 порт 5060) 701 - FXS 1
2 FXS - 604 -------------------------------------------------------------------------------------------------------------------------------------------------------- 702 - FXO 2
3 FXO - 601
4 FXO - 602
Проброс портов настроил и на асусе и в винде, порт пробрасую только 5060, на асусе и TCP и UDP, на win2008 только UDP
если шлюзы в одной локальной сети то все работает
Последний раз редактировалось MrZaYaC Чт мар 17, 2011 11:16, всего редактировалось 1 раз.
СообщениеДобавлено: Чт мар 17, 2011 11:15
укажите NAt public IP в Advanced --> nat traversal на 7111 NAt/ddns --> NAT publc ip на 7022
СообщениеДобавлено: Чт мар 17, 2011 11:59
Заработало, но еще нужно пробросить порт 9000 почему то...
СообщениеДобавлено: Чт мар 17, 2011 16:22
вот еще проблема обнаружилась, когда я звоню с TDA30 на T616 все нормально, а когда наоборот то шлюзы сигнал пробрасывают, я сигнал атс слышу, но когда набираю номер, то занято, я думаю что это из за настроек внешней линии на t616, завтра поеду туда проверю...
СообщениеДобавлено: Пн мар 21, 2011 12:26
поменял t616 на TA308 проблема осталась. я звоню все нормально, но когда звонят ко мне то при выходе на линию сигнал гудка слышно, но при наборе номера ничего не происходит, в трубке остается непрерывный гудок... что делать? какие настройки смотреть?
