Текущее время: Пт окт 30, 2026 20:36
СообщениеДобавлено: Ср мар 02, 2011 14:08
Здравствуйте. Проблема с настройкой оборудования.
Мануал: http://dlink.ru/up/uploads_media/FAQ/p2p_7111-2102.pdf.
Звонки проходят в одну сторону от DVG-7111S к DVG-2102S. Обратно, после набора номера, идет сброс.
Лог DVG-2102S:
13:49:45 *** SLMON start to log ***
13:49:55 [023385] Receive Cmd=1100, ParaLen=5, Para=[Login]
13:49:56 [023385] Login GE_1.00 == Ver(1.02.38.39.1651 2009/07/07 14:14:18) PId(282.DLink.l2tp.DualAccess.MultiServer.NoPrefix.TR069.drtp) Drv(0.10.37.1) Hw(DS
13:49:56 A) ==
13:50:14 [023570] 0: Fxs Pickup
13:50:14 [023570] 0: HotLineEnabled with [601]
13:50:14 [023570] 0: End Input Default Route [0]
13:50:14 [023570] 0: PhoneBook has GwNo=601, addr=10.200.0.12:5060
13:50:14 [023570] 0: ==7:Inviting
13:50:14 [023570] 0: VoIP CallOut, Invite <sip:601@10.200.0.12;user=phone>
13:50:15 [023572] 0: 701=DIALING
13:50:15 [023573] 0: 701=PROCEEDING
13:50:15 [023576] 0: 701=CONNECTED
13:50:15 [023576] 0: Peer=10.200.0.12:9002, PT=18, RecvOnly=0
13:50:15 [023576] 0: RtpApiTalk[1,1], Peer=10.200.0.12:9002, PT=18, FC=2, NewOOB=0
13:50:15 [023576] 0: ==14:Talking
13:50:24 [023668] 0: 701=DISCONNECT
13:50:24 [023668] 0: Release Active Dlg
13:50:24 [023668] 0: ==15:PlayBusyTone
13:50:30 [023731] 0: Fxs Hangup
13:50:30 [023732] 0: ==3:Idle
13:50:30 [023732] 0: SetFax(1)=0
Лог DVG-7111S:
13:49:53 *** SLMON start to log ***
13:50:03 [026093] Receive Cmd=1100, ParaLen=5, Para=[Login]
13:50:03 [026093] Login RU_1.00 == Ver(1.02.38.54.2846 2010/04/15 17:34:03) PId(281.DLink.RU.DecodeProf.DhcpOpt195.l2tp.DualAccess.NoPrefix.drtp) Drv(0.10.47.1
13:50:03 ) Hw(TSO) == 0.6.8
13:50:14 [026205] 1: 601=OFFERING
13:50:14 [026205] 1: Get CallerId=701
13:50:14 [026205] 1: Peer=10.200.0.11:9000, PT=18, RecvOnly=0
13:50:14 [026205] 1: TrunkPrefix=, Dest=, Dialno=
13:50:15 [026205] 1: FxoHookOff
13:50:15 [026205] 1: ==18:TrunkDialOut
13:50:15 [026206] 1: Fxo DialOut OK
13:50:15 [026207] 1: 601=ACCEPT
13:50:15 [026207] 1: ==13:VoipAnswering
13:50:15 [026209] 1: 601=CONNECTED
13:50:15 [026209] 1: RtpApiTalk[1,1], Peer=10.200.0.11:9000, PT=18, FC=2, NewOOB=0
13:50:15 [026209] 1: ==14:Talking
13:50:23 [026298] 1: Fxo Detected BTC(0)
13:50:23 [026298] 1: FxoHookOn
13:50:24 [026298] 1: Bye at Talking
13:50:24 [026298] 1: ==15:PlayBusyTone
13:50:24 [026299] 1: FxoHookOn
13:50:24 [026299] 1: ==3:Idle
13:50:24 [026299] 1: SetFax(1)=0
13:50:24 [026299] 1: SetModem(0)=-1
13:50:24 [026300] 1: 601=DISCONNECT
13:50:25 [026300] 1: Release Old Dlg #2
Подскажите решение. Спасибо.
СообщениеДобавлено: Ср мар 02, 2011 14:38
Скриншот Hot Line на 7111 выложите пожалуйста.
СообщениеДобавлено: Ср мар 02, 2011 15:04
Скриншот: http://zalil.ru/30600115
СообщениеДобавлено: Ср мар 02, 2011 15:14
Еще требуется скриншот Cpt/cadence settings.
СообщениеДобавлено: Ср мар 02, 2011 15:19
Скриншот: http://zalil.ru/30600217
СообщениеДобавлено: Ср мар 02, 2011 15:30
Попробуйте BTC detection senstivity поставить на 2. Также выложите скриншоты DTMF&pulse со шлюзов.
СообщениеДобавлено: Ср мар 02, 2011 15:42
Скриншот: http://zalil.ru/30600377
СообщениеДобавлено: Ср мар 02, 2011 16:03
Enable out-of-band dtmf включите и поставьте на RFC2833 на двух шлюзах
СообщениеДобавлено: Ср мар 02, 2011 16:24
Сделал. На телефоне который подключен к 2102S пропали помехи.
Снимаем трубку, слышим гудок, набираем номер, почти сразу же слышим гудок свободной линии и через некоторое время идет сброс.
Скриншот с логами: http://zalil.ru/30600786
.11 - DVG-2102S
.12 - DVG-7111S
СообщениеДобавлено: Ср мар 02, 2011 16:42
У вас 7111 ловит сигнал занято. Попробуйте на другой линии.
