Текущее время: Сб окт 31, 2026 10:52
 Заголовок сообщения: 6008 + 5008
СообщениеДобавлено: Сб дек 11, 2010 12:57
Дано: DVG-6008S и DVG-5008S
Для обычного проброса линий через инет.
6008: Current Software Version No. [1.02.37.61]
модем DLink 2500U
5008: Current Software Version No. [1.02.37.61]
модем от провайдера Megaline (похож на TPLink)
При поднятии трубки на 5008 гудка не слышно, через 15 секунд выдается занято, на 6008 в логах следующее:
15:26:12 [002580] 0: 601=OFFERING
15:26:12 [002580] 0: Get CallerId=701
15:26:12 [002580] 0: Peer=178.89.167.74:10046, PT=2, RecvOnly=0
15:26:12 [002580] 0: TrunkPrefix=, Dest=, Dialno=
15:26:12 [002580] 0: FxoHookOff
15:26:12 [002580] 0: SetInputGain(-2)
15:26:12 [002580] 0: ==18:TrunkDialOut
15:26:12 [002581] 0: Fxo DialOut OK
15:26:12 [002582] 0: 601=ACCEPT
15:26:12 [002582] 0: ==13:VoipAnswering
15:26:30 [002759] 0: Fxo Detected BTC(2)
15:26:30 [002759] DSP_ch0_check=0
15:26:30 [002759] 0: FxoHookOn
15:26:30 [002760] 0: ==15:PlayBusyTone
15:26:30 [002760] DSP_ch0_check=0
15:26:30 [002760] 0: FxoHookOn
15:26:30 [002760] 0: ==3:Idle
15:26:30 [002760] 0: SetInputGain(4)
15:26:30 [002760] 0: SetFax(1)=0
На 5008 лог:
15:29:24 [002441] 0: Fxs Pickup
15:29:24 [002441] 0: HotLineEnabled with [601]
15:29:24 [002441] 0: End Input Default Route [0]
15:29:24 [002441] 0: OutPinCode=<>, dial_no=<601>
15:29:24 [002441] 0: PhoneBook has GwNo=601, addr=тут_днс_6008-й:5060
15:29:24 [002441] *** Start Dns Query [тут_днс_6008-й] #1
15:29:24 [002441] 0: ==6:DnsQuerying
15:29:24 [002443] 0: ==7:Inviting
15:29:24 [002443] 0: VoIP CallOut, Invite <sip:601@89.218.98.159:5060;user=phone>
15:29:24 [002444] 0: 701=DIALING
15:29:25 [002446] 0: 701=PROCEEDING
15:29:25 [002449] 0: 701=CONNECTED
15:29:25 [002449] 0: Peer=192.168.2.201:9000, PT=2, RecvOnly=0
15:29:25 [002449] 0: RtpApiTalk[1,1], Peer=192.168.2.201:9000, PT=2, FC=2, NewOOB=0
15:29:25 [002449] 0: ==14:Talking
15:29:43 [002627] 0: 701=DISCONNECT
15:29:43 [002627] 0: Release Active Dlg
15:29:43 [002627] 0: ==15:PlayBusyTone
15:29:52 [002721] DSP_ch0_check=0
15:29:52 [002721] 0: Fxs Hangup
15:29:52 [002721] 0: ==3:Idle
15:29:52 [002721] 0: SetFax(1)=0
Пробовали в локальной сети - все работает. Похоже, дело в настройке модемов, но куда копать - непонятно.
На модемах настроен Virtual Server на UDP 5060 --> WAN шлюза:5060
Увидел в портах цифру 9000 - от отчаяния настроил и 9000-й порт на проброс туда же, хотя ежу ясно, что это порт исходящий :)
CPT Autolearning отключил, впрочем, подозреваю, что оно тут ни при чем тоже.
Подскажите пожалуйста, куда копать...
 Заголовок сообщения: Re: 6008 + 5008
СообщениеДобавлено: Сб дек 11, 2010 19:29
Всем спасибо, проблема решилась установкой галки "NAT Public IP" и прописыванием текущего днс имени каждого аппарата соответственно в NAT IP/Domain.
:D
