Текущее время: Вт сен 29, 2026 11:26
 Заголовок сообщения: Помогите разобраться с DVG-7022
СообщениеДобавлено: Ср мар 03, 2010 08:43
дравствуте. Подскажите пожалуйста в чем может быть проблема если не получается позвонить с одного люза на другой. Вот первый лог шлюза с которого звоню
[014542] Receive Cmd=1100, ParaLen=5, Para=[Login]
[014542] Login == Ver(1.02.38.28.8749 2008/08/22 15:48:39) PId(242.DLink.NoPrefix.drtp.vlan) Drv(0.9.5.1.1140 30/Jul/2008 12:27:59) Hw(IAD202) == 0.6.7-1
[015117] 0: Fxs Pickup
[015117] 0: ==4:GetDtmf
[015185] 0: DTMF Timeout #1
[015185] 0: End Input Default Route [0]
[015185] 0: Line DialNum_New [601]
[015185] 0: PhoneBook has GwNo=601, addr=192.168.14.8:5060
[015185] 0: ==7:Inviting
[015185] 0: VoIP CallOut, Invite <sip:601@192.168.14.8:5060;user=phone>
[015186] 0: 701=DIALING
[015266] 0: Inviting Timeout, Try Local Fxo ========
[015266] 0: Local Calling Fxo [601]
[015266] 0: Get Local Fxo Line 2
[015266] 2: TrunkPrefix=, Dest=601, Dialno=601
[015266] 2: FxoHookOff
[015266] 2: SetInputGain(-2)
[015267] 2: ==18:TrunkDialOut
[015277] 2: DialOut(601)=0
[015284] 2: Fxo DialOut OK
[015284] 2: Local Talk at ToAnswer
[015284] 2: RtpApiTalk[1,1], Peer=127.0.0.1:9000, PT=0, FC=4, NewOOB=0
[015284] 0: Local Talk at RingBack
[015284] 0: RtpApiTalk[1,1], Peer=127.0.0.1:9004, PT=0, FC=4, NewOOB=0
[015284] 2: ==14:Talking
[015284] 0: ==14:Talking
[015305] 2: Fxo Detected BTC(0)
[015305] DSP_ch2_check=0
[015305] 2: FxoHookOn
[015305] 2: Bye at Talking
[015305] 2: ==15:PlayBusyTone
[015305] 0: ==15:PlayBusyTone
[015305] 2: ==3:Idle
[015306] 2: SetInputGain(4)
[015306] 2: SetFax(1)=0
[015365] DSP_ch0_check=0
[015365] 0: Fxs Hangup
[015365] 0: ==3:Idle
[015365] 0: SetFax(1)=0
а вот лог второго шлюза
[014116] Receive Cmd=1100, ParaLen=5, Para=[Login]
[014116] Login == Ver(1.02.38.28.8749 2008/08/22 15:48:39) PId(242.DLink.NoPrefix.drtp.vlan) Drv(0.9.5.1.1140 30/Jul/2008 12:27:59) Hw(IAD202) == 0.6.7-1
[014314] 0: Alert Timeout, Reject Call
[014315] 0: 601=REJECT
[014315] 0: ==3:Idle
[014315] 0: SetFax(1)=0
[015042] 0: 601=OFFERING
[015042] 0: Get CallerId=701
[015043] 0: Peer=192.168.10.8:9000, PT=0, RecvOnly=0
[015043] 0: ==12:Alerting
[015935] 0: Alert Timeout, Reject Call
[015935] 0: 601=REJECT
[015935] 0: ==3:Idle
[015935] 0: SetFax(1)=0
Шлюзы подключены по схеме DVG-7022-VPN-DVG-7022.
СообщениеДобавлено: Ср мар 03, 2010 10:15
Выложите пожалуйста скриншот настроек SIP c первого и второго шлюзов
СообщениеДобавлено: Ср мар 03, 2010 14:11
Скриншоты выложить в данный момент не могу, но могу сказать что со всех SIP серверов сняты галочки.
СообщениеДобавлено: Ср мар 03, 2010 14:15
Какие номера у линий на превом и втором шлюзе?
СообщениеДобавлено: Ср мар 03, 2010 14:21
На первом шлюзе с которого звоню номера 701-704, а на втором шлюзе на который звоню номера 601-604
СообщениеДобавлено: Ср мар 03, 2010 14:53
Хотелось бы еще и настройки сети
СообщениеДобавлено: Ср мар 03, 2010 14:54
Пожалуйста, дайте больше информации. Лог это конечно хорошо, но неплохо было бы дать пояснения.
Вы звоните с fxs на fxs? Шлюзы соединены напрямую? Какими портами (LAN/WAN)? Какие у них IP/маска? Что в phonebook обоих шлюзов?
Я хочу изменить мир к лучшему, но Бог не дает мне исходники (придумал не я)
Asterisk + DVG-4032S + 8xDVG-2032S + ATA Panasonic
СообщениеДобавлено: Ср мар 03, 2010 15:07
У первого шлюза IP 192,168,10,8 маска 255,255,255,0 у второго IP 192.168.14.8 маска 255,255,255,0 В телефонной книге прописаны на первом шлюзе номера второго с его IP а на втором шлюзе прописаны номера первого с его IP. Шлюзы подключены через машрутизаторы в разных городах.
СообщениеДобавлено: Ср мар 03, 2010 15:12
Судя по всему, вызов на второй шлюз проходит, но нет приема звонка, стоит ли non-SIP inbox call? Вы звоните на fxo линию или fxs?
попробуйте отключить hotline и прозвонить с fxs все понрты удаленного шлюза. (т.е. номера 601-604)
СообщениеДобавлено: Ср мар 03, 2010 16:30
Смотрите лог
У вас шлюз с адресом 192.168.14.8 не отвечает на инвайт. Смотрите снифером, идет ли ответ назад через маршрутизаторы, может файрволом блокируются пакеты. Хотя с другой стороны второй шлюз вроде как звонит на телефонный аппарат, но трубку не поднимают в течение 90 секунд:
СообщениеДобавлено: Чт мар 04, 2010 06:34
Звонок то на второй шлюз проходит, но я не слышу гудков вызова, и если даже берут трубку телефона на втором шлюзе на первом шлюзе полная тишина как и была до этого, а потом на первом шлюзе идут гудки занято и все
СообщениеДобавлено: Чт мар 04, 2010 10:41
СообщениеДобавлено: Чт мар 04, 2010 10:42
Судя по тому, что вызов проходит, где то блокируются пакеты при возврате
СообщениеДобавлено: Ср мар 10, 2010 15:02
Спасибо огромное. Все заработало. Тема закрыта.
