Текущее время: Вт окт 27, 2026 07:53
 Заголовок сообщения: DG-102SS : Coding Profile 0 must have coding_type G711_MU
СообщениеДобавлено: Пн мар 28, 2005 11:32
При попытке поменять кодек на g729ab, на портах возникает ошибка:
ggdbg>activate
023152979 NMM:Coding Profile 0 must have coding_type G711_MU or G711_A
023152979 NMM: 0, Port Configuration Failed
023152979 NMM: 1, Port Configuration Failed
КАК ЭТО ВЫЛЕЧИТЬ?
несколько раз ресетил девайс и перепрошивал его, не помогает.
ggdbg>show version
PROM Version Label: 1.0B02
XGCP Version: Release 08.01.003 Telogy Software
CM Version Label: 1.0B02
TBD-TBD, SIP Build, 100 Ticks/Sec Clock
2 Voice TCIDS, 0 Data TCIDS
System has FLASH
TIU Continuous Polling (1)
DSP Configuration:
DSPs = 1
Channels per DSP = 2
HPI Mapping = 2 (FIFO)
Clock Mult = 4
Fsx Fsr = 2
Pwr Dn Tmr Period = 5000
Wake Up Int Mask = 0
HW Companding = 1
Serial Port Config = 0
Sync Int Config = 1
Clock Out Config = 1
Hint Control = 0x0
BDX Delay Control = 0
HW Gain Control = 0
PktIsr TS Offset = 0
Sample Freq (IPP) = 0
Serial Port Type = 1
Analog Codec Type = 0
Hpi Fifo Size = 894
Serial Port Assigm = 16
ggdbg>sip show
--- SIP configurations ---
enable_server_fqdn = 0
server_ip = 10.10.2.2
server_fqdn = seniorita_mallaguena
server_port = 5060
service_domain = 10.10.2.2
url_protocol = 2
user_phone_type = 1
timer_t2 = 4
p_n_ua = 1
enable_proceeding_timer = 1
non_register_mode = 0
initial_unregister_mode = 1
peertopeer_mode = 1
allow_PSTNcallwaiting = 1
100rel = 1
same_phone_number = 0
Min-SE = 180
Supported codecs: 18
digit_timer = 4
inComingCallFunctionType = 0
Line 1 configuration
phone_number = 800
display_name = ph800
user_agent_port = 5060
auth_username = 800
auth_password =
sig_tos = 5
rtp_tos = 5
ec = 1
vad = 1
Line 2 configuration
phone_number = 801
display_name = ph801
user_agent_port = 5061
auth_username = 801
auth_password =
sig_tos = 5
rtp_tos = 5
ec = 1
vad = 1
=== phone_table ===
1: [900] = 900@10.10.2.3:5060
2: [901] = 901@10.10.2.3:5061
3: [666] = dk@10.10.2.1:5060
4: [] = @0.0.0.0:0
5: [] = @0.0.0.0:0
6: [] = @0.0.0.0:0
7: [] = @0.0.0.0:0
8: [] = @0.0.0.0:0
9: [] = @0.0.0.0:0
10: [] = @0.0.0.0:0
OK
ggdbg>show coding 1
Configuration for coding profile id 1:
Tx Coding = G.711 MU
Rx Coding = G.711 MU
Coding profile for voice
Tx VIF size = 1920 (bits)
Rx VIF size = 1920 (bits)
VAD = Enabled
VAD threshold = Adaptive VAD
Playout nominal delay = 20 (msec)
Playout maximum delay = 120 (msec)
Playout minimum delay = 0 (msec)
Adaptive Playout = Adjust during silence period only
Rate = 14400
DTMF Relay = Disabled
Tone detect = Enabled
Call Progress Tone detect = Disabled
V.18 Tone detect = Disabled
SS7 COT Tone detect = Disabled
SF Sig Tone detect = Disabled
EC = Enabled
EC NL = Enabled
EC NL Sens = 327
EC Tail = 8 (msec)
EC Refresh = Update
EC Coeffs = Normal
EC Auto Update = Disabled
EC Auto Search = Disabled
EC Search Freeze = Disabled
Modem TX level = 0 (dB)
Modem CD threshold = 0
Modem no activity timeout = 0 (sec)
Caller ID Support = ENABLED
Resampling = Disabled
EC Config = NLP_FIXED
NLP Confort Noise = 65486
SID Retx Rate = 0
Encapsulation = RTP
Tx ssrc = 0
Tx start timestamp = 0
Rx ssrc = 0
Rx start timestamp = 0
Tx digit payload = 100
Rx digit payload = 100
Digit repetitions = 0
Secondary Decoder = Disabled
ggdbg>show tcid
Mode: Switched xGCP
Pref Voice coding profile: 1
Pref Fax coding profile: 0
Telephony Interface Configuration:
Gain (RX,TX) = (-2,-4)
Idle noise level = -6500 x .01 dB
Signaling Protocol: FXS Loop Start
FXS Loop Start Parameters:
Offhook Debounce: 50 msec
Onhook Debounce: 50 msec
Seize Detect: 100 msec
Originator Clear Detect: 1200 msec
Answering Party Clear Detect: 150 msec
CPC Wait: 200 msec
CPC Duration: 850 msec
Ring Id: Default (-1)
Caller Id Generation: ON
Dial Out Parameters:
Out Wait: 250 msec
Out Type: tone
Tone Out Off Time: 70 msec
Tone Out On Time: 70 msec
Tone Out Power: -130 x 0.1 dB (not configurable)
Echo Cancellation Parameters:
Mode: LINE
Output: HANDS FREE
V.18A Tone Detect Parameters:
Hangover: 0
Threshold: 0
Fraction: 0
Other Parameters
Call Limit: 65535 sec
Endpoint id : aaln/1
Partial Digit Timer: 10 sec
Critical Digit Timer : 4 sec
Service Class : 224
Default Digit Map: 0T
Default Event List: hu,hd,ft,mt
Entity to be notified:
Mode: Switched xGCP
CPC Wait: 200 msec
Out Wait: 250 msec
Out Type: tone
Mode: LINE
Output: HANDS FREE
Hangover: 0
Threshold: 0
Fraction: 0
Other Parameters
Endpoint id : aaln/2
Service Class : 224
СообщениеДобавлено: Пн мар 28, 2005 11:39
ЫЫ! ступил, не тот профиль воткнул:
ggdbg>show coding 0
Configuration for coding profile id 0:
Tx Coding = G.729AB
Rx Coding = G.729AB
Tx VIF size = 192 (bits)
Rx VIF size = 192 (bits)
VAD = Enabled
VAD threshold = 0 (dB) (relative to ref level of -30dBm)
Playout nominal delay = 0 (msec)
Playout maximum delay = 0 (msec)
Adaptive Playout = Disabled
Rate = 14400
EC = Disabled
EC NL = Disabled
EC NL Sens = 0
EC Tail = 0 (msec)
EC Refresh = Update
EC Coeffs = Normal
Caller ID Support = DISABLED
Resampling = Enabled
EC Config = Invalid (0)
NLP Confort Noise = 0
SID Retx Rate = 0
Encapsulation = Unknown Encapsulation
он в очень куцом состоянии, но если в первом профиле поменять кодек и присвоить его tcid'ам, то ошибка возникает та-же
