Текущее время: Вт окт 27, 2026 06:53
Начать новую тему Ответить на тему  [ Сообщений: 47 ]  На страницу Пред.  1, 2, 3, 4  След.
СообщениеДобавлено: Сб авг 14, 2004 08:38
Victor Kolosov писал(а):
Давайте версии прошивок, настройки обоих шлюзов.
dg102sh:
Boot PROM Version 0.0B16-G
Firmware Version TEST-B43
Hardware Revision
DSP Version Cap 0xfc12, Rel 8.1.0.2, Build g26 , DSP C5402, Platform VPBX/GG6E, Cap2 0x26fa, Cap3 0x4000, Chans 2, EC tail len 64, PCM chans 0
1104:
1.01
В логах показывется несколько другое:
dg102sh
ggdbg>000271075 HSMU: Enter call_profile->capabilities
000271075 HSMU: Coding Profile Bit 6 ignored, no 'voice' usage.
000271075 HSMU: Exit call_profile->capabilities.
000271075 HSMU 5: Process outgoing H.323 Fast Start call.
000271075 Dialing DEST = TA:xxx.69.204.82:1720,TEL:[MSK phone]
000271075 SOURCE = NAME:DEFAULT_H323_ID,TEL:2002
000271075 USER_TO_USER = CID_NAME:tcid1, CID_NUM:2002 SETUP
000271075 hsmup_open_rtp_sockets: nw_open(RTP2), port=30010, call_num=5
000271075 hsmup_open_rtp_sockets: nw_open(RTCP1), call_num=5, port=30011
000271088 HSMU 5: set timer for 50000 in state hsmup_state_h225_wait_alerting
000271088 HSMU 5: cmEvCallStateChanged(State = cmCallStateDialtone, cmCallStateFastStartReceived) - local
000271104 HSMU 5: cmEvCallStateChanged(State = cmCallStateDisconnected, cmCallStateModeDisconnectedUnreachable) - local
000271104 HSMU 5: cmEvCallStateChanged(State = cmCallStateIdle, cmCallStateFastStartReceived) - local
000271104 HSMU 5: abort timer in state hsmup_state_h225_wait_alerting
000271104 HSMU 5: H.323 release (IF)
000271156 HSMU 5: voice rtp open=1, rtcp open=1, nw_close(voice socked RTP2, RTCP1)
000271156 HSMU 5: nw_close(inchan local RTCP65535, RTP65535)
000271156 HSMU 5: nw_close(outchan local RTCP65535)
dvg1104th:
cmEvNewCall(hsCall=7060620) runs
No Free Slot,Drop the Call!!
cmEvCallStateChanged(state=cmCallStateDisconnected, statemode=cmCallStateModeDisconnectedLocal)
not found hsCall = 6bbc8c Got you
cmEvCallStateChanged(state=cmCallStateIdle, statemode=cmCallStateModeDisconnectedBusy)
СообщениеДобавлено: Пн авг 16, 2004 09:20
Модератор
Модератор
dg102sh:
Hardware Revision
1104:
1.01
dg102sh
dvg1104th:
Перешейте заново 1104.
Виктор Колосов
СообщениеДобавлено: Пн авг 16, 2004 09:38
Доброе утро Виктор, прошивки самые последние, и прошить 1104 достаточно проблематично, т.к. он находится за 1100 км. и настроить даже Ip там некому. Есть еще инфо... Опытным путём установлено, что звонки с 1104 на 102 проходят отлично....
usr/config$ rom -print
Download Method : TFTP
Hardware Ver. : A1
Boot Rom : boot.104
Application Rom : 101.bin
DSP App : 48302ce3.140
DSP Kernel : 48302ck.140
DSP Test Code : 483cbit.bin
Ringback Tone : ringbacktone.100
Hold Tone : holdtone.101
Greetings : greeting.101
Askpin : pincode.100
СообщениеДобавлено: Пн авг 16, 2004 09:45
Модератор
Модератор
Hardware Ver. : A1
Boot Rom : boot.104
ПОкажите еще
sysconf -prit
show coding 5
IP настраивать не потребуется т.к. 1104 не сбрасывает установленный IP на заводской.
Виктор Колосов
СообщениеДобавлено: Пн авг 16, 2004 10:00
ПОкажите еще
sysconf -prit
show coding 5
System information
Gateway Service: 2
Inter-Digit time out : 5
End of Dial : No end of dial
Port status:
port1: Enabled
port2: Enabled
port3: Enabled
port4: Enabled
DTMF selection : In-band
Line seizure mode: None
2nddial: Off
Dial Rule
outgoing call:(Call from PSTN)
filter: [] drop: [] insert: [].
incoming call:(Call from IP)
PIN prompt: 0
set1: 1111
set2: 2222
set3: 3333
set4: 4444
Ring Detect Method: 1
Ring before Answer: 0
FAX redundancy depth: 0
Caller ID Detect: disable
usr/config$ h323 -print
H.323 stack relate information
RAS mode : Peer-to-Peer
Registration mode : Gateway
Q931 port : 1720
RAS port : 1024
RTP port : 16384
Default Gateway : x
Allocated port range :
start port : 1024
end port : 65535
Response timeOut : 20
Connect timeOut : 600
usr/config$ voice -print
Voice codec setting relate information
Sending packet size :
G.723.1 : 30 ms
G.723.1 : 30 ms
G.723.1 : 30 ms
G.723.1 : 30 ms
G.729 : 40 ms
Priority order codec :
g7231 g7231 g7231 g7231 g729
Volume levels :
voice volume : 30
input gain : 32
dtmf volume : 24
Sound compress & CNG :
G.723.1 : Off
G.723.1 : Off
G.723.1 : Off
G.723.1 : Off
Echo canceller : On On On On
JitterBuffer Min Delay : 90
JitterBuffer Max Delay : 150
СообщениеДобавлено: Пн авг 16, 2004 10:05
Модератор
Модератор
ПОкажите еще
sysconf -prit
show coding 5
System information
Gateway Service: 2
Port status:
port1: Enabled
port2: Enabled
port3: Enabled
port4: Enabled
2nddial: Off
Dial Rule
PIN prompt: 0
set1: 1111
set2: 2222
set3: 3333
set4: 4444
Q931 port : 1720
RAS port : 1024
RTP port : 16384
Default Gateway : x
start port : 1024
end port : 65535
G.723.1 : 30 ms
G.723.1 : 30 ms
G.723.1 : 30 ms
G.723.1 : 30 ms
G.729 : 40 ms
Volume levels :
voice volume : 30
input gain : 32
dtmf volume : 24
G.723.1 : Off
G.723.1 : Off
G.723.1 : Off
G.723.1 : Off
Ну во первых нужно установить End of Dial : # и 2nddial: On
Вы используете 723 кодек.
Покажите настройки 102
show tcid 0
show coding
Виктор Колосов
СообщениеДобавлено: Пн авг 16, 2004 10:25
show tcid 0
show coding
Configuration for TCID 0:
Mode: Switched CAS
Pref Voice coding profile: 3
Pref Fax coding profile: 6
Pref Modem coding profile: 0
Pref Data coding profile: 0
Allowed Coding Prof Ids\Call Caps: (x - y means x to y both inclusive)
Coding prof: 0-127. Call cap: 0- 63.
Telephony Interface Configuration:
Companding = Mu-Law
Gain (RX,TX) = (-2,-4)
Idle noise level = -6500 x .01 dB
Call Progress Tone Detection Control = Always off
Call Progress Tone Detection Configuration = Default
Signaling Protocol: FXS Loop Start
FXS Loop Start Parameters:
Offhook Debounce: 50 msec
Onhook Debounce: 50 msec
Seize Detect: 100 msec
Originator Clear Detect: 450 msec
Answering Party Clear Detect: 150 msec
CPC Wait: 200 msec
CPC Duration: 850 msec
Ring Id: Default (-1)
Caller Id Generation: ON
Dial Out Parameters:
Out Wait: 250 msec
Out Type: tone
Tone Out Off Time: 100 msec
Tone Out On Time: 100 msec
Tone Out Power: -130 x 0.1 dB (not configurable)
Dial In Parameters:
Plar addr: None
Call Timing Parameters:
Call Limit: forever
Answer Wait: forever
Hangup Wait: forever
Fax Holdover: 2000 msec
Echo Cancellation Parameters:
Mode: LINE
Output: HANDS FREE
V.18A Tone Detect Parameters:
Hangover: 0
Threshold: 0
Fraction: 0
SS7 COT Tone Detect Parameters:
Hangover: 0
Threshold: 0
Fraction: 0
Single Frequency Signaling Tone Detect Parameters:
Hangover: 0
Threshold: 0
Fraction: 0
Tone Table:
Default
Caller ID Parameters:
Caller ID Number: 1
Caller ID Name: tcid0
Prefer Codec:
g723_53
_____
ggdbg>show coding
Configuration for coding profile id 1:
Tx Coding = G.711 MU
Rx Coding = G.711 MU
Coding profile for voice
Tx VIF size = 1280 (bits)
Rx VIF size = 1280 (bits)
VAD = Enabled
VAD threshold = Adaptive VAD
Playout nominal delay = 60 (msec)
Playout maximum delay = 120 (msec)
Playout minimum delay = 0 (msec)
Adaptive Playout = Adjust immediately
Rate = 14400
DTMF Relay = out-of-band:report to host, don't pass as voice
Tone detect = Enabled
Call Progress Tone detect = Disabled
V.18 Tone detect = Disabled
SS7 COT Tone detect = Disabled
SF Sig Tone detect = Disabled
EC = Enabled
EC NL = Enabled
EC NL Sens = 327
EC Tail = 8 (msec)
EC Refresh = Update
EC Coeffs = Normal
EC Auto Update = Disabled
EC Auto Search = Disabled
EC Search Freeze = Disabled
Modem TX level = 0 (dB)
Modem CD threshold = 0
Modem no activity timeout = 0 (sec)
Caller ID Support = Enabled
Resampling = Disabled
EC Config = NLP_FIXED
NLP Confort Noise = 65486
SID Retx Rate = 0
Encapsulation = RTP
Tx ssrc = 0
Tx start timestamp = 0
Rx ssrc = 0
Rx start timestamp = 0
Tx digit payload = 0
Rx digit payload = 0
Digit repetitions = 3
Secondary Decoder = Disabled
Configuration for coding profile id 2:
Tx Coding = G.711 A
Rx Coding = G.711 A
VAD = Enabled
Rate = 14400
EC = Enabled
EC NL = Enabled
EC NL Sens = 0
EC Tail = 8 (msec)
EC Refresh = Update
EC Coeffs = Normal
EC Config = Invalid (0)
NLP Confort Noise = 0
SID Retx Rate = 0
Encapsulation = RTP
Tx ssrc = 0
Rx ssrc = 0
Configuration for coding profile id 3:
Tx Coding = G723 5.3 kbps
Rx Coding = G723 5.3 kbps
Tx VIF size = 192 (bits)
Rx VIF size = 192 (bits)
VAD = Enabled
VAD threshold = 0 (dB) (relative to ref level of -30dBm)
Rate = 14400
EC = Enabled
EC NL = Enabled
EC NL Sens = 327
EC Tail = 8 (msec)
EC Refresh = Update
EC Coeffs = Normal
SID Retx Rate = 0
Encapsulation = RTP
Tx ssrc = 0
Rx ssrc = 0
Configuration for coding profile id 4:
Tx Coding = G723 6.3 kbps
Rx Coding = G723 6.3 kbps
VAD = Enabled
Rate = 14400
EC = Enabled
EC NL = Enabled
EC NL Sens = 327
EC Tail = 8 (msec)
EC Refresh = Update
EC Coeffs = Normal
SID Retx Rate = 0
Encapsulation = RTP
Tx ssrc = 0
Rx ssrc = 0
Configuration for coding profile id 5:
Tx Coding = G.729AB
Rx Coding = G.729AB
Tx VIF size = 160 (bits)
Rx VIF size = 160 (bits)
VAD = Enabled
Rate = 14400
DTMF Relay = Disabled
EC = Enabled
EC NL = Enabled
EC NL Sens = 0
EC Tail = 8 (msec)
EC Refresh = Update
EC Coeffs = Normal
Modem TX level = -13 (dB)
Modem no activity timeout = 20 (sec)
Caller ID Support = Disabled
SID Retx Rate = 0
Encapsulation = RTP
Tx ssrc = 0
Rx ssrc = 0
Configuration for coding profile id 6:
Tx Coding = T.38 FAX
Rx Coding = T.38 FAX
Coding profile for fax
Tx VIF size = 288 (bits)
Rx VIF size = 288 (bits)
VAD = Enabled
Playout nominal delay = 300 (msec)
Playout maximum delay = 300 (msec)
Playout minimum delay = 20 (msec)
Adaptive Playout = Disabled
Rate = 14400
EC = Disabled
EC NL = Disabled
EC NL Sens = 0
EC Tail = 8 (msec)
EC Refresh = Update
EC Coeffs = Normal
Modem TX level = -10 (dB)
Modem CD threshold = 1
Modem no activity timeout = 30 (sec)
Silence detection time = 0 (msec)
Silence detection level = 0 (dB)
Fax debug level = 0
TCF handling = Method 2 (Sent over the network)
Max low speed packetization = 1 (bytes)
Tx network timeout = 150 (sec)
Eflag start timer = 2600 (ms)
Eflag stop timer = 2300 (ms)
Scan line fix up = Enabled
Eflags for fast DIS = Enabled
TFOP proto enhancement = Enabled
NSF override = Disabled
T30 ECM = Disabled
T30 MR page compression = Disabled
T.38 Fax Parameters
Fax high-speed packet rate = 10 (msec)
Fax low-speed redundancy for T.38 UDP = 3
Fax high-speed redundancy for T.38 UDP = 0
SID Retx Rate = 2000
Encapsulation = UDP
FYI Было бы не плохо сделать возможность прикрепления к сообшению файлов.
СообщениеДобавлено: Пн авг 16, 2004 10:28
Модератор
Модератор
Выполните
set coding 3 dtmf_relay off
set coding 4 dtmf_relay off
nwdbg save changes
Виктор Колосов
СообщениеДобавлено: Пн авг 16, 2004 10:36
Выполните
nwdbg save changes
Сделал, всё попрежнему.
Странно, при наборе префикса ничего не происходит и в логах не отображается.
При наборе префикса + номер телефона происходит следуюшее.
на 102
ggdbg>spy 32 0
ggdbg>000033197 HSMU 2: cmEvCallStateChanged(State = cmCallStateDialtone, cmCallStateFastStartReceived) - local
000033213 HSMU 2: cmEvCallStateChanged(State = cmCallStateDisconnected, cmCallStateModeDisconnectedUnreachable) - local
000033213 HSMU 2: cmEvCallStateChanged(State = cmCallStateIdle, cmCallStateFastStartReceived) - local
на 1104
usr/config$ debug -open
usr/config$ cmEvNewCall(hsCall=7056828) runs
not found hsCall = 6badbc Got you
Последний раз редактировалось l0 Пн авг 16, 2004 10:44, всего редактировалось 1 раз.
СообщениеДобавлено: Пн авг 16, 2004 10:39
Модератор
Модератор
Выполните
nwdbg save changes
Тогда, все таки необходимо перешить 1104
Виктор Колосов
СообщениеДобавлено: Пн авг 16, 2004 10:49
Выполните
nwdbg save changes
Виктор, подскажите пожалуйста ftp с которого можно сделать загрузку.
У себя я этого сделать не могу, т.к. сижу за nat, а на ftp.dlink.ru всё в архивах.
И еще вопрос
Отображается не тот номер который набираю на 102.
СообщениеДобавлено: Пн авг 16, 2004 10:52
Модератор
Модератор
Выполните
nwdbg save changes
И еще вопрос
Прямая ссылка на бинарный файл. ftp://ftp.dlink.ru/pub/VoIP/DVG-1104TH/Firmware/1.01
Виктор Колосов
СообщениеДобавлено: Пн авг 16, 2004 11:07
Какой Логин и пароль указывать?
СообщениеДобавлено: Пн авг 16, 2004 11:18
Модератор
Модератор
Там все открыто..нет ни логинов ни паролей.
Виктор Колосов
СообщениеДобавлено: Пн авг 16, 2004 11:19
Всё прошло удачно. Но! 1104 требует сброса.
Boot Rom : boot.104
Application Rom : /pub/VoIP/DVG-1104TH/Firmware/1.
* WARNING!! *
* Please issue "flash -clean" to consist software *
* version. But this command will back to factory *
* setting, please record your current setting. *
