Текущее время: Ср окт 28, 2026 05:16
СообщениеДобавлено: Ср фев 25, 2004 14:46
факсы не хотят ходить не туда ни сюда в схеме
факс#1 <-> 104 <- ip -> 1104 <-> PSTN <-> факс#2
хотя пару раз получалось принять/отправить факс.....??! :?
на обеих устройствах включен T38 и отключен fast start.
вот кусок лога:
000062524 Capability Set
000062524 Local capability codec "g711Ulaw64k".
000062524 Remote capability codec "g711Ulaw64k".
000062524 Match found for codec "g711Ulaw64k".
000062524 HSMU 6: Capabilities match found for "g711Ulaw64k"
000062524 HSMU 6: CapabilitiesExt_msg
000062543 HSMU 6: cmEvCallMasterSlaveStatus_msg: Local station is Master
000062543 HSMU 6: cmControlStateConnected, p_call->fast_start_on=0
000062543 HSMU 6: abort timer in state hsmup_state_h245_wait_complete
000062543 HSMU 6: Chan 0o - hsmup_open_channel() codec = "g711Ulaw64k", p_assoc_chan=0x0,chanal name ="g711Ulaw64k"
000062543 hsmup_open_channel: nw_open(RTCP2), call_num=6 , port=30013, chan_num(i/o)=0o
000062543 HSMU 6: set timer for 10000 in state hsmup_state_master_wait_connect_all_lc
000062543 HSMU 6: Chan 0i cmEvChannelSetRTCPAddress_msg IP = 212.220.101.6, Port = 16385
000062543 HSMU 6: Chan 0i - master offering channel "g711Ulaw64k"
000062543 HSMU 6: selected codec name=g711Ulaw64k, selected profile=1, master
000062543 hsmup_master_incoming_lc: nw_open(RTP1), call_num=6 , port=30012, chan_num(i/o)=0i
000062544 HSMU 6: Chan 0i: Opened RTP socket = 1, port = 30012
000062544 HSMU 6: Chan 0i - cmChannelStateConnected "g711Ulaw64k"
local RTCP = 30013, remote RTCP =16385, RTP = 212.220.101.66:30012
000062544 HSMU 6: Chan 0o cmEvChannelSetRTCPAddress_msg IP = 212.220.101.6, Port = 16385
000062544 HSMU 6: Chan 0o cmEvChannelSetAddress_msg IP = 212.220.101.6, Port = 16384
000062544 HSMU 6: Chan 0o - cmChannelStateConnected ""
local RTCP = 30013, remote RTCP =16385, RTP = 212.220.101.6:16384
000062544 HSMU 6: abort timer in state hsmup_state_master_wait_connect_all_lc
000062544 HSMU 6: VOICE CONNECTED, coding=g711Ulaw64k, mode=Master
000062544 HSMU 6: set timer for 30000 in state hsmup_state_voice_connected
000062587 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=4e
000063017 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000063323 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000063661 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000064049 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000064091 HSMU 6: abort timer in state hsmup_state_voice_connected
000064523 HSMU 6: request mode "request"
000064523 HSMU 6: recv cmReqModeRequest name=t38fax, entryId=2678
000064523 HSMU 6: recv cmReqModeRequest Chan 825110797i old codec name = "g711Ulaw64k"
000064542 NWIF: send_datagram() - could not send a UDP packet: no listening connection.
000064542 HSMU 6: Chan 0i - cmChannelStateConnected "g711Ulaw64k"
000064542 HSMU 6 [0i]: CH SM Unexpected event "HSMUE_CH_CONNECTED" in "hsmup_ch_state_connected" state.
000064542 HSMU 6: Master OpenLogicalChannel for fax.
000064542 HSMU 6: Chan 1o - hsmup_open_channel() codec = "t38fax", p_assoc_chan=0x0,chanal name ="t38fax"
000064542 hsmup_open_channel: nw_open(RTCP3), call_num=6 , port=30013, chan_num(i/o)=1o
000064542 HSMU 6: set timer for 10000 in state hsmup_state_fax_channel
000064542 HSMU: h323_get_static_cap_name capability name "t38fax"
000064542 HSMU 6: Chan 1i cmEvChannelSetRTCPAddress_msg IP = 212.220.101.6, Port = 16385
000064542 HSMU 6: Chan 1i - master offering channel "t38fax"
000064542 HSMU 6: selected codec name=t38fax, selected profile=6, master
000064542 hsmup_master_incoming_lc: nw_open(RTP4), call_num=6 , port=30012, chan_num(i/o)=1i
000064543 HSMU 6: Chan 1i: Opened RTP socket = 4, port = 30012
000064543 HSMU: h323_get_static_cap_name capability name "t38fax"
000064543 HSMU 6: Chan 1i - cmChannelStateConnected "t38fax"
000064543 HSMU 6: abort timer in state hsmup_state_fax_channel
000064543 HSMU 6: VOICE CONNECTED, coding=t38fax, mode=Master
000064543 HSMU 6: set timer for 30000 in state hsmup_state_voice_connected
000064551 HSMU 6: Chan 1o cmEvChannelSetRTCPAddress_msg IP = 212.220.101.6, Port = 16385
000064551 HSMU 6: Chan 1o cmEvChannelSetAddress_msg IP = 212.220.101.6, Port = 16384
000064551 HSMU 6: Chan 1o - cmChannelStateConnected ""
000064552 HSMU 6: abort timer in state hsmup_state_voice_connected
000064552 HSMU 6: set timer for 30000 in state hsmup_state_voice_connected
000065084 HSMU 6: abort timer in state hsmup_state_voice_connected
000065084 HSMU 6: set timer for 30000 in state hsmup_state_voice_connected
000066342 DIM: 0:3 - dim_rx_pkt_violation suggests swo
000067554 HSMU 6: abort timer in state hsmup_state_voice_connected
000067554 HSMU 6: set timer for 30000 in state hsmup_state_voice_connected
000068814 HSMU 6: abort timer in state hsmup_state_voice_connected
000068814 HSMU 6: cmCallDropParam(p_call=0x4271ac, h323_release_reason=11)
000068814 HSMU: h323_get_static_cap_name capability name "t38fax"
000068866 HSMU 6: voice rtp open=0, rtcp open=0, nw_close(voice socked RTP0, RTCP0)
000068866 HSMU 6: nw_close(inchan local RTCP2, RTP1)
000068866 HSMU 6: nw_close(inchan local RTCP3, RTP4)
000068866 HSMU 6: nw_close(inchan local RTCP65535, RTP65535)
000068866 HSMU 6: nw_close(outchan local RTCP65535)
и почему 104 постоянно в дебаге валит на консоль:
000141505 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
:shock:
СообщениеДобавлено: Ср фев 25, 2004 14:47
версии:
1.01 и
1.0B20-G, 1.0B53-G
СообщениеДобавлено: Пн мар 01, 2004 13:07
guest писал(а):
версии:
1.01 и
1.0B20-G, 1.0B53-G
Понизте скорость на факсах а на RTCP не обращайте внимания, это 104 не понимает типы пакетов которые ему 1104 шлет, на процесс это не влияет.
С уважением, Дмитрий Письменов
СообщениеДобавлено: Вт мар 02, 2004 08:46
Дмитрий Письменов писал(а):
Понизте скорость на факсах .
в смысле на самих факс. аппаратах???
СообщениеДобавлено: Вт мар 02, 2004 14:09
снижение скорости на факсовом аппарате - непомогло :cry:
СообщениеДобавлено: Вт мар 02, 2004 14:37
set coding 6 rate 4800
СообщениеДобавлено: Вт мар 02, 2004 16:01
также не помогло.... :cry:
СообщениеДобавлено: Вт мар 02, 2004 16:11
Покажите настройки
104
show h323
show coding 6
1104
support -print
и лог с 1104.
СообщениеДобавлено: Ср мар 03, 2004 13:23
104 :
ggdbg>show h323
show h323
h323 display_name = 'DG-104SH'
h323 h323_ID = 'DEFAULT_H323_ID'
h323 h245_term_type = 60
h323 rtp_port_base = 30000
h323 rtp_tos = 8
h323 ras_tos = 4
h323 h225h245_tos = 6
h323 fast_start = off
h323 t38 = on
h323 t38_req_initiater = callee
h323 gk_mode = off
h323 no_ans_callfwd_time = 10
h323 h235_token = on
h323 h235_token_password =
ggdbg>show coding 6
show coding 6
Configuration for coding profile id 6:
Tx Coding = T.38 FAX
Rx Coding = T.38 FAX
Coding profile for fax
Tx VIF size = 288 (bits)
Rx VIF size = 288 (bits)
VAD = Enabled
VAD threshold = Adaptive VAD
Playout nominal delay = 300 (msec)
Playout maximum delay = 300 (msec)
Playout minimum delay = 20 (msec)
Adaptive Playout = Disabled
Rate = 4800
DTMF Relay = Disabled
Tone detect = Enabled
Call Progress Tone detect = Disabled
V.18 Tone detect = Disabled
SS7 COT Tone detect = Disabled
SF Sig Tone detect = Disabled
EC = Disabled
EC NL = Disabled
EC NL Sens = 0
EC Tail = 8 (msec)
EC Refresh = Update
EC Coeffs = Normal
EC Auto Update = Disabled
EC Auto Search = Disabled
EC Search Freeze = Disabled
Modem TX level = -10 (dB)
Modem CD threshold = 1
Modem no activity timeout = 30 (sec)
Silence detection time = 0 (msec)
Silence detection level = 0 (dB)
Fax debug level = 0
TCF handling = Method 2 (Sent over the network)
Max low speed packetization = 1 (bytes)
Tx network timeout = 150 (sec)
Eflag start timer = 2600 (ms)
Eflag stop timer = 2300 (ms)
Scan line fix up = Enabled
Eflags for fast DIS = Enabled
TFOP proto enhancement = Enabled
NSF override = Disabled
T30 ECM = Disabled
T30 MR page compression = Disabled
T.38 Fax Parameters
Fax high-speed packet rate = 10 (msec)
Fax low-speed redundancy for T.38 UDP = 3
Fax high-speed redundancy for T.38 UDP = 0
Caller ID Support = Disabled
Resampling = Disabled
EC Config = NLP_FIXED
NLP Confort Noise = 0
SID Retx Rate = 2000
Encapsulation = UDP
ggdbg>
1104:
usr/config$ support -print
Special Voice function support manipulation
T.38(FAX) support : Enabled.
T.38(FAX) ECM : Enabled.
FastStart support : Disabled.
Tunnelled H.245 support : Enabled.
H.245 message after FastStart : Enabled.
usr/config$
дебаг 1104:
(в первом случае факс посылался с 104 через 1104 в ТФОП + предв. звонок)
usr/config$ debug -add h323 h323vp
usr/config$ debug -open
usr/config$ cmEvNewCall(hsCall=7064012) runs
Set Tunnelling TRUE.
*-*-*-*-*-* Enter SSE section
*-*-*-*-*-* SSE section completed!
cmEvCallStateChanged(state=cmCallStateOffering, statemode=cmCallStateModeOfferingCreate)
0-Offering-cmEvCallStateChanged
cmEvCallStateChanged(state=cmCallStateConnected, statemode=cmCallStateModeConnectedCallSetup)
0-Connected-cmEvCallStateChanged
Callee----->
fs_flag[0]=0
------statemode: ConnectedCallSetup------
0-ControlStateTransportConnected
Enter cmEvCallCapabilities()
## Remote Capability Set
## [1] g711Ulaw64k: Audio Receive and Transmit
## [2] g711Alaw64k: Audio Receive and Transmit
## [3] g7231: Audio Receive and Transmit
## [4] g7231: Audio Receive and Transmit
## [5] g729AnnexA: Audio Receive and Transmit
## [6] t38fax: Data Receive and Transmit
First entry of matched remote TCS: (0)g711Ulaw64k
the best matched codec is g711Ulaw64k
MSDetermination: Master
0-cmControlStateConnected
cmEvCallStateChanged(state=cmCallStateConnected, statemode=cmCallStateModeConnectedCall)
Callee----->
fs_flag[0]=0
Calling party creating channel...
=== Channel New
=== Channel Set RTCP Address
call0 ch1-ChannelState: Dialtone
call0 ch1-ChannelState: RingBack
=== Channel open with codec: g711Ulaw64k, TxM=0
cmEvChannelSetRTCPAddress hsChan = 6ae31c
RTCP call: 0, channel: 1
cmEvChannelSetAddress hsChan = 6ae31c
call0 ch1-212.220.101.66: 30012-cmEvChannelSetAddress
cmEvChannelParameters hsChannel: 6ae31c channeName = (null)
call0 ch1-ChannelState: Connected
Enter EvChannelNew..6ae4b4
call0 hsChanIn-cmEvChannelNew Send
cmEvChannelSetRTCPAddress hsChan = 6ae4b4
RTCP call: 0, channel: 0
cmEvChannelParameters hsChannel: 6ae4b4 channeName = g711Ulaw64k
incoming channel codec: g711Ulaw64k
call0 ch0-ChannelState: Offering
call0 ch0-ChannelState: Connected
0-Enter openDeviceChannel
H323ap select codec g711Ulaw64k
H323ap select codec g711Ulaw64k, TxM=2 echo=1
After connect, h245 connect
call0 ch0-ChannelState: Disconnected
call0 ch0-ChannelState: Idle
call0 ch1-ChannelState: Disconnected
call0 ch1-ChannelState: Idle
0-cmControlStateTransportDisconnected
cmEvCallStateChanged(state=cmCallStateDisconnected, statemode=cmCallStateModeDisconnectedNormal)
0-Disconnected-cmEvCallStateChanged reason = 11
cmEvCallStateChanged(state=cmCallStateIdle, statemode=cmCallStateModeDisconnectedBusy)
cmEvNewCall(hsCall=7064740) runs
Callee----->
fs_flag[0]=0
Callee----->
fs_flag[0]=0
=== Channel New
cmEvChannelSetRTCPAddress hsChan = 6ae64c
cmEvChannelSetAddress hsChan = 6ae64c
call0 ch1-212.220.101.66: 30014-cmEvChannelSetAddress
cmEvChannelParameters hsChannel: 6ae64c channeName = (null)
Enter EvChannelNew..6ae7e4
cmEvChannelSetRTCPAddress hsChan = 6ae7e4
cmEvChannelParameters hsChannel: 6ae7e4 channeName = g711Ulaw64k
cmEvChannelSetRTCPAddress hsChan = 6ae97c
cmEvChannelSetAddress hsChan = 6ae97c
cmEvChannelParameters hsChannel: 6ae97c channeName = (null)
Enter EvChannelNew..6aeb14
cmEvChannelSetRTCPAddress hsChan = 6aeb14
cmEvChannelParameters hsChannel: 6aeb14 channeName = t38fax
incoming channel codec: t38fax
call_back_from_VP 24
(факс прошол... очень повезло, в основном не проходит),
далее попытка послать факс из ТФОП на 104:
ringing 0 ~~~~~~
first_slot= 0 strDes=TA:212.220.101.66:1720, strOri=2011
0-cmCallNew() success
0-cmCallMake()
cmEvCallStateChanged(state=cmCallStateDialtone, statemode=cmCallStateModeDisconnectedBusy)
Destination e.164 = 761700
B: Insert cmParamCalledPartyNumber successfully.
Insert cmParamDestinationAddress successfully.
0-Dialtone-cmEvCallStateChanged
cmEvCallStateChanged(state=cmCallStateProceeding, statemode=cmCallStateModeDisconnectedBusy)
0-Proceeding-cmEvCallStateChanged
cmEvCallStateChanged(state=cmCallStateRingBack, statemode=cmCallStateModeDisconnectedBusy)
0-RingBack-cmEvCallStateChanged
ringing 0 ~~~~~~
Callee----->
fs_flag[0]=0
MSDetermination: Slave
Callee----->
fs_flag[0]=0
=== Channel New
Enter EvChannelNew..6aee44
cmEvChannelSetRTCPAddress hsChan = 6aee44
cmEvChannelParameters hsChannel: 6aee44 channeName = g711Ulaw64k
cmEvChannelSetRTCPAddress hsChan = 6aecac
cmEvChannelSetAddress hsChan = 6aecac
call0 ch1-212.220.101.66: 30010-cmEvChannelSetAddress
cmEvChannelParameters hsChannel: 6aecac channeName = (null)
Enter EvChannelNew..6af174
cmEvChannelSetRTCPAddress hsChan = 6af174
cmEvChannelParameters hsChannel: 6af174 channeName = t38fax
cmEvChannelSetRTCPAddress hsChan = 6aefdc
cmEvChannelSetAddress hsChan = 6aefdc
cmEvChannelParameters hsChannel: 6aefdc channeName = (null)
Enter EvChannelNew..6af4a4
cmEvChannelSetRTCPAddress hsChan = 6af4a4
cmEvChannelParameters hsChannel: 6af4a4 channeName = g711Ulaw64k
факс не прошол :cry:
СообщениеДобавлено: Ср мар 03, 2004 13:48
Попробуйте вот что
1. Включите фаст-старт
2. Отключите VAD
СообщениеДобавлено: Ср мар 03, 2004 15:34
c fast start вообще ничего никуда ниходит :cry: ,
отключил VAD, вроде удалось принять/отправить - посмотрим, как дальше будет, спасибо за опреративные ответы и помощь :) .
СообщениеДобавлено: Ср мар 03, 2004 15:35
Сообщите сюда о результатах если не сложно.
СообщениеДобавлено: Чт мар 04, 2004 09:03
Да, опять то же самое опять не ходят уходить/приходить...
хотя ничего не меняли...
уже не знаю что и думать по этому поводу..... :shock:
СообщениеДобавлено: Чт мар 04, 2004 10:16
Поменяйте терминал-тайп на 104 попробуйте 1 и 255.
СообщениеДобавлено: Пн мар 15, 2004 12:08
все также.... :cry:
Сейчас этот форум просматривают: Baidu [Spider] и гости: 8
