Текущее время: Ср авг 05, 2026 12:11
 Заголовок сообщения: помогите разобраться с Dlink-dph-150se
СообщениеДобавлено: Ср май 23, 2012 09:07
телефон работает но иногда по чемуто перестает нажимать кнопки
вот лог с телефона (кнопри нажимаются но со статусом 9)
05-23-2012 12:53:11 User.Notice 192.168.1.44 [SIP] | NOTICE | allocating NICT context
05-23-2012 12:53:11 User.Notice 192.168.1.44 [SIP] | NOTICE | allocating transaction ressource 732 18355460519750-2822921968839
05-23-2012 12:53:11 User.Warning 192.168.1.44 [SIP] | WARNING| User need to authenticate to REGISTER!
05-23-2012 12:53:11 User.Warning 192.168.1.44 [SIP] | WARNING| OnEvent_New_Incoming4xxResponse!
05-23-2012 12:53:11 User.Notice 192.168.1.44 [SIP] | NOTICE | allocating transaction ressource 731 18355460519750-2822921968839
05-23-2012 12:52:47 User.Notice 192.168.1.44 [SIP] | NOTICE | free nist ressource
05-23-2012 12:52:47 User.Notice 192.168.1.44 [SIP] | NOTICE | free transaction ressource 730 892526f9-be70-4eff-a993-e2d11cd1544ef0de
05-23-2012 12:52:47 User.Warning 192.168.1.44 [SIP] | WARNING| Call leg is removed.
05-23-2012 12:52:47 User.Warning 192.168.1.44 [SIP] | WARNING| Transaction 730 killed.
05-23-2012 12:52:42 User.Info 192.168.1.44 [MGR] | INFO | >chan 0 is handed down.tick=1412039
05-23-2012 12:52:40 User.Info 192.168.1.44 [MGR] | INFO | >chan 0 gets the key=0 down,status=9
05-23-2012 12:52:40 User.Info 192.168.1.44 [MGR] | INFO | >chan 0 gets the key=8 down,status=9
05-23-2012 12:52:40 User.Info 192.168.1.44 [MGR] | INFO | >chan 0 gets the key=5 down,status=9
05-23-2012 12:52:39 User.Info 192.168.1.44 [MGR] | INFO | >chan 0 gets the key=1 down,status=9
05-23-2012 12:52:37 User.Info 192.168.1.44 [MGR] | INFO | >chan 0 gets the key=5 down,status=9
05-23-2012 12:52:37 User.Info 192.168.1.44 [MGR] | INFO | >chan 0 gets the key=4 down,status=9
05-23-2012 12:52:33 User.Notice 192.168.1.44 [SIP] | NOTICE | free nist ressource
05-23-2012 12:52:33 User.Notice 192.168.1.44 [SIP] | NOTICE | free transaction ressource 727 5613003e-ec3a-45e8-0aae-7f3bc2f9551ec95e
05-23-2012 12:52:33 User.Warning 192.168.1.44 [SIP] | WARNING| Call leg is removed.
05-23-2012 12:52:33 User.Warning 192.168.1.44 [SIP] | WARNING| Transaction 727 killed.
05-23-2012 12:52:32 User.Info 192.168.1.44 [MGR] | INFO | Call finished:We have been called from 89136863125 on 192.168.1.50 to operator2 by using SIP . The talk lasted 0 hour 0 minute 9 second
05-23-2012 12:52:32 User.Info 192.168.1.44 [MGR] | INFO | we receive bye, the call disconnected
05-23-2012 12:52:32 User.Warning 192.168.1.44 [SIP] | WARNING| info: call-leg has been found!
05-23-2012 12:52:32 User.Warning 192.168.1.44 [SIP] | WARNING| dialog ID match
05-23-2012 12:52:32 User.Notice 192.168.1.44 [SIP] | NOTICE | the dialog status is 3
05-23-2012 12:52:32 User.Notice 192.168.1.44 [SIP] | NOTICE | the local dialog callid is 892526f9-be70-4eff-a993-e2d11cd1544ef0de
05-23-2012 12:52:32 User.Notice 192.168.1.44 [SIP] | NOTICE | the sip message callid is 892526f9-be70-4eff-a993-e2d11cd1544ef0de
05-23-2012 12:52:32 User.Notice 192.168.1.44 [SIP] | NOTICE | the dialog remote tag is 67e1f041-c2350000-a8771e08
05-23-2012 12:52:32 User.Notice 192.168.1.44 [SIP] | NOTICE | the dialog local tag is 228588108
05-23-2012 12:52:32 User.Notice 192.168.1.44 [SIP] | NOTICE | the sip message to tag is 228588108
05-23-2012 12:52:32 User.Notice 192.168.1.44 [SIP] | NOTICE | the sip message from tag is 67e1f041-c2350000-a8771e08
05-23-2012 12:52:32 User.Notice 192.168.1.44 [SIP] | NOTICE | the local dialog callid is 18355460519750-2822921968839
05-23-2012 12:52:32 User.Notice 192.168.1.44 [SIP] | NOTICE | the dialog local tag is 1910320769
05-23-2012 12:52:32 User.Warning 192.168.1.44 [SIP] | WARNING| nist_bye_received():
05-23-2012 12:52:32 User.Notice 192.168.1.44 [SIP] | NOTICE | allocating NIST context
05-23-2012 12:52:32 User.Notice 192.168.1.44 [SIP] | NOTICE | allocating transaction ressource 730 892526f9-be70-4eff-a993-e2d11cd1544ef0de
05-23-2012 12:52:26 User.Info 192.168.1.44 [MGR] | INFO | >chan 0 gets the key=9 down,status=8
05-23-2012 12:52:25 User.Info 192.168.1.44 [MGR] | INFO | >chan 0 gets the key=0 down,status=8
05-23-2012 12:52:24 User.Info 192.168.1.44 [MGR] | INFO | >chan 0 gets the key=3 down,status=8
05-23-2012 12:52:23 User.Info 192.168.1.44 [MGR] | INFO | >chan 0 gets the key=* down,status=8
05-23-2012 12:52:23 User.Notice 192.168.1.44 [SIP] | NOTICE | free ist ressource
05-23-2012 12:52:23 User.Notice 192.168.1.44 [SIP] | NOTICE | free transaction ressource 728 892526f9-be70-4eff-a993-e2d11cd1544ef0de
05-23-2012 12:52:23 User.Warning 192.168.1.44 [SIP] | WARNING| Transaction 729 killed.
05-23-2012 12:52:23 User.Error 192.168.1.44 [SIP] | ERROR | The rfc2327 says there should be at least an email or a phone header!- anyway, we don't mind about it.
05-23-2012 12:52:23 User.Warning 192.168.1.44 [SIP] | WARNING| Found body application/sdp
05-23-2012 12:52:23 User.Error 192.168.1.44 [SIP] | ERROR | The content-type is not explicitely set.
05-23-2012 12:52:23 User.Warning 192.168.1.44 [SIP] | WARNING| info: call-leg has been found!
05-23-2012 12:52:23 User.Warning 192.168.1.44 [SIP] | WARNING| dialog ID match
СообщениеДобавлено: Ср май 23, 2012 09:35
Схему сети опишите. У Вас на порт телефона мультикаст не приходит?
СообщениеДобавлено: Ср май 23, 2012 10:44
одноранговая сеть на свитчах dgs-1024d сервер подключен к свитчу как и телефоны. атс октелл
и иногда телефон перестает набирать. при новом звонке все становится ок
СообщениеДобавлено: Ср май 23, 2012 12:18
ПРошивка на телефонах последняя? Телефон серого или черного цвета? Мульткаста в сети точно нет?
СообщениеДобавлено: Ср май 23, 2012 12:40
телефон черный. прошивка Firmware Version:GE_1.00
СообщениеДобавлено: Ср май 23, 2012 15:53
Прошейте последней прошивкой.
СообщениеДобавлено: Пт май 25, 2012 04:43
попробовал скачать прошивку DPH-150SE_2a21V1_7_334_135T20110429113441(0429163053).z залил
прошивка осталась прежней
СообщениеДобавлено: Чт июн 14, 2012 07:52
так все таки из за чего такое поведение длинка при нажатии кнопок
СообщениеДобавлено: Чт июн 14, 2012 09:31
обратитесь в сервисный центр для диагностики.
