Текущее время: Сб сен 26, 2026 21:18
 Заголовок сообщения: Проблема с DWL-3200AP
СообщениеДобавлено: Пт май 08, 2009 13:00
Доброго времени суток!
Имеется указанная выше точка доступа. К ней подлючено порядка 10 клиентов. Клиенты периодически "отваливаются" на syslog видим следующее:
May  8 12:37:26 10.0.5.120  [SYS]--AP reboot
May  8 12:37:53 10.0.5.120  [SYS]--AP warm start with f/w version: v2.50
May  8 12:37:54 10.0.5.120  [SYS]--Synchronize Timer with NTP server:10.0.20.1 successfully!
May  8 12:37:55 10.0.5.120  [WIRELESS]--WLAN1 Normal AP ready
May  8 12:37:56 10.0.5.120  [WIRELESS]--WLAN1 initiate Primary SSID: SSID:RND BSSID:00:21:91:81:8b:f7 Auth: WPA-AUTO-Personal
May  8 12:37:57 10.0.5.120  [WIRELESS]--WLAN1 initiate Multiple SSID[1]: SSID:ASP BSSID:04:21:91:81:8b:f7 Auth: WPA-AUTO-PSK
May  8 12:37:58 10.0.5.120  [WIRELESS]--Association:11G STA 00:1b:77:7e:b5:44 associated with WLAN1
May  8 12:37:59 10.0.5.120  [WIRELESS]--Association:11G STA 00:1b:77:7e:d8:e5 associated with WLAN1
May  8 12:38:00 10.0.5.120  [WIRELESS]--Association:11G STA 00:1b:77:7e:98:ff associated with WLAN1
May  8 12:38:01 10.0.5.120  [WIRELESS]--Deauth: WLAN1 11G STA 00:1b:77:7e:b5:44 reason code=1
May  8 12:38:02 10.0.5.120  [WIRELESS]--Deauth: WLAN1 11G STA 00:1b:77:7e:d8:e5 reason code=1
May  8 12:38:03 10.0.5.120  [WIRELESS]--Association:11G STA 00:1b:77:7e:d8:e5 associated with WLAN1
May  8 12:38:04 10.0.5.120  [WIRELESS]--Association:11G STA 00:1c:f0:da:5d:a5 associated with WLAN1
May  8 12:38:05 10.0.5.120  [WIRELESS]--Association:11G STA 00:1e:58:ad:73:63 associated with WLAN1
May  8 12:38:06 10.0.5.120  [WIRELESS]--Deauth: WLAN1 11G STA 00:1b:77:7e:d8:e5 reason code=1
May  8 12:38:07 10.0.5.120  [WIRELESS]--Association:11G STA 00:1c:f0:da:5d:fa associated with WLAN1
May  8 12:38:08 10.0.5.120  [WIRELESS]--Association:11G STA 00:1e:58:ad:74:a4 associated with WLAN1 SSID = ASP MSSID-index = 1
May  8 12:38:09 10.0.5.120  [WIRELESS]--Received Disassoc: WLAN 1 11G STA 00:1e:58:ad:73:63
May  8 12:38:10 10.0.5.120  [WIRELESS]--Received Deauth: WLAN 1 11G STA 00:1e:58:ad:73:63 reason code=3
May  8 12:38:11 10.0.5.120  [WIRELESS]--Received Disassoc: WLAN 1 11G STA 00:1c:f0:da:5d:fa
May  8 12:38:12 10.0.5.120  [WIRELESS]--Received Deauth: WLAN 1 11G STA 00:1c:f0:da:5d:fa reason code=3
May  8 12:38:13 10.0.5.120  [WIRELESS]--Received Disassoc: WLAN 1 11G STA 00:1e:58:ad:74:a4
May  8 12:38:14 10.0.5.120  [WIRELESS]--Received Deauth: WLAN 1 11G STA 00:1e:58:ad:74:a4 reason code=3
May  8 12:38:15 10.0.5.120  [WIRELESS]--Association:11G STA 00:1c:f0:da:5d:fa associated with WLAN1
May  8 12:38:16 10.0.5.120  [WIRELESS]--Association:11G STA 00:1e:58:ad:73:63 associated with WLAN1
May  8 12:38:17 10.0.5.120  [WIRELESS]--Association:11G STA 00:1e:58:ad:73:6a associated with WLAN1
May  8 12:38:18 10.0.5.120  [WIRELESS]--Association:11G STA 00:1e:58:ad:74:a4 associated with WLAN1 SSID = ASP MSSID-index = 1
May  8 12:38:27 10.0.5.120  [SYS]--Web login success from 10.127.0.22
May  8 12:38:28 10.0.5.120  [SYS]--Get GMT from SNTP/NTP server:10.0.20.1 successfully!
May  8 12:38:34 10.0.5.120  Last message repeated 4 times
May  8 12:38:34 10.0.5.120  [WIRELESS]--Received Disassoc: WLAN 1 11G STA 00:1e:58:ad:73:63
May  8 12:38:34 10.0.5.120  [WIRELESS]--Received Deauth: WLAN 1 11G STA 00:1e:58:ad:73:63 reason code=3
May  8 12:38:43 10.0.5.120  [WIRELESS]--Association:11G STA 00:1b:77:7e:d8:e5 associated with WLAN1
May  8 12:38:44 10.0.5.120  [WIRELESS]--Association:11G STA 00:1b:77:bb:31:97 associated with WLAN1
May  8 12:38:44 10.0.5.120  [WIRELESS]--Association:11G STA 00:1b:77:7e:b5:44 associated with WLAN1
May  8 12:38:51 10.0.5.120  [WIRELESS]--Association:11G STA 00:1e:58:ad:73:63 associated with WLAN1
May  8 12:38:55 10.0.5.120  [WIRELESS]--Association:11G STA 00:1c:f0:da:5e:91 associated with WLAN1
May  8 12:39:15 10.0.5.120  [WIRELESS]--Received Disassoc: WLAN 1 11G STA 00:1e:58:ad:73:6a
May  8 12:39:15 10.0.5.120  [WIRELESS]--Received Deauth: WLAN 1 11G STA 00:1e:58:ad:73:6a reason code=3
May  8 12:39:15 10.0.5.120  [WIRELESS]--Association:11G STA 00:1e:58:ad:73:6a associated with WLAN1
May  8 12:43:46 10.0.5.120  [SYS]--Web logout from 10.127.0.22
May  8 12:48:53 10.0.5.120  [WIRELESS]--Received Disassoc: WLAN 1 11G STA 00:1c:f0:da:5d:fa
May  8 12:48:53 10.0.5.120  [WIRELESS]--Received Deauth: WLAN 1 11G STA 00:1c:f0:da:5d:fa reason code=3
May  8 12:49:10 10.0.5.120  [WIRELESS]--Association:11G STA 00:1c:f0:da:5d:fa associated with WLAN1
May  8 12:50:41 10.0.5.120  [WIRELESS]--Received Disassoc: WLAN 1 11G STA 00:1e:58:ad:73:6a
May  8 12:50:41 10.0.5.120  [WIRELESS]--Received Deauth: WLAN 1 11G STA 00:1e:58:ad:73:6a reason code=3
May  8 12:50:45 10.0.5.120  [WIRELESS]--Association:11G STA 00:1e:58:ad:73:6a associated with WLAN1
May  8 12:56:00 10.0.5.120  [WIRELESS]--Received Disassoc: WLAN 1 11G STA 00:1e:58:ad:73:6a
May  8 12:56:00 10.0.5.120  [WIRELESS]--Received Deauth: WLAN 1 11G STA 00:1e:58:ad:73:6a reason code=3
May  8 12:56:04 10.0.5.120  [WIRELESS]--Association:11G STA 00:1e:58:ad:73:6a associated with WLAN1
May  8 12:56:52 10.0.5.120  [SYS]--Web login success from 10.127.0.22
May  8 12:56:53 10.0.5.120  [SYS]--Get GMT from SNTP/NTP server:10.0.20.1 successfully!
May  8 12:58:41 10.0.5.120  Last message repeated 4 times
May  8 12:58:41 10.0.5.120  [SYS]--Web logout from 10.127.0.22
May  8 12:59:10 10.0.5.120  [SYS]--Web login success from 10.127.0.22
В чём может быть причина подобного поведения точки доступа?
СообщениеДобавлено: Пт май 08, 2009 13:14
Reason Code:
3 deauthenticated, STA is leaving IBSS or ESS, send from the STA
EX: Click the "reconnect" or "disconnect" in the STA UI
Вывод - станции выходят из зоны действия сети. Поскольку клиенты не перемещаются, единственный вариант - низкий уровень сигнала на точке доступа.
Решение - Используйте более мощные/направленные антенны. Поднимите уровень сигнала. Клиентам рекомендуется использовать направленные антенны.
СообщениеДобавлено: Пт май 08, 2009 13:19
Хотелось бы узнать, где можно получить информацию по кодам сообщений?
Текущее состояние клиентов:
Primary-SSID 00:1b:77:7e:98:ff G WPA-Personal 100% On
Primary-SSID 00:1c:f0:da:5d:fa G WPA-Personal 88% Off
Primary-SSID 00:1e:58:ad:73:6a G WPA-Personal 84% Off
Multi-SSID 1 00:1e:58:ad:74:a4 G WPA-Personal 100% Off
Primary-SSID 00:1c:f0:da:5e:91 G WPA-Personal 100% Off
Primary-SSID 00:1b:77:bb:31:97 G WPA-Personal 64% Off
СообщениеДобавлено: Вс май 10, 2009 16:31
Как видно из предыдущего поста, уровень сигнала достаточно высок...
