Текущее время: Вс ноя 08, 2026 08:31
 Заголовок сообщения: DWL 2000 AP+ ping статистика
СообщениеДобавлено: Сб фев 19, 2005 21:45
64 bytes from 212.8.33.185: icmp_seq=0 ttl=64 time=6767.628 ms
64 bytes from 212.8.33.185: icmp_seq=1 ttl=64 time=7081.376 ms
64 bytes from 212.8.33.185: icmp_seq=2 ttl=64 time=8376.066 ms
64 bytes from 212.8.33.185: icmp_seq=3 ttl=64 time=9254.124 ms
64 bytes from 212.8.33.185: icmp_seq=4 ttl=64 time=8674.273 ms
64 bytes from 212.8.33.185: icmp_seq=5 ttl=64 time=8894.942 ms
64 bytes from 212.8.33.185: icmp_seq=6 ttl=64 time=8846.676 ms
64 bytes from 212.8.33.185: icmp_seq=7 ttl=64 time=8558.529 ms
64 bytes from 212.8.33.185: icmp_seq=8 ttl=64 time=7985.242 ms
64 bytes from 212.8.33.185: icmp_seq=9 ttl=64 time=7623.365 ms
64 bytes from 212.8.33.185: icmp_seq=10 ttl=64 time=7901.578 ms
64 bytes from 212.8.33.185: icmp_seq=11 ttl=64 time=8095.172 ms
64 bytes from 212.8.33.185: icmp_seq=12 ttl=64 time=8205.149 ms
64 bytes from 212.8.33.185: icmp_seq=13 ttl=64 time=7374.772 ms
64 bytes from 212.8.33.185: icmp_seq=14 ttl=64 time=6745.503 ms
64 bytes from 212.8.33.185: icmp_seq=15 ttl=64 time=6472.057 ms
64 bytes from 212.8.33.185: icmp_seq=16 ttl=64 time=5943.635 ms
64 bytes from 212.8.33.185: icmp_seq=17 ttl=64 time=5315.262 ms
64 bytes from 212.8.33.185: icmp_seq=18 ttl=64 time=4606.858 ms
64 bytes from 212.8.33.185: icmp_seq=19 ttl=64 time=4661.401 ms
64 bytes from 212.8.33.185: icmp_seq=20 ttl=64 time=4288.229 ms
64 bytes from 212.8.33.185: icmp_seq=21 ttl=64 time=3704.540 ms
64 bytes from 212.8.33.185: icmp_seq=22 ttl=64 time=2697.299 ms
64 bytes from 212.8.33.185: icmp_seq=23 ttl=64 time=1700.207 ms
64 bytes from 212.8.33.185: icmp_seq=24 ttl=64 time=753.242 ms
64 bytes from 212.8.33.185: icmp_seq=25 ttl=64 time=27.404 ms
64 bytes from 212.8.33.185: icmp_seq=26 ttl=64 time=13.284 ms
64 bytes from 212.8.33.185: icmp_seq=27 ttl=64 time=8.582 ms
64 bytes from 212.8.33.185: icmp_seq=28 ttl=64 time=11.737 ms
64 bytes from 212.8.33.185: icmp_seq=29 ttl=64 time=8.727 ms
в чем может быть причина?
точка работает в режиме wireless client, пингуется база, к которой ходит точка по WiFi. У всех остальных клиентов этой базы (несколько из них через дом от меня) все нормально.
Меня смущает, что пакеты не теряются,но получаются какие-то дикие тайм-ауты.
Сейчас этот форум просматривают: Baidu [Spider] и гости: 16
