Текущее время: Сб сен 26, 2026 00:55
 Заголовок сообщения: Проблема DIR-300 и Wi-Fi
СообщениеДобавлено: Вт фев 10, 2009 17:06
Всем добрый день.
Есть ДИР-300 (проша 1.05), стац. РС (ХР SP3) и ноут DELL (ХР SP3). При подключении к роутеру проводами, всё ок, сеть работает и в сетевом окружении все друг друга видят и доступны друг другу расшаренные ресурсы.
Теперь проблема:
включаю на роутере Wi-Fi, настраиваю. Ноут подключается. В результате имею:
1. Ноут не видит РС и соответственно наоборот.
2. Ноут через каждые 3 мин. теряет подключение, с послед. восстановлением подключения. Логи:
"Feb 10 15:43:32 ","DHCP: Server sending ACK to 192.168.0.102. (Lease time = 604800)"
"Feb 10 15:43:32 ","DHCP: Server receive REQUEST from 00:19:7d:87:79:10."
"Feb 10 15:40:07 ","DHCP: Server sending ACK to 192.168.0.102. (Lease time = 604800)"
"Feb 10 15:40:07 ","DHCP: Server receive REQUEST from 00:19:7d:87:79:10."
"Feb 10 15:36:42 ","DHCP: Server sending ACK to 192.168.0.102. (Lease time = 604800)"
"Feb 10 15:36:42 ","DHCP: Server receive REQUEST from 00:19:7d:87:79:10."
"Feb 10 15:33:17 ","DHCP: Server sending ACK to 192.168.0.102. (Lease time = 604800)"
"Feb 10 15:33:17 ","DHCP: Server receive REQUEST from 00:19:7d:87:79:10."
"Feb 10 15:29:52 ","DHCP: Server sending ACK to 192.168.0.102. (Lease time = 604800)"
"Feb 10 15:29:52 ","DHCP: Server receive REQUEST from 00:19:7d:87:79:10."
"Feb 10 15:28:17 ","DHCP: Server sending ACK to 192.168.0.102. (Lease time = 604800)"
"Feb 10 15:28:17 ","DHCP: Server receive REQUEST from 00:19:7d:87:79:10."
"Feb 10 15:25:02 ","DHCP: Server sending ACK to 192.168.0.102. (Lease time = 604800)"
"Feb 10 15:25:02 ","DHCP: Server receive REQUEST from 00:19:7d:87:79:10."
"Feb 10 15:21:42 ","DHCP: Server sending ACK to 192.168.0.102. (Lease time = 604800)"
"Feb 10 15:21:42 ","DHCP: Server receive REQUEST from 00:19:7d:87:79:10."
"Feb 10 15:18:27 ","DHCP: Server sending ACK to 192.168.0.102. (Lease time = 604800)"
"Feb 10 15:18:27 ","DHCP: Server receive REQUEST from 00:19:7d:87:79:10."
"Feb 10 15:15:02 ","DHCP: Server sending ACK to 192.168.0.102. (Lease time = 604800)"
"Feb 10 15:15:02 ","DHCP: Server receive REQUEST from 00:19:7d:87:79:10."
"Feb 10 15:15:02 ","DHCP: Server sending OFFER of 192.168.0.102."
"Feb 10 15:15:02 ","DHCP: Server receive DISCOVER from 00:19:7d:87:79:10."
"Feb 10 15:14:37 ","DHCP: Server sending OFFER of 192.168.0.102."
"Feb 10 15:14:37 ","DHCP: Server receive DISCOVER from 00:19:7d:87:79:10."
"Feb 10 15:14:21 ","DHCP: Server sending OFFER of 192.168.0.102."
"Feb 10 15:14:21 ","DHCP: Server receive DISCOVER from 00:19:7d:87:79:10."
"Feb 10 15:14:14 ","DHCP: Server sending OFFER of 192.168.0.102."
"Feb 10 15:14:12 ","DHCP: Server receive DISCOVER from 00:19:7d:87:79:10."
Что может быть? Настройки использовал рекомендованные Д-Линком.
СообщениеДобавлено: Ср фев 11, 2009 14:59
1.Ноут не видит в сетевом окружении или не проходит пинг?Если в сетевом окружении,то вопрос с нетбиосом сейчас HQ решает.
2.Какой адаптер на ноуте,какой драйвер под него?видимость прямая?какое расстояние?
СообщениеДобавлено: Ср фев 11, 2009 18:09
Спасибо, проблема решилась установкой более свежей версии драйвера для адаптера Wifi на ноуте с сaппорта DELL.
СообщениеДобавлено: Ср фев 11, 2009 23:21
Несколько погорячился. Ноут по WiFi видит в Сетевом окружении РС и имеет доступ к расшаренным папкам. Но при этом РС тоже видит ноут, но доступа к ноуту нет. Выдаёт сообщение "Нет доступа к Ноутбуку. Возможно, у Вас нет прав на использование этого сетевого ресурса. Обратитесь к администратору этого сервера для получения соотв. прав доступа. Указанное сетевое имя более недоступно."
Но если ноут подключить кабелем, а не WiFi, то ко всем расшаренным папкам доступ есть. В чём может быть проблема?
СообщениеДобавлено: Чт фев 12, 2009 00:40
Включенный брандмауэр на беспроводном подключении.
СообщениеДобавлено: Чт фев 12, 2009 11:34
Да вроде отключён. В свойствах беспроводного соединения вкладка дополнительно - брандмауэр Виндовс отключён.
