Текущее время: Ср сен 02, 2026 06:22
СообщениеДобавлено: Пн окт 27, 2008 05:06
Доброго времени! Проблема в седующем- стоит две 2100АР в режиме моста, связь эсть только скорость низкая и постоянно на основной точке такой лог:
MON OCT 27 03:11:28 2008 Wireless --Received Deauth: WLAN 1 11G STA 00:21:
91:22:ce:93 reason code=7
MON OCT 27 03:11:53 2008 Wireless --Received Deauth: WLAN 1 11G STA 00:21:
MON OCT 27 03:12:18 2008 Wireless --Received Deauth: WLAN 1 11G STA 00:21:
MON OCT 27 03:12:34 2008 Wireless --Received Deauth: WLAN 1 11G STA 00:21:
MON OCT 27 03:12:43 2008 Wireless --Received Disassoc: WLAN 1 11G STA 00:2
1:91:22:ce:93
MON OCT 27 03:12:43 2008 Wireless --Received Deauth: WLAN 1 11G STA 00:21:
MON OCT 27 03:13:03 2008 Wireless --Received Deauth: WLAN 1 11G STA 00:21:
MON OCT 27 03:13:19 2008 Wireless --Received Deauth: WLAN 1 11G STA 00:21:
MON OCT 27 03:13:31 2008 Wireless --Received Disassoc: WLAN 1 11G STA 00:2
1:91:22:ce:93
MON OCT 27 03:13:31 2008 Wireless --Received Deauth: WLAN 1 11G STA 00:21:
MON OCT 27 03:13:42 2008 Wireless --Received Deauth: WLAN 1 11G STA 00:21:
MON OCT 27 03:13:54 2008 Wireless --Received Deauth: WLAN 1 11G STA 00:21:
MON OCT 27 03:14:08 2008 Wireless --Received Deauth: WLAN 1 11G STA 00:21:
MON OCT 27 03:14:47 2008 Wireless --Received Deauth: WLAN 1 11G STA 00:21:
MON OCT 27 03:14:57 2008 Wireless --Received Deauth: WLAN 1 11G STA 00:21:
MON OCT 27 03:15:03 2008 Wireless --Received Deauth: WLAN 1 11G STA 00:21:
MON OCT 27 03:15:29 2008 Wireless --Received Deauth: WLAN 1 11G STA 00:21:
MON OCT 27 03:15:59 2008 Last message repeated 3 times
MON OCT 27 03:15:59 2008 Wireless --Received Deauth: WLAN 1 11G STA 00:21:
MON OCT 27 03:18:18 2008 Wireless --WDS AP connected: wlan 1 11G AP 00:21:
91:22:ce:93
MON OCT 27 03:18:34 2008 Wireless --Received Disassoc: WLAN 1 11G STA 00:2
1:91:22:ce:93
ЧТО ЭТО ЗНАЧИТ :?:
СообщениеДобавлено: Пн окт 27, 2008 05:55
На первых четырех страницах нашел четыре темы с этой-же проблемой и ни в одном нет ответа :cry: Неужели техподдержка не знает причины данного поведения АПэшки? Что означают коды ошибок 2 и 7??????
СообщениеДобавлено: Пн окт 27, 2008 11:35
Hammer_ua
Хм... интересный лог))), уж не ломать ли вас пытаются? ;) По крайней мере на это похоже... Запросы дисассоциации и деаутентификации.
00:21:91:22:ce:93 - вот это кто?
Какая защита стоит? Если WEP я бы поменял на WPA, в идеале на WPA2. А также попытался бы найти машину с вышеприведенным маком и дать хозяину по рогам))).
СообщениеДобавлено: Пн окт 27, 2008 13:55
2 - client associated but not authorized - клиент не проходит авторизацию
7 Class 3 frames: data frames, management frames, control frames - получение Class 3 frame от не ассоциированой станции.Ломать видимо пытаются.
PS
знать то знаем,но в 5 утра не работаем
СообщениеДобавлено: Пн окт 27, 2008 14:16
Это мак моей удаленной точки моста. Она моя и ламать меня не может. Они сконнектены и переодически отваливается гдето раз в 2-5 минут. эфир чистый сигнал 68%. Менял прошивки не помогает. Питание 220 прямо в коробке!
СообщениеДобавлено: Пн окт 27, 2008 14:18
P.S. Периодически пропадает пинг
СообщениеДобавлено: Пн окт 27, 2008 14:31
Какое расстояние?Какие антенны,если есть и прочее - опишите топологию.
СообщениеДобавлено: Пн окт 27, 2008 15:07
три точки 2100ар все как мост Базовая с антенной всенапр 12дби длинк вторая на растоянии 400м прямая видимость антенна 24дби решетка- єта пара работает без вопросов , а вот вторая точка на растоянии 700м прямая видимость антенна 27дби решетка постоянно отваливается от базовой :cry:
Топология: AP2<->WDS<->AP1база<->WDS<->AP3
СообщениеДобавлено: Пн окт 27, 2008 16:01
Есть соображения????? :cry:
СообщениеДобавлено: Пн окт 27, 2008 17:05
Я так понимаю - мыслей НЕТ???
СообщениеДобавлено: Пн окт 27, 2008 17:47
Hammer_ua
Ну не хотел бы вас огорчать, просто как информация. Вы вообще в курсе как ломают WiFi? И что маки менять можно на ура, и софт-AP поднять не проблема. Я бы точно поставил снифер и глядел что происходит...
Деаутентификация - верный признак того, что кому-то нужны ARP-пакеты). Ну это ИМХО, конечно))), хотя все признаки есть.
П.С. И все же - какое у вас шифрование?
СообщениеДобавлено: Пн окт 27, 2008 17:57
Open system :( при wap сильно скорость падает
СообщениеДобавлено: Пн окт 27, 2008 18:03
по поводу снифера пасиба буду пробовать :)
СообщениеДобавлено: Пн окт 27, 2008 18:07
Тогда не знаю... Если бы WEP стоял, тогда можно предположить попытки взлома деаутенфикацией и набором ARP, если WPA - можно предположить, что кто-то поднял софт-АР, чтобы попытаться перехватить клиентов... А если без шифрования, то и толку что либо делать (ломать) нету.
Наверное действительно что-то с железкой или (в чем сомневаюсь) с настройками.
СообщениеДобавлено: Пн окт 27, 2008 18:25
Скачал ПО 2.50 перешил. точка загнулась пришлось ехать на место установки. По лану web "0" Acowa видит. "Горяче" ребутнул - проблемма осталась. Выключил из сети питания на 15 минут после включения точка ожила с новым ПО. Сделал все настройки очистил журнал лога на обоих точках. Наблюдаю три часа пока "отвалов" не наблюдаю. Завтра на єтой точке начнут работать юзеры- посмотрю, что получится. Буду надеятся на лутшее. Результаты раскажу :lol:
