Текущее время: Ср ноя 04, 2026 05:12
СообщениеДобавлено: Вс май 11, 2008 21:39
День добрый!
Имеется 2100 со следующими параметрами:
version
 SOFTWARE_VERSION: v2.40eu
D-Link Access Point wlan1 ->
get config
wlan1 revisions: mac 5.8 phy 4.4 analog 4.6
  PCI Vendor ID: 0x168c, Device ID: 0x13
  Sub Vendor ID: 0x168c, Sub Device ID: 0x13
chip is AR2312
Country Code: GB
Operation Mode: Wireless Client
Remote AP: 00:17:9A:9F:4A:88
Wlan State: Enabled
Radio Frequency: 2422 MHz (IEEE 3)
Wireless LAN Mode: 802.11g
Auto Channel Select: Disabled
Extended Channel Mode: Enabled
Data Rate: best
Antenna: 1
Login Username: admin
RADIUS address:
Name server IP address:
Name server domain suffix:
SSID: giga10
SSID Suppress Mode: Disabled
System Name: D-Link Access Point
Beacon Interval: 100
DTIM: 1
Fragmentation Threshold: 2346
RTS/CTS Threshold: 2346
Short Preamble: Enabled
11g Only Allowed: Enabled
CTS Mode: AUTO
CTS Rate: 11 Mbps
CTS Type: CTS-ONLY
11g Overlapping BSS Protection: Disabled
11g Beacon Rate: 1 Mbps
11g Draft 5.0 compatibility: Disabled
Short Slot Time: Enabled
Basic 11g Rate Set: (1, 2, 5.5, 11, 6, 12, 24)
11g Optimization Level: 1
Burst Time: 2
Burst Sequence Threshold: 3
IP Address: 192.168.31.253
IP Mask: 255.255.255.0
Host IP Address: 0.0.0.0
Gateway IP Address: 0.0.0.0
SNTP/NTP Server IP Address:
Time Zone: 27
HW Transmit Retry Limit: 4
SW Transmit Retry Limit: 3
TransmitPower: full
Current Transmit Output Power 17.0 dBm
SuperG :Disabled
Encryption: Disabled
Cipher selection: WEP
Authentication Type: Open-System
Default transmit key: 1
Shared Key  1, size  40, 0000000000
Access Check: Disabled
Key Entry Method: hexadecimal
Group Key Update Interval: 1800 seconds
Key Source: flash
Aging Interval: 300 seconds
Telnet Access: Enabled
Telnet Timeout: 180 seconds
Minimum rate: 1 Mbps
XR Poll interval: 100 msec
XR Frame Limit: 25
XR Poll Rate String is 0.25 1 1 3 3 6 6 20
XR Fragmentation Threshold: 540
антенна на 2100 ant24-2100, на другой стороне 1201, с неясной степенью направленности, расстояние 1200 м.
при подключении к другой точке доступа (судя по МАКу - тоже D-Link) в режиме AP Client имеем циклически повторяющиеся провалы в скорости продолжительностью 5 секунд с интервалом 30 секунд:
(реальная скорость в два раза меньше, т.к. DU meter считал трафик по всем интерфейсам - ethernet и vpn)
при этом RSSI меняется следующим образом:
get station
00:1a:92:44:9c:05, State: up, AID: 2
WLAN Mode: 2.4GHz 54Mbps (802.11g),  nonERP present: NO, nonERP protected: NO
Encryption: OFF Ciphers: NONE(unicast), NONE(multicast),  NONE
Compression: OFF
Power Save Mode: OFF
WMM: Disabled
Rx Data Rate: 11, RxSignalStrength(per cent): 40, AckSignalStrength: 18
              MSDU       Data    Mcast     Mgmt     Ctrl    Errors
Rx       295516     336787        0    30572        0    769489
Tx       222507     223433      329      109        0   3156718
и в терминале, что, в принципе, логично, идут сообщения:
< cservXrModeChangeNotify: switch count = -896
< cservXrModeChangeNotify: switch count = -897
< cservXrModeChangeNotify: switch count = -898
< cservXrModeChangeNotify: switch count = -899
Подскажите, пожалуйста, с чем можно пошаманить, чтобы стабилизировать скорость, при условии, что, по крайней мере пока, невозможно изменить ориентацию антенны на другой стороне и активировать режим WDS (если, конечно, это может оказать какое-либо положительное влияние)?
З.Ы. Пробовал ограничивать точку в 12 Мбит, высота пиков увеличилась, Изображение
количество ошибок уменьшилось
get station
Compression: OFF
WMM: Disabled
Rx Data Rate: 11, RxSignalStrength(per cent): 46, AckSignalStrength: 15
Rx       175521     210031        0    10920        0    525182
Tx       124697     125579      476      234        0    115143
качество выросло до 28,5%/52%, ошибки cservXrModeChangeNotify: switch count остались, периодичность провалов не изменилась...
ЗЗЫ Правда, потом статистика все равно портится до 28%/23%...
get station
Compression: OFF
WMM: Disabled
Rx Data Rate: 11, RxSignalStrength(per cent): 44, AckSignalStrength: 15
Rx       746916     885268        0    57223        0   2281390
Tx       530503     542409     1429      454        0   1843366
Последний раз редактировалось vulty Пн май 12, 2008 09:24, всего редактировалось 1 раз.
СообщениеДобавлено: Пн май 12, 2008 09:05
Пробуйте менять каналы. Ну и антенны обязательно покрутите.
СообщениеДобавлено: Пн май 12, 2008 09:39
я бы с радостью сменил канал, но ТД на другой стороне идет as is... так что могу крутить только свою ant24-2100...
есть ли какой-нибудь способ мгновенной оценки качества канала? я пробовал удаленно мониторить по acowa AP manager, юстируя антенну в попытках добиться максимального AckSignalStrength. 18 - лучшее из того, что получилось...
viewtopic.php?t=33508 ("ЧЕм измерить Линк ?") видел, но подтащить комп/ноут к антенне пока нет возможности...
