Текущее время: Вс сен 06, 2026 12:53
 Заголовок сообщения: глюки 7700АР
СообщениеДобавлено: Вт фев 19, 2008 19:47
Firmware Version: v2.00SG
> get config
Username : ______
Password : _______
MAC address : 00:11:95:e0:a9:38
Bridge Port Info List:
EntryAddr DevName Num MuxCookie Type
0x01566168 ixe 0 0x0156621C END
0x014B14AC vp 0 0x014AAD04 END
0x014B13E4 vp 8 0x014B137C END
0x014B11A8 mirror 1 0x014B1140 END
0x0151DB1C vp 9 0x0151DAB4 END
0x0151D2EC vp 10 0x0151D284 END
Country mode : Singapore(SG)
IP Leasing Table
MAC IP
Boot mode: Static
IP= 192.168.5.150
Subnet mask : 255.255.255.0
Default gateway : 192.168.5.1
IP Type: Static
Allowed connecting STA number: 10
Access Point Name : D-Link Corp. Access Point
System Contact : WLAN
System Location : Kalinina_str_123
System Description :
Telnet Support State : Enable
Telnet Timeout Value : never timeout
Internal connection between WLAN11a and WLAN11g : Disable
SNMP Support State : Disable
Current Temperature - 37`C
Alarm temperature set to - 80`C
Radius Server IP=
Radius Secret=
Radius Port= 1812
System uptime = 2107 (Sec)
System uptime = 0 Day 0(H):35(M):7(S)
Current Status: Enable
System log server IP address : 192.168.5.1
System Local Log Status: Eanble
System Remote Log Status: Eanble
Local System Log:
000 Uptime 0 day 00:00:06 AP cold start with v2.00SG version
001 Uptime 0 day 00:00:06 Band: 11G Status: Authenticated Mac:00046148F7FE
002 Uptime 0 day 00:00:12 Band: 11G Status: Authenticated Mac:00046148F7FE
003 Uptime 0 day 00:00:12 Wireless STA connected 00-04-61-48-F7-FE
004 Uptime 0 day 00:10:15 Web Login success from 192.168.0.30
005 Uptime 0 day 00:20:11 ProbeRequest Transmit Error 1
006 Uptime 0 day 00:20:21 ProbeRequest Transmit Error 1
007 Uptime 0 day 00:21:14 Telnet Login success from 192.168.5.1
008 Uptime 0 day 00:33:01 Web logout from 192.168.0.30
System syslog status: Eanble
Wireless syslog status: Eanble
Notice syslog status: Eanble
Ethernet Server 1 IP : 0.0.0.0
Ethernet Server 2 IP : 0.0.0.0
Ethernet Server 3 IP : 0.0.0.0
Ethernet Server IP Check Status: Disable
OK!
почему-то не получается ограничить общение между собой клиентов, хотя
Internal Station Connection - галочка не стоит
а мне это учень нуно...
Потом, оу меня две точки и обе по раз пять за две недели виснут, чё делать?
СообщениеДобавлено: Пт фев 22, 2008 14:44
техподдержка пожалуйста ответьте
СообщениеДобавлено: Ср мар 05, 2008 11:07
Техподдержка ответье, ну..
СообщениеДобавлено: Ср мар 05, 2008 12:46
Дело в том,что нет пока возможности протестить.Результатов покамест нет.Жду поставку устройств.
СообщениеДобавлено: Ср мар 05, 2008 13:43
ок, а на когда примерно можно расчитывать получение...?
СообщениеДобавлено: Ср мар 05, 2008 14:00
Полагаю не раньше конца след.недели смогу дать ответ.
