Текущее время: Вс сен 06, 2026 19:15
 Заголовок сообщения: Вопрос и проблемка с DWL 2100 AP
СообщениеДобавлено: Вс ноя 25, 2007 00:13
Смотрите
Имеем
D-Link Access Point wlan1 -> get config
wlan1 revisions: mac 5.8 phy 4.4 analog 4.6
  PCI Vendor ID: 0x168c, Device ID: 0x13
  Sub Vendor ID: 0x168c, Sub Device ID: 0x13
chip is AR2312
Country Code: GB
Operation Mode: Access Point
Wlan State: Enabled
Radio Frequency: 2467 MHz (IEEE 12)
Wireless LAN Mode: 802.11g
Auto Channel Select: Disabled
Extended Channel Mode: Enabled
Data Rate: best
Antenna: best
Login Username: admin
RADIUS address:
Name server IP address:
Name server domain suffix:
SSID: HAHA
SSID Suppress Mode: Disabled
System Name: D-Link Access Point
Beacon Interval: 100
DTIM: 1
Fragmentation Threshold: 2346
RTS/CTS Threshold: 2346
Short Preamble: Enabled
11g Only Allowed: Disabled
CTS Mode: AUTO
CTS Rate: 11 Mbps
CTS Type: CTS-ONLY
11g Overlapping BSS Protection: Disabled
11g Beacon Rate: 1 Mbps
11g Draft 5.0 compatibility: Disabled
Short Slot Time: Enabled
Basic 11g Rate Set: (1, 2, 5.5, 11)
11g Optimization Level: 1
Burst Time: 2
Burst Sequence Threshold: 3
IP Address: 192.168.1.2
IP Mask: 255.255.255.0
Host IP Address: 0.0.0.0
Gateway IP Address: 192.168.1.1
SNTP/NTP Server IP Address:
Time Zone: 27
HW Transmit Retry Limit: 4
SW Transmit Retry Limit: 3
TransmitPower: full
Current Transmit Output Power 17.0 dBm
SuperG :Disabled
Encryption: Disabled
Cipher selection: WEP
Authentication Type: Open-System
Default transmit key: 1
Shared Key  1, size  40, 0000000000
Access Check: Disabled
Key Entry Method: hexadecimal
Group Key Update Interval: 1800 seconds
Key Source: flash
Aging Interval: 300 seconds
Telnet Access: Enabled
Telnet Timeout: 180 seconds
Minimum rate: 1 Mbps
XR Poll interval: 100 msec
XR Frame Limit: 25
XR Poll Rate String is 0.25 1 1 3 3 6 6 20
XR Fragmentation Threshold: 540
С прошивкой DWL2100AP-eu-firmware-v230patch02-rc131(0808150947).tfp
Получаем:
Ответ от 192.168.1.2: число байт=32 время=2мс TTL=64
Ответ от 192.168.1.2: число байт=32 время=1мс TTL=64
Ответ от 192.168.1.2: число байт=32 время=41мс TTL=64
Я понимаю что это не плохой результат, для этого устройства при работе в режиме AP, но всётаки вопрос как можно убрать явление:
СообщениеДобавлено: Вс ноя 25, 2007 11:57
Пинг как пинг. Появилась либо помеха, либо точка решила поменять скорость. В принципе, все нормально.
Попробуйте ping ip -t -l 8000
СообщениеДобавлено: Вс ноя 25, 2007 17:13
Выставил точке постоянную скорость - 54мб/с чтобы она не думала переходить на другую.
Помеха... точка стоит в 2-х метрах от ноута в одной комнате и ничто им не преграждает видимость это из физических помех, а по поводу помех в радиоэфире тож не оч верится....
Можа есть ещё предположения???
