Текущее время: Чт ноя 05, 2026 17:05
 Заголовок сообщения: DWL-G700AP плохо работает.
СообщениеДобавлено: Ср сен 05, 2007 16:22
Чем вызвано появление в логе таких записей:
8day 04:49:35 wlan0: A wireless client is associated - 00:06:4F:44:C5:BA
8day 04:54:23 wlan0: A expired STA is resumed - 00:13:02:08:76:FD
8day 04:55:13 wlan0: A STA is expired - 00:06:4F:44:C5:BA
8day 05:02:33 wlan0: A STA is expired - 00:13:02:08:76:FD
8day 05:03:37 wlan0: A wireless client is deauthenticated - 00:15:00:20:89:A6
8day 05:03:50 wlan0: A wireless client is deauthenticated - 00:15:00:20:89:A6
8day 05:03:54 Tx hangup! Reset wlan driver [14]...
8day 05:08:13 wlan0: A wireless client is deauthenticated - 00:15:00:20:89:A6
8day 05:08:22 Tx hangup! Reset wlan driver [15]...
8day 05:11:26 wlan0: A wireless client is deauthenticated - 00:15:00:20:89:A6
8day 05:11:36 Tx hangup! Reset wlan driver [16]...
8day 05:12:30 wlan0: A wireless client is deauthenticated - 00:15:00:20:89:A6
8day 05:12:31 wlan0: A wireless client is deauthenticated - 00:15:00:20:89:A6
8day 05:12:36 Tx hangup! Reset wlan driver [17]...
8day 05:13:33 wlan0: A wireless client is associated - 00:15:00:20:89:A6
8day 05:13:37 wlan0: A wireless client is deauthenticated - 00:15:00:20:89:A6
8day 05:14:17 wlan0: A wireless client is associated - 00:06:4F:44:C5:BA
8day 05:14:23 wlan0: A wireless client is associated - 00:15:00:20:89:A6
8day 05:14:33 wlan0: A wireless client is deauthenticated - 00:15:00:20:89:A6
8day 05:14:38 Tx hangup! Reset wlan driver [18]...
8day 05:25:41 Tx hangup! Reset wlan driver [26]...
8day 05:26:35 wlan0: A wireless client is deauthenticated - 00:15:00:20:89:A6
8day 05:26:39 wlan0: A wireless client is associated - 00:15:00:20:89:A6
8day 05:26:50 wlan0: A wireless client is deauthenticated - 00:15:00:20:89:A6
8day 05:26:58 Tx hangup! Reset wlan driver [27]...
8day 05:27:03 wlan0: A wireless client is deauthenticated - 00:15:00:20:89:A6
8day 05:27:04 wlan0: A wireless client is deauthenticated - 00:15:00:20:89:A6
8day 05:27:09 Tx hangup! Reset wlan driver [28]...
8day 05:27:33 wlan0: A wireless client is associated - 00:15:00:20:89:A6
8day 05:27:42 wlan0: A wireless client is deauthenticated - 00:15:00:20:89:A6
8day 05:27:56 Tx hangup! Reset wlan driver [29]...
8day 05:28:58 wlan0: A wireless client is deauthenticated - 00:15:00:20:89:A6
и так далее в таком роде. Клиент при этом отключается/подключается каждые несколько секунд, и ничего не работает. Я пробовал менять настройку скорости и mode setting, а также канал.
Сейчас я поставил mode setting: G mode, TX rate: 12 M, и вроде бы начало работать нормально.
Крайне неудобно, что это устройство никак нельзя просто перезагрузить по сети. Можно только сбросить установки на дефолты. (Кстати, кто-нибудь расскажет, при этом IP-адрес тоже сбрасывается на по умолчанию? Проверять на рабочей системе мне не хочется.) При изменении настроек происходит нечто вроде частичного перезапуска, чем я и пользуюсь (но при этом непонятно, что играет роль: новые настройки, или то что там что-то перезапустилось).
Версия прошивки:
Current Firmware Version: v2.13
Firmware Date: Fri, 30 Mar 2007
СообщениеДобавлено: Чт сен 06, 2007 08:58
Да,адрес также сбрасывается на дефлотный.Уровень сигнала у клиентского устройства достаточный?Какая шифрация стоит?
СообщениеДобавлено: Вс сен 09, 2007 15:11
Да, уровень сигнала "Отличный" (когда все работает). Там расстояние метров 10 всего. Шифрация WEP.
Клиент в это время был единственный (хотя в первой части лога видно, что кто-то еще ненадолго подключается).
СообщениеДобавлено: Вс сен 09, 2007 17:28
А у вас случаем DHCP Lease не на 10-20 секунд настроено?
СообщениеДобавлено: Пн сен 10, 2007 01:48
Нет, на этом компе адрес статический, хоть это и ноутбук.
Пока работает все, с теми настройками, которые я написал выше.
Сейчас этот форум просматривают: Google [Bot] и гости: 13
