Текущее время: Пн сен 07, 2026 14:00
 Заголовок сообщения: Логи DI-524UP
СообщениеДобавлено: Пт авг 03, 2007 11:43
Подключаюсь к AP провайдера через DWL-2000AP, оттуда патчкорд идет в WAN порт на DI-524UP, адрес получаю по DHCP 10.0.0.212
мой лог на DI-524UP:
--- Log Begin ---
Fri Aug 03 12:32:27 2007 DHCP:renew
Fri Aug 03 12:32:29 2007 DHCP:ack(DOL=600,T1=300,T2=525)
Fri Aug 03 12:37:28 2007 DHCP:renew
Fri Aug 03 12:37:30 2007 DHCP:ack(DOL=600,T1=300,T2=525)
Fri Aug 03 12:42:29 2007 DHCP:renew
Fri Aug 03 12:42:32 2007 DHCP:ack(DOL=600,T1=300,T2=525)
Fri Aug 03 12:43:12 2007 Unrecognized attempt blocked from 10.0.0.220:49160 to 10.0.0.25 TCP:80
Fri Aug 03 12:43:15 2007 Unrecognized attempt blocked from 10.0.0.220:49160 to 10.0.0.25 TCP:80
Fri Aug 03 12:43:21 2007 Unrecognized attempt blocked from 10.0.0.220:49160 to 10.0.0.25 TCP:80
Fri Aug 03 12:44:47 2007 Unrecognized attempt blocked from 10.0.0.220:49162 to 10.0.0.25 TCP:80
Fri Aug 03 12:44:49 2007 Unrecognized attempt blocked from 10.0.0.220:49162 to 10.0.0.25 TCP:80
Fri Aug 03 12:44:55 2007 Unrecognized attempt blocked from 10.0.0.220:49162 to 10.0.0.25 TCP:80
Fri Aug 03 12:47:31 2007 DHCP:renew
Fri Aug 03 12:47:33 2007 DHCP:ack(DOL=600,T1=300,T2=525)
Fri Aug 03 12:50:06 2007 Unrecognized attempt blocked from 10.0.0.93:49160 to 10.0.0.25 TCP:80
Fri Aug 03 12:50:08 2007 Unrecognized attempt blocked from 10.0.0.93:49160 to 10.0.0.25 TCP:80
Fri Aug 03 12:50:14 2007 Unrecognized attempt blocked from 10.0.0.93:49160 to 10.0.0.25 TCP:80
Fri Aug 03 12:52:32 2007 DHCP:renew
Fri Aug 03 12:52:34 2007 DHCP:ack(DOL=600,T1=300,T2=525)
Fri Aug 03 12:57:34 2007 DHCP:renew
Fri Aug 03 12:57:36 2007 DHCP:ack(DOL=600,T1=300,T2=525)
Fri Aug 03 13:02:35 2007 DHCP:renew
Fri Aug 03 13:02:37 2007 DHCP:ack(DOL=600,T1=300,T2=525)
Fri Aug 03 13:07:36 2007 DHCP:renew
Fri Aug 03 13:07:39 2007 DHCP:ack(DOL=600,T1=300,T2=525)
Fri Aug 03 13:12:38 2007 DHCP:renew
Fri Aug 03 13:12:40 2007 DHCP:ack(DOL=600,T1=300,T2=525)
Fri Aug 03 13:17:39 2007 DHCP:renew
Fri Aug 03 13:17:42 2007 DHCP:ack(DOL=600,T1=300,T2=525)
Fri Aug 03 13:21:26 2007 Unrecognized attempt blocked from 10.0.0.220:49161 to 10.0.0.25 TCP:80
Fri Aug 03 13:21:29 2007 Unrecognized attempt blocked from 10.0.0.220:49161 to 10.0.0.25 TCP:80
Fri Aug 03 13:21:35 2007 Unrecognized attempt blocked from 10.0.0.220:49161 to 10.0.0.25 TCP:80
Fri Aug 03 13:22:41 2007 DHCP:renew
Fri Aug 03 13:22:43 2007 DHCP:ack(DOL=600,T1=300,T2=525)
Fri Aug 03 13:23:13 2007 Unrecognized attempt blocked from 10.0.0.220:49177 to 10.0.0.25 TCP:80
Fri Aug 03 13:23:15 2007 Unrecognized attempt blocked from 10.0.0.220:49177 to 10.0.0.25 TCP:80
Fri Aug 03 13:23:21 2007 Unrecognized attempt blocked from 10.0.0.220:49177 to 10.0.0.25 TCP:80
Fri Aug 03 13:27:43 2007 DHCP:renew
Fri Aug 03 13:27:46 2007 DHCP:ack(DOL=600,T1=300,T2=525)
--- Log End ---
Подскажите пожалуйста что означает "Fri Aug 03 13:07:36 2007 DHCP:renew
Fri Aug 03 13:07:39 2007 DHCP:ack(DOL=600,T1=300,T2=525)"?
А так же не понятно что такое "Fri Aug 03 13:23:13 2007 Unrecognized attempt blocked from 10.0.0.220:49177 to 10.0.0.25 TCP:80"
СообщениеДобавлено: Пт авг 03, 2007 15:56
DHCP:ack - запрос на получение IP и проч. по DHCP.
DHCP:renew - собственно, получение IP и проч.
Блокирование подозрительной попытки попасть на 10.0.0.25 по порту TCP:80 с 10.0.0.220 по порту 49177.
10.0.0.212 - это IP WAN интерфейса роутера? Какой IP у точки?
Чей IP 10.0.0.220 ?
СообщениеДобавлено: Пн авг 06, 2007 06:25
Vladimir Degtyarev писал(а):
Чей IP 10.0.0.220 ?
Прошу прощения, ошибся... не 10.0.0.220 а 10.0.0.25 :) Разобрался! Спасибо!
