Текущее время: Вс ноя 08, 2026 20:37
СообщениеДобавлено: Вт окт 31, 2006 20:45
Atheros Troubleshooting Utility
Troubleshooter report...
Report date: Friday, October 27, 2006
Name: Driver installation test
Description: This test is to check the radio driver installation.
The radio's registry keys are OK.
Nic name. . . . . . . . . : Atheros AR5005G Wireless Network Adapter
Driver name . . . . . . . : Atheros AR5005G Wireless Network Adapter (Microsoft's Packet Scheduler)
Driver path . . . . . . . : C:\WINDOWS\system32\DRIVERS\ar5211.sys
Driver version. . . . . . : 4.2.0.82
Active Profile Name . . : Default
Test Done: The radio driver has been installed.
Name: Card insertion test
Description: This test is to check the radio insertion.
Test Done: The radio has been inserted.
Name: Card enable test
Description: This test is to check if the radio/driver is enabled.
Test Done: The radio has been enabled.
Description: This test is to check if the radio is turned on.
Test Done: Your radio is turned on.
Description: This test is to check your client adapter's association to an access point.
Link Status . . . . . . . : Associated
AP Name . . . . . . . . . : unavailable
AP IP Address . . . . . . : unavailable
Test Done: Test passed
Description: This test is to check authentication.
Test bypassed: Authentication test bypassed, because authentication is not in use.
Description: This test is to check your network settings.
Your IP address might not be correct.
Test Failure: You have not configured your computer to use the client adapter.
Solution: Use the Network icon in the System Preferences application
to set the network configuration for your client adapter.
Test completed.
утилита атероса ругается при нетворк-тесте. Что бы это могло значить ?
карта - D-Link DWL-G510
СообщениеДобавлено: Вт окт 31, 2006 21:39
вероятнее всего, сетка настроена вручную, айпишники прописаны вручную, утилита попыталась пингануть гейтвей или днс и не смогла.
или просто не смогла определить параметры конфигурации.
короче - что угодно, кроме аппаратных проблем может дать такую ошибку.
