Текущее время: Вс сен 20, 2026 11:16
 Заголовок сообщения: DWL-2100 eu (v2.30) Firmware А чего все молчат?
СообщениеДобавлено: Пт сен 22, 2006 12:43
Firmware: v2.30rc038
Hardware:
Date: Sep 11, 2006
Problems Resolved:
1. [Roaming]Update current AP1's association table, when STA roam to another AP2.
Enhancements:
None
Firmware: v2.30rc037
Hardware:
Date: Sep 5, 2006
Problems Resolved:
1. when set APC mode, APC can't connect to trapze AP(DWL8220) only in wpa2-psk ,the previous release is failed for testing
Enhancements:
None
Firmware: v2.30rc034
Hardware:
Date: Sep 5, 2006
Problems Resolved:
Enhancements:
None
Firmware: v2.30rc032
Hardware:
Date: Aug 31, 2006
Problems Resolved:
1. In telnet/cli command, hide the “11b only” item in “set wirelessmode” to be consistent with the web
2. Fix the bug that The function of Update configuration file is abnormity in WEB
3. According output table from PP Leon, adjust output power for region EU.
Enhancements:
None
Firmware: v2.30rc027
Hardware:
Date: Aug 25, 2006
Problems Resolved:
2. WDS WPA-PSK connection will drop after 20-30 mins
Enhancements:
1. Change default SSID to “dlink”;
2. Configuration file extension from CFG to DCF;
3. Support 64 character WEB login username length;
4. support Character Set of WEB login username, include "a~z","A~Z","0~9","@", ".", "-" and "_".
5. Pop error message when key in unsupported characters in WEB login user name.
6. Add command “get/set SNMP” to control snmp state.
7. Add f/w upgrade protection policy in WEB.
8. 802.1x packet pass through in AP mode,when authentication type is Open/Shared key
9. Support IEEE 802.1X, the Authentication can be initiated by the Authenticator PAE(support EAPOL start frame automatically).
10. Add Telnet command “Get PassPhrase” to display passphrase of wpa-psk
11. Add Telnet command “Get RadiusSecret” to display Radius Secret
СообщениеДобавлено: Пт сен 22, 2006 16:07
НАДО ПРОБОВАТЬ! ОЧЕНЬ ВАЖНЫЕ ОШИБКИ ИСПРАВЛЕНЫ - ЭТО ХОРОШО! :roll: = :lol:
З.Ы. ИНТЕРЕСНО ТОЛЬКО КТО ИМИ ЗАНИМАЕТСЯ! КТО ИХ ДЕЛАЕТ? ПУГАЕТ ТАКАЯ РАЗНИЦА НА САЙТАХ В РАЗНЫХ СТРАНАХ... У КОГО-ТО ЛУЧШЕ, НА КОМОВСКОМО ВААЩЕ 2.10... ПОЙМИ ИХ! САМОДЕЛКИНЫ!
СообщениеДобавлено: Пт сен 22, 2006 16:21
ИНТЕРЕСНО, исправили ли баг типа alpha\sdd.....
СообщениеДобавлено: Пт сен 22, 2006 16:48
УСТАНОВИЛ! РАБОТАЕТ ОТЛИЧНО! НЕ РЕБУТИТЬСЯ! МОЩНОСТЬ В ТЕЛНЭТЕ СМЕНИТЬ МОЖНО!
ТЕПЕРЬ РАБОТАЕТ НА 20 dBm! (ВЕРСИЯ HW: 4)
:lol: 8)
ВСЕМ УДАЧНЫХ ПРОШИВОК!
СообщениеДобавлено: Сб сен 23, 2006 16:19
Судя RC в версии прошивки, это релиз кандидат.
А где этих релизов качать можно? Или когда выйдет зафиналенная версия?
СообщениеДобавлено: Сб сен 23, 2006 21:50
Поставил, пришлось откатиться на 2.20.
2.30 Вводит точку в состояние ступора когда на нее валится шировещательный трафик с очень крупной локальной сети.
Точка работает очень хорошо с этой прошивкой, пока не вставляешь в свитч кабель этой самой крупной сети, пинг на точку через секунду пропадает по радио интерфейсу, через свитч - нестабилен. Радио канал меняет скорость на 108 Мб/сек и практически не работает. Когда убираешь этот сетевой широковещательный флуд - точка оживает и радио интерфейс нормализируется.
Откат на 2.20 решил проблему, точка ведет себя нормально при такой нагрузке.
СообщениеДобавлено: Пн сен 25, 2006 05:51
определенно могу сказать, что 2.30 не коцает теги 802.1q, в отличии
от 2.20 . Остальное будем посмотреть.
СообщениеДобавлено: Пн сен 25, 2006 06:38
есть две точки 2100AP A3 и A4... с 2.10 поставил 2.20eu на A3. На A4 она была прошита. Дык кроме огорчения ничего не получил - раза 3 лазил по крышам ресетил их, народ гонял и тд...Висли сами по себе, после сохранения настроек по-разному... Пришлось откатить ОБЕ на 2.10.... стали работать как положено. Пропали, ессно, полезные функции... Вышла 2.30 - залил на ОБЕ. Ресетнул. Не прошло и пары часов - ЗАВИСЛИ до пропадания пингов! Сегодня опять полезу на крышу ресетить. Залью опять 2.10. Лучшее враг хорошего....
СообщениеДобавлено: Вт сен 26, 2006 11:35
а еще кто нибудь тестил? не пойму она только с широковещательным трафиком глючит или вообще...
СообщениеДобавлено: Чт окт 05, 2006 18:19
ПОДТВЕРЖДАЮ!
РАБОТАЕТ ОТЛИЧНО! НЕ РЕБУТИТЬСЯ С МОЩНОСТЬ 20 dBm!
ВСЕГО ДВЕ ТОЧКИ НА 2.30 и одна на 2.20(руки не дошли и ноги тоже), все в режиме WDS with AP. НИ ПРОБЛЕМ НИ СБОЕВ В ТЕЧЕНИИ ДВУХ НЕДЕЛЬ НЕ НАБЛЮДАЛОСЬ! А ВООБЩЕ ЛОКАЛКУ С WiFi объединять вредно...
СообщениеДобавлено: Чт окт 05, 2006 18:36
Hardware:
Date: Sep 11, 2006
Problems Resolved:
Enhancements:
None
А где это добро брать?
СообщениеДобавлено: Чт окт 05, 2006 22:55
дык это ж ченжлог от этой же прошивки
СообщениеДобавлено: Чт окт 05, 2006 23:10
garald писал(а):
ПОДТВЕРЖДАЮ!
Уважаемый, а вы то флудер, если у вас такой голимый монитор, что вы ставити такой шрифт, то не надо об этом хвастаться 8) , а поводу нельзя сопрягать локалку с wi-fi? а как же вы еще доставите НЭТ пользователю, при этом пользователь платить деньги еще и за доступ к локальным ресурсам. А такое сказать, что трафик UDP запрещен и прирезать его, наверное Вы об таком и не слышили......
СообщениеДобавлено: Вс ноя 05, 2006 14:58
А как вам такое?
copa AP wlan1 -> set wire
wirelessmode 11g                    -- 802.11g
wirelessmode 108g dynamic           -- 802.11g Dynamic Turbo
Not enough parameters!
copa AP wlan1 -> set wire 11b
Invalid parameter: 11b
List of valid parameter(s):
 11g                                -- 802.11g
copa AP wlan1 ->
и такое на двух точках!
