Текущее время: Сб ноя 07, 2026 04:36
 Заголовок сообщения: DWL-7000AP <-> DWL-2000AP+ v rezime REPEATER
СообщениеДобавлено: Пт май 07, 2004 12:57
DWL-7000AP setup:
Boot mode : Manual
IP address : 10.10.10.1
Subnet mask : 255.255.255.0
Default gateway : 10.10.10.10
MAC address : 00:0d:88:50:70:5a
Speed : Auto
dtim : 1
Frag Threshold : 2346
RTS Threshold : 2346
Tx Power : Full
Radio ON
Beacon Interval: 100
Auth Type : Open System
ENCRYPTION : Disable
Cipher : WEP
Key Index : First
WLAN11g SSID Broadcast State : Enable
WLAN11g Auto Channel Scan State : Disable
Aging Period: 30 (sec)
Broadcast packet from Ethernet TO WLAN : Enable
Internal Station Connection State : Enable
Passphare: You are using PSK.
AP mode : Normal AP
Root AP's MAC address : 00:00:00:00:00:00
AP mode != AP Repeater ACL State : Disable
acl mode : disable
DWL-2000AP setup:
Device Information
Firmware Version 1.13 , 18 Feb 2004
Ethernet
MAC Address 000d88b3a0a3
IP Address 10.10.10.4
Subnet Mask 255.255.255.0
Gateway 10.10.10.10
Wireless
MAC Address 000d88b37008
SSID XXX
Encryption Function Disabled
Channel 1
Wireless performance:
Beacon interval: 100 (msec, range:1~1000, default:100)
RTS Threshold : 2346 (range: 256~2432, default:2432)
Fragmentation : 2346 (range: 256~2346, default:2346, even number only)
DTIM interval : 1 (range: 1~255, default:3)
TX Rates : Auto
Wireless Mode : mixed
Preamble Type : Long Preamble
SSID Broadcast : Enabled
Client security: Disabled
8X Mode : Disabled
Mode:
Repeater Remote AP MAC : 000d8850705a
View Log
page 1 of 1
Time Message
May/07/2004 11:33:05 Repeater mode Ready. Channel : 3 SSID : XXX Remote AP MAC : 00-0d-88-50-70-5a
May/07/2004 11:30:03 System started
Stats @ date Fri May 7 11:39:20 EEST 2004
Traffic Statistics
Traffic Statistics display Receive and Transmit Packets Passing through the DWL-2000AP+
Ethernet
Send Good Packets 84
Dropped Packets 0
Recv Good Packets 1026
Dropped Packets 0
Wireless
Send Good Packets 908
Dropped Packets 0
Recv Good Packets 675
Dropped Packets 0
PROBLEMA:
moshno ping AP -> Repeater (po4ti rabotajet:P
#date
Fri May 7 11:28:09 EEST 2004
#ping 10.10.10.4
PING 10.10.10.4 (10.10.10.4): 56 data bytes
64 bytes from 10.10.10.4: icmp_seq=2 ttl=127 time=6.581 ms
64 bytes from 10.10.10.4: icmp_seq=4 ttl=127 time=4.276 ms
64 bytes from 10.10.10.4: icmp_seq=9 ttl=127 time=3.800 ms
64 bytes from 10.10.10.4: icmp_seq=10 ttl=127 time=3.585 ms
64 bytes from 10.10.10.4: icmp_seq=13 ttl=127 time=3.399 ms
64 bytes from 10.10.10.4: icmp_seq=14 ttl=127 time=4.644 ms
64 bytes from 10.10.10.4: icmp_seq=15 ttl=127 time=3.595 ms
64 bytes from 10.10.10.4: icmp_seq=17 ttl=127 time=2.199 ms
64 bytes from 10.10.10.4: icmp_seq=18 ttl=127 time=7.175 ms
64 bytes from 10.10.10.4: icmp_seq=19 ttl=127 time=7.707 ms
64 bytes from 10.10.10.4: icmp_seq=20 ttl=127 time=4.961 ms
64 bytes from 10.10.10.4: icmp_seq=21 ttl=127 time=3.465 ms
64 bytes from 10.10.10.4: icmp_seq=22 ttl=127 time=4.017 ms
64 bytes from 10.10.10.4: icmp_seq=23 ttl=127 time=4.418 ms
64 bytes from 10.10.10.4: icmp_seq=24 ttl=127 time=2.755 ms
64 bytes from 10.10.10.4: icmp_seq=25 ttl=127 time=4.267 ms
~snip
64 bytes from 10.10.10.4: icmp_seq=653 ttl=127 time=3.780 ms
64 bytes from 10.10.10.4: icmp_seq=654 ttl=127 time=5.710 ms
64 bytes from 10.10.10.4: icmp_seq=655 ttl=127 time=4.165 ms
64 bytes from 10.10.10.4: icmp_seq=656 ttl=127 time=4.622 ms
64 bytes from 10.10.10.4: icmp_seq=657 ttl=127 time=4.740 ms
pausa (paketi ne pridut obratno) ~7 minut (#date Fri May 7 11:39:20 EEST 2004 --> Fri May 7 11:46:30 EEST 2004)
neshego ne proizhodit
64 bytes from 10.10.10.4: icmp_seq=1077 ttl=127 time=7016.008 ms
64 bytes from 10.10.10.4: icmp_seq=1078 ttl=127 time=6018.073 ms
64 bytes from 10.10.10.4: icmp_seq=1079 ttl=127 time=5021.392 ms
64 bytes from 10.10.10.4: icmp_seq=1080 ttl=127 time=4026.107 ms
64 bytes from 10.10.10.4: icmp_seq=1084 ttl=127 time=27.583 ms
64 bytes from 10.10.10.4: icmp_seq=1085 ttl=127 time=5.509 ms
64 bytes from 10.10.10.4: icmp_seq=1085 ttl=127 time=8.243 ms (DUP!)
64 bytes from 10.10.10.4: icmp_seq=1086 ttl=127 time=5.528 ms
64 bytes from 10.10.10.4: icmp_seq=1087 ttl=127 time=7.415 ms
64 bytes from 10.10.10.4: icmp_seq=1088 ttl=127 time=3.897 ms
64 bytes from 10.10.10.4: icmp_seq=1089 ttl=127 time=6.424 ms
64 bytes from 10.10.10.4: icmp_seq=1090 ttl=127 time=4.547 ms
~snip
64 bytes from 10.10.10.4: icmp_seq=1693 ttl=127 time=4.922 ms
64 bytes from 10.10.10.4: icmp_seq=1694 ttl=127 time=4.915 ms
64 bytes from 10.10.10.4: icmp_seq=1695 ttl=127 time=4.114 ms
64 bytes from 10.10.10.4: icmp_seq=1696 ttl=127 time=3.938 ms
64 bytes from 10.10.10.4: icmp_seq=1697 ttl=127 time=5.668 ms
pausa (paketi ne pridut obratno) ~7 minut (#date Fri May 7 11:57:31 EEST 2004 --> Fri May 7 12:05:09 EEST 2004)
64 bytes from 10.10.10.4: icmp_seq=2196 ttl=127 time=8020.490 ms
64 bytes from 10.10.10.4: icmp_seq=2197 ttl=127 time=7023.488 ms
64 bytes from 10.10.10.4: icmp_seq=2198 ttl=127 time=6027.009 ms
64 bytes from 10.10.10.4: icmp_seq=2199 ttl=127 time=5030.178 ms
64 bytes from 10.10.10.4: icmp_seq=2204 ttl=127 time=31.173 ms
64 bytes from 10.10.10.4: icmp_seq=2205 ttl=127 time=5.878 ms
64 bytes from 10.10.10.4: icmp_seq=2206 ttl=127 time=6.319 ms
64 bytes from 10.10.10.4: icmp_seq=2207 ttl=127 time=5.777 ms
~snip
64 bytes from 10.10.10.4: icmp_seq=2522 ttl=127 time=5.863 ms
64 bytes from 10.10.10.4: icmp_seq=2523 ttl=127 time=6.155 ms
64 bytes from 10.10.10.4: icmp_seq=2524 ttl=127 time=4.886 ms
64 bytes from 10.10.10.4: icmp_seq=2525 ttl=127 time=5.887 ms
64 bytes from 10.10.10.4: icmp_seq=2526 ttl=127 time=5.402 ms
^C
--- 10.10.10.4 ping statistics ---
2527 packets transmitted, 1593 packets received, +38 duplicates, 36% packet loss
round-trip min/avg/max/stddev = 2.199/34.409/8020.490/429.066 ms
no s klienta na Repeater'e (dhcp dajot adressa v te4enie minuta !!):
D:\W2KSRW\system32>ipconfig
Windows 2000 IP Configuration
Ethernet adapter wifi@avaya:
Connection-specific DNS Suffix . : xxx.xxx.net
IP Address. . . . . . . . . . . . : 10.10.10.243
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 10.10.10.10
D:\W2KSRW\system32>ping 10.10.10.4
Pinging 10.10.10.4 with 32 bytes of data:
Reply from 10.10.10.4: bytes=32 time=10ms TTL=127
Reply from 10.10.10.4: bytes=32 time<10ms TTL=127
Ping statistics for 10.10.10.4:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 10ms, Average = 2ms
D:\W2KSRW\system32>ping 10.10.10.1
Pinging 10.10.10.1 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 10.10.10.1:
Packets: Sent = 3, Received = 0, Lost = 3 (100% loss),
Minimum = 0ms, Maximum = 0ms, Average = 0ms
Control-C
^C
itak, proshu pomosh !
AP 7000+ rabotajet normalno, a nado vkljutshit k nemu i paru repiterov s omni antennas ...
moshet li tut bit delo v ustrositve (SETUP) oborudivaine ili 4to?
 Заголовок сообщения: DWL2000AP+ v rezime client
СообщениеДобавлено: Пт май 07, 2004 13:42
pohoshe CLIENT MODE na DWL2000AP+ takshe ne rabotajet, i esho: 7 minutnie pausi ne vosmoshno pingovat i s CLIENTa na REPEATERa samogo REPEATERA
smisli ?
СообщениеДобавлено: Вт май 11, 2004 14:42
Модератор
Модератор
Протестировали Вашу ситуацию.
2000АР+ Rev.A1 F/W 1.13 (Repiter mode)
7000AP Rev. A1 F/W 1.03sg (AP mode)
DWL-G520+ Driver: 4.0.40.1
Связка работала в течении 15 минут потери практически нулевые. Ничего из описанного Вами замечено не было. ping проходят в обе стороны.
Возможно у Вас неисправно одно из устройств или имеются сильные помехи.
Виктор Колосов
