Текущее время: Чт ноя 05, 2026 10:49
СообщениеДобавлено: Вт фев 28, 2006 14:59
Немогу Завязать 2100 и 350 cisco
ping xxx.xxx.xxx.xxx -s 1464
PING xxx.xxx.xxx.xxx (xxx.xxx.xxx.xxx) 1464(1492) bytes of data
1472 bytes from xxx.xxx.xxx.xxx: icmp_seq=1 ttl=128 time=23.2ms
Всё придел больше НЕ ЛЕЗУТ ну разумеется и сетка не работает. 2100 в качестве клиента. заместо BR350 пробовал менять BR340 такаяже фигня сто пудово касяк в 2100. Пробовал отключать WEP 128 всё равно (и это не решение)
Конфиг DWL-2100 AP :
wlan1 revisions: mac 5.8 phy 4.4 analog 4.6
PCI Vendor ID: 0x168c, Device ID: 0x13
Sub Vendor ID: 0x168c, Sub Device ID: 0x13
chip is AR2312
Country Code: GB
Operation Mode: Wireless Client
Remote AP: 00:40:96:56:F1:0B
Wlan State: Enabled
Radio Frequency: 2412 MHz (IEEE 1)
Wireless LAN Mode: 802.11g
Auto Channel Select: Disabled
Extended Channel Mode: Enabled
Data Rate: best
Antenna: 1
Login Username: admin
RADIUS address:
Name server IP address:
Name server domain suffix:
SSID: xxxxxx
SSID Suppress Mode: Disabled
System Name: bullet
Beacon Interval: 100
DTIM: 2
Fragmentation Threshold: 2048
RTS/CTS Threshold: 2048
Short Preamble: Enabled
11g Only Allowed: Enabled
CTS Mode: AUTO
CTS Rate: 11 Mbps
CTS Type: CTS-ONLY
11g Overlapping BSS Protection: Enabled
11g Beacon Rate: 1 Mbps
11g Draft 5.0 compatibility: Disabled
Short Slot Time: Enabled
Basic 11g Rate Set: (1, 2, 5.5, 11, 6, 12, 24)
11g Optimization Level: 1
Burst Time: 2
Burst Sequence Threshold: 3
IP Address: xxx.xxx.xxx.xxx
IP Mask: 255.255.255.0
Host IP Address: 0.0.0.0
Gateway IP Address: xxx.xxx.xxx.xxx
SNTP/NTP Server IP Address:
Time Zone:
HW Transmit Retry Limit: 4
SW Transmit Retry Limit: 3
TransmitPower: full
Current Transmit Output Power 17.0 dBm
SuperG :Disabled
Encryption: Enabled
Cipher selection: WEP
Authentication Type: Open System
Default transmit key: 1
Shared Key 1, size 104, xxxxxxxxxxxxxxxxxxxxxxxxx
Shared Key 2, size 104, xxxxxxxxxxxxxxxxxxxxxxxxx
Access Check: Disabled
Key Entry Method: hexadecimal
Group Key Update Interval: 0 seconds
Key Source: flash
Aging Interval: 300 seconds
Telnet Access: Enabled
Telnet Timeout: 60 seconds
Minimum rate: 1 Mbps
XR Poll interval: 100 msec
XR Frame Limit: 25
XR Poll Rate String is 0.25 1 1 3 3 6 6 20
XR Fragmentation Threshold: 540
 Заголовок сообщения: Ну что теперь ???
СообщениеДобавлено: Ср мар 01, 2006 08:51
Ну тогда скажите, что мне делать если ответа не знаете.
Какие бриджи(клиенты) с внешней антеной, сто пудово будут работать с Cisco BR350 и с dwl-2100ap в режиме AP и чтоб с производства не были сняты.
А может просто выкинуть Dlink, забыть, что такя фирма вобще есть и купить другое обарудование? , А ? :twisted:
СообщениеДобавлено: Чт июл 27, 2006 20:21
Уже решилась просто прошивочку 2.20 поставь проверено работает супер
СообщениеДобавлено: Чт июл 27, 2006 21:15
с прошивкой от бб точно работает с 1310, 1121, 1230
СообщениеДобавлено: Чт июл 27, 2006 21:24
А что, BR 350 поддерживает 11g ???
