Текущее время: Пт янв 24, 2020 23:19
 Заголовок сообщения: Re: DAP-1155 does not work in Client mode
СообщениеДобавлено: Сб авг 17, 2019 09:33
Dear Sir, click the Click'n'Connect link in the Home section. Select Client Mode.
On the opened page, click the Search button. Select the network to which you want to connect and click the Next button.
On the next page, you need to enter the password for connection to the network.
Enter the password in the Network key field. If you don't need a password to connect to the selected network, the Network key
field is unavailable. Click the Next button. On the next page, the parameters of the network to which you want to connect and the entered
password are displayed. Make sure that the specified settings are correct and then click the Apply button. After that, the wireless channel of
DAP-1155 will switch to the channel of the wireless access point to which you have connected. After configuring the device as a client, you need to create a WAN connection with relevant parameters for the WiFiClient interface.
After clicking the Apply button, the Home / Information page opens.
Сейчас этот форум просматривают: Google [Bot] и гости: 2
