Текущее время: Вс ноя 08, 2026 15:49
Начать новую тему Эта тема закрыта, Вы не можете редактировать и оставлять сообщения в ней.  [ Сообщений: 2 ]
Будет ли официальная документация по Telnet'y
Да 0%  0%  [ 0 ]
Нет 0%  0%  [ 0 ]
Второй год ждем 100%  100%  [ 2 ]
Всего голосов : 2
СообщениеДобавлено: Вт сен 27, 2005 04:29
Приложение 1. Список команд, доступных через telnet
config wlan -- config wlanX
del acl -- Delete Access Control List
del wdsacl -- Delete WDS Access Control List
del key -- Delete Encryption key
find bss -- Find BSS
find channel -- Find Available Channel
find all -- Find All BSS
dhcps help -- Display DHCP Server Command Help
get 11gonly -- Display 11g Only Allowed
get acl -- Display Access Control List
get wdsacl -- Display WDS Access Control List
get wdsap -- Display WDS Access Point
get apmode -- Display AP Mode(runtime)
get aging -- Display Aging Interval
get antenna -- Display Antenna Diversity
get association -- Display Association Table
get authentication -- Display Authentication Type
get autochannelselect -- Display Auto Channel Select
get beaconinterval -- Display Beacon Interval
get channel -- Display Radio Channel
get availablechannel -- Display Available Radio Channel
get cipher -- Display Encryption cipher
get config -- Display Current AP Configuration
get countrycode -- Display Country Code
get dhcpc -- Display DHCP Clinet State
get dtim -- Display Data Beacon Rate (DTIM)
get encryption -- Display Encryption Mode
get eth2wlan -- Display Eth2Wlan Broadcast packet filter state
get fragmentthreshold -- Display Fragment Threshold
get frequency -- Display Radio Frequency (MHz)
get gateway -- Display Gateway IP Address
get groupkeyupdate -- Display Group Key Update Interval (in Seconds)
get ipaddr -- Display IP Address
get ipmask -- Display IP Subnet Mask
get key -- Display Encryption Key
get keyentrymethod -- Display Encyrption Key Entry Method
get keysource -- Display Source Of Encryption Keys
get login -- Display Login User Name
get macaddress -- Display Mac address
get power -- Display Transmit Power Setting
get radiusname -- Display RADIUS server name or IP address
get radiusport -- Display RADIUS port number
get rate -- Display Data Rate
get remoteAp -- Display Remote Ap's Mac Address
get rtsthreshold -- Display RTS/CTS Threshold
get shortpreamble -- Display Short Preamble Usage
get shortslottime -- Display Short Slot Time Usage
get sntpserver -- Display SNTP/NTP Server IP Address
get ssid -- Display Service Set ID
get ssidsuppress -- Display SSID Suppress Mode
get station -- Display Station Status
get SuperG -- Display SuperG Feature Status
get systemname -- Display Access Point System Name
get sta2sta -- Display wireless STAs to wireless STAs connect state
get eth2sta -- Display ethernet to wireless STAs connect state
get telnet -- Display Telnet Mode
get timeout -- Display Telnet Timeout
get syslog -- Display Syslog Information
get uptime -- Display UpTime
get wirelessmode -- Display Wireless LAN Mode
get wlanstate -- Display wlan state
get vlanstate -- Display Vlan State State
get nativevlan -- Display Native Vlan Tag
get multi-state -- Display Multi-SSID Mode
get multi-ind-state [index] -- Display Individual Multi-SSID State
get Vlantag -- Display Vlantag
get multi-ssid [index] -- Display Service Set ID for Multi-SSID
get multi-authentication [index] -- Display Authentication Type for Multi-SSID
get multi-cipher [index] -- Display Encryption cipher for Multi-SSID
get multi-encryption [index] -- Display Encryption Mode for Multi-SSID
get multi-keyentrymethod -- Display Encryption Key Entry Method for Multi-SSID
get multi-vlantag [index] -- Display Vlan-Tag for Multi-SSID
get multi-key -- Display Encryption Key for Multi-SSID
get multi-config [index] -- Display AP Configuration for Multi-SSID
help -- Display CLI Command List
ping -- Ping
reboot -- Reboot Access Point
quit -- Logoff
set 11gonly -- Set 11g Only Allowed
set acl -- Set Access Control List
set wdsacl -- Set WDS List
set aging -- Set Aging Interval
set antenna -- Set Antenna
set apmode -- Set AP Mode
set authentication -- Set Authentication Type
set autochannelselect -- Set Auto Channel Selection
set beaconinterval -- Modify Beacon Interval
set channel -- Set Radio Channel
set cipher -- Set Cipher
set dhcpc -- Set DHCP Clinet State
set dtim -- Set Data Beacon Rate (DTIM)
set encryption -- Set Encryption Mode
set eth2wlan -- Set Eth2Wlan Broadcast packet filter state
set factorydefault -- Restore to Default Factory Settings
set fragmentthreshold -- Set Fragment Threshold
set gateway -- Set Gateway IP Address
set groupkeyupdate -- Set Group Key Update Interval (in Seconds)
set hostipaddr -- Set Host IP address
set ipaddr -- Set IP Address
set ipmask -- Set IP Subnet Mask
set key -- Set Encryption Key
set keyentrymethod -- Select Encryption Key Entry Method
set keysource -- Select Source Of Encryption Keys
set login -- Modify Login User Name
set syslog -- Set sysLog settings
set password -- Modify Password
set passphrase -- Modify Passphrase
set power -- Set Transmit Power
set radiusname -- Set RADIUS name or IP address
set radiusport -- Set RADIUS port number
set radiussecret -- Set RADIUS shared secret
set rate -- Set Data Rate
set remoteAP -- Set Remote AP's Mac Address
set rtsthreshold -- Set RTS/CTS Threshold
set shortpreamble -- Set Short Preamble
set sntpserver -- Set SNTP/NTP Server IP Address
set ssid -- Set Service Set ID
set ssidsuppress -- Set SSID Suppress Mode
set SuperG -- Super G Features
set systemname -- Set Access Point System Name
set sta2sta -- Set wireless STAs to wireless STAs connect state
set eth2sta -- Set ethernet to wireless STAs connect state
set wlanstate -- Set wlan state
set wirelessmode -- Set Wireless LAN Mode
set vlanstate -- Set Vlan State State
set nativevlan -- Set Native Vlan Tag
set multi-state -- Set Multi-SSID Mode
set multi-ind-state -- Set Individual Multi-SSID State
set Vlantag -- Modify Vlantag
set multi-ssid -- Set Service Set ID for Multi-SSID
set multi-authentication -- Set Authentication Type for Multi-SSID
set multi-cipher -- Set Cipher for Multi-SSID
set multi-encryption -- Set Encryption Mode for Multi-SSID
set multi-keyentrymethod -- Select Encryption Key Entry Method for Multi-SSID
set multi-vlantag [tag value] [index] -- Set Vlan-Tag for Multi-SSID
set multi-key -- Set Encryption Key for Multi-SSID
set telnet -- Set Telnet Mode
set timeout -- Set Telnet Timeout
timeofday -- Display Current Time of Day
version -- Software version
rstp setstp -- Modify Spanning Tree Settings
rstp getstp -- Show Spanning Tree Settings
rstp setport -- Modify STP Port Settings
rstp getport -- Show STP Port Settings
rstp setstate -- Modify Spanning Tree State
rstp getstate -- Show Spanning Tree State
rstp setdefault -- Set Factory Default
snmp adduser -- Add User To SNMP Agent
snmp deluser -- Delete User From SNMP Agent
snmp showuser -- Show User In SNMP Agent
snmp setauthkey -- Set User Auth Key
snmp setprivkey -- Set User Private Key
snmp addgroup -- Add User Group
snmp delgroup -- Delete User Group
snmp showgroup -- Show User Group
snmp addview -- Add User View
snmp delview -- Delete User View
snmp showview -- Show User View
snmp addcomm -- Add Communication String
snmp delcomm -- Delete Communication String
snmp showcomm -- Show Communication String
snmp addhost -- Add Host To Notify List
snmp delhost -- Delete Host From Notify List
snmp showhost -- Show Host In Notify List
snmp authtrap -- Set Auth Trap Status
snmp sendtrap -- Send Warm Trap
snmp status -- Display SNMP Agent status
snmp suspend -- Suspend SNMP Agent
snmp resume -- Resume SNMP Agent
snmp load_default -- Load SNMP Default Setting
tftp get -- Get a file from TFTP Server.
tftp uploadtxt -- Upload the configuration of the device to TFTP Server.
tftp srvip -- Setup the TFTP Server IP address.
tftp update -- Update the file to the device.
tftp info -- Information about the TFTPC setting
СообщениеДобавлено: Вт сен 27, 2005 04:31
http://www.techlabs.ru/articles/communi ... 0/0/293/4/
ссылочку забыл sorry
Сейчас этот форум просматривают: Baidu [Spider] и гости: 21
