Текущее время: Ср ноя 11, 2026 14:25
СообщениеДобавлено: Вт апр 03, 2012 10:04
При попытке просмотреть full map - я получаю сообщение: A device on the network, such as a hub or switch, is not working properly or is not compatible with the Link Layer Topology Discovery (LLTD) protocol
Но если отключаю Ethernet соединение по витой паре с маршрутизатором, то Wi-Fi net - видится на полной карте. (full map) вместе с маршрутизатором.
A device on the network, such as a hub or switch, is not working properly or is not compatible with the Link Layer Topology Discovery (LLTD) protocol, which Windows uses to create the map. To fix this problem, disable the device, turn it off, or remove it from your network.
Responses from other devices on the network are delayed or there is an incompatible router on the network. If responses are delayed, try waiting a few minutes and then refreshing the network map by pressing F5. If a router is incompatible, try disabling the router, turning it off, or removing it from your network.
