Текущее время: Пн окт 05, 2026 02:24
 Заголовок сообщения: 3G модем не работает с DIR-320NRU
СообщениеДобавлено: Чт авг 09, 2012 07:04
Всем доброго дня.
Приобрел недавно модем Билайновский ZTE 190 и не могу заставить его работать с wi-fi роутером DIR-320NRU rev.B1.
Выдаёт следующие логи:
Jan 1 00:00:06 kernel: [17179577.164000] rt3xxx-ohci rt3xxx-ohci: RT3xxx OHCI Controller
Jan 1 00:00:06 kernel: [17179577.168000] rt3xxx-ohci rt3xxx-ohci: new USB bus registered, assigned bus number 2
Jan 1 00:00:06 kernel: [17179577.172000] rt3xxx-ohci rt3xxx-ohci: irq 18, io mem 0x101c1000
Jan 1 00:00:06 kernel: [17179577.256000] usb usb2: configuration #1 chosen from 1 choice
Jan 1 00:00:06 kernel: [17179577.264000] hub 2-0:1.0: USB hub found
Jan 1 00:00:06 kernel: [17179577.268000] hub 2-0:1.0: 1 port detected
Jan 1 00:00:06 kernel: [17179577.280000] usb 1-1: new high speed USB device using rt3xxx-ehci and address 2
Jan 1 00:00:07 kernel: [17179577.424000] usb 1-1: Product: ZTE WCDMA Technologies MSM
Jan 1 00:00:07 kernel: [17179577.428000] usb 1-1: Manufacturer: ZTE,Incorporated
Jan 1 00:00:07 kernel: [17179577.432000] usb 1-1: SerialNumber: MF190AZTED010000
Jan 1 00:00:07 kernel: [17179577.496000] usb 1-1: configuration #1 chosen from 1 choice
Jan 1 00:00:07 kernel: [17179577.504000] scsi0 : SCSI emulation for USB Mass Storage devices
Jan 1 00:00:12 kernel: [17179582.508000] scsi 0:0:0:0: CD-ROM ZTE USB SCSI CD-ROM 2.31 PQ: 0 ANSI: 2
Jan 1 00:00:12 kernel: [17179582.516000] scsi 0:0:0:0: Attached scsi generic sg0 type 5
Jan 1 00:00:12 init_dongle: Error in initdongle (code:0100)
Jan 1 00:00:12 resident_usb_handler: init_dongle return 0100
Jan 1 00:00:20 kernel: [17179590.952000] br0: topology change detected, propagating
Jan 1 00:00:20 kernel: [17179590.956000] br0: port 4(eth2.1) entering forwarding state
Jan 1 00:00:20 kernel: [17179590.960000] br0: topology change detected, propagating
Jan 1 00:00:20 kernel: [17179590.964000] br0: port 3(eth2.2) entering forwarding state
Jan 1 00:00:20 kernel: [17179590.968000] br0: topology change detected, propagating
Jan 1 00:00:20 kernel: [17179590.972000] br0: port 2(eth2.3) entering forwarding state
Jan 1 00:00:20 kernel: [17179590.976000] br0: topology change detected, propagating
Jan 1 00:00:20 kernel: [17179590.980000] br0: port 1(eth2.4) entering forwarding state
Последний раз редактировалось Faraon2040 Чт авг 09, 2012 07:25, всего редактировалось 1 раз.
 Заголовок сообщения: Re: 3G модем не работает с DIR-320NRU
СообщениеДобавлено: Чт авг 09, 2012 07:14
Ну и собственно сам вопрос, где нибудь есть обновленный список 3G модемов, которые корректно бы работали с DIR-320NRU.
До этого пробовал работать с 3G модемом E173 от Huawei. Подключался, работал, но в течении дня происходили обрывы связи, после которых помогал только ребут по питанию. Перезагрузка роутера под админом не помогала. Решил, что дело в модеме.
Перепробовал прошивки 1.2.94, 1.3.0, 1.3.3. Результат почти одинаковый. Сейчас остался на прошивке 1.3.3
Подскажите, есть ли на билайновский модем специальная прошивка для DIR-320NRU?
СообщениеДобавлено: Пт авг 10, 2012 10:10
Тут есть: http://dlink.ru/ru/products/5/1466_b.html
Не знаю, на сколько этот список свеж...
СообщениеДобавлено: Пн авг 13, 2012 07:23
Поддерживаемые USB-модемы
GSM-модемы
• Huawei E150
• Huawei E1550
• Huawei E160G
• Huawei E169G
• Huawei E173
• Huawei E220
• ZTE MF626
• ZTE MF627
Как я понимаю, этот список уже не свежий. К примеру мне как раз важна поддержка модема ZTE MF190. Его в перечне нет.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 96
